Office Wants Me To Hang Coat Hooks, Say's Not Sure What's Behind Wall. - Carpentry - Contractor Talk
Old 11-23-2018, 02:26 PM   #1
vancouver dave's Avatar
Trade: Handyman carpenter
Rewards Points: 142
An office contacted me and wants an estimate to hang 6 coat hooks.
In the email they say they don't know what's behind the drywall and want an 'expert' to do the job.
I don't have x-ray vision and so I'm thinking I don't know what's behind the wall either.
I have a decent stud finder with A/C warning and I can look around at where the electrical outlets are.
But I don't know if there's plastic water pipes behind there. And I don't know if it's wood or steel stud behind there.
Also with office jobs, I find that I often don't pick up a new 'regular' client.
I think that happens for various reasons, like they just call people off the internet each time and maybe a new secretary etc...
Another is that in an office building if you do hit something it's a disaster as lawsuits will follow etc, whereas with home owner at least get a chance to shut things off and make it good again.
I think I've just talked myself out of it!
vancouver dave is offline
Old 11-23-2018, 02:36 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,494
Re: Office Wants Me To Hang Coat Hooks, Say's Not Sure What's Behind Wall.
zipits, wingits would be good choices.
find a couple of studs and hang a nice oak etc, 1x4-1x6 and mount your coat hooks....
griz is online now
The Following 9 Users Say Thank You to griz For This Useful Post:
Bull Trout (02-27-2019), Caleb1989 (11-26-2018), finisher65 (03-04-2019), hdavis (02-28-2019), Jaws (11-23-2018), pinwheel (11-23-2018), rrk (11-23-2018), sunkist (03-04-2019), tgeb (11-23-2018)
Old 11-23-2018, 07:04 PM   #3
TimNJ's Avatar
Rewards Points: 6,838
That's exactly how we did it in our church.
Took a 1x8 mahogany and fastened that to the studs and then spaced nice brass coat hooks evenly down the line. Looks really nice.
TimNJ is offline
Old 11-23-2018, 07:13 PM   #4
rrk's Avatar
Rewards Points: 5,448
You know what is usually in office partition walls? Nothing but sound insulation
I installed 75 4 hook coat racks in a large law office, made them in my shop and it took less than 10 min to install each including cleanup. I made a killing and got to trim out their conference rooms and make a trophy case for their awards after that.
rrk is offline
The Following 3 Users Say Thank You to rrk For This Useful Post:
Easy Gibson (11-27-2018), finisher65 (03-04-2019), hdavis (02-28-2019)
Old 11-23-2018, 07:48 PM   #5
Lettusbee's Avatar
Rewards Points: 1,646
I like to use an 1/8" tile bit, or even a piece of insulation rod for the first hole. Go easy and after you are through the drywall, (Which is usually 5/8" in commercial) quit spinning the bit and feel around in there for any weirdness. Wait, what were we talking about again?
If it's a multi story office building, fire suppression pipes can be running vertically through the wall even if there is no plumbing in that room. DAMHIK
Lettusbee is online now
Old 02-27-2019, 08:00 PM   #6
Learn-Build-Enjoy
ASidhu's Avatar
Trade: Carpentry and Landscaping
Rewards Points: 142
heavy duty adhesive backed coat hooks?
Command strips
ASidhu is offline
Old 02-27-2019, 08:12 PM   #7
MarkJames's Avatar
Rewards Points: 19,561
Precision work is required. Bill accordingly. Good thing they called you!
MarkJames is online now
Old 02-27-2019, 08:34 PM   #8
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
I do almost exclusively remodel work, and I will see if there is a bathroom behind a wall then drill through the drywall and then stop and plunge with the bit.
Its all about experience,
I can do this directly behind a shower or whatever. I know what I am feeling and can adjust accordingly.
If your not comfortable with this for sure you should pass
Anderson is offline
Old 02-27-2019, 08:41 PM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I would have had em hung and cashed the cheque in the time it took you to write that post.
Inner10 is offline
The Following 4 Users Say Thank You to Inner10 For This Useful Post:
cedarboarder (03-04-2019), finisher65 (03-04-2019), hdavis (02-28-2019), rrk (02-27-2019)
Old 02-27-2019, 09:19 PM   #10
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,536
I get these all the time. Gotta mount on wood pendants or pc 1x with a routed edge.
I use 1/8" x 6" drill bit to explore first, then zipits or similar.
This work is not full proof. Look around good. I've never had a problem. Have insurance and I usually look around for the main water shut off just in case.
I'll take as much comm work as I can get. Comm and multi family --- higher rate.
Two bathrooms behind these walls. Used my method -- 1/8" bit first --- then 3/8" for toggle bolt -- top hole of each flange.
Office wants me to hang coat hooks, say's not sure what's behind wall.-shelves-022719.jpg
Steve
We Fix Houses is offline
Old 02-27-2019, 09:39 PM   #11
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 19,322
Yo Dave, can we get some closure on this?
You get those coat hooks in there?
Easy Gibson is offline
Old 02-28-2019, 11:54 AM   #12
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,314
An estimate for (6) coat hooks ?
They wouldn't get an estimate from me. Here's my hourly rate, if you like I'll come take care of that for you. Cost will depend on what is there to anchor to and how long it takes to do it right.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Old 02-28-2019, 01:05 PM   #13
hdavis's Avatar
Rewards Points: 2,312
Mount on edge profiled board, I don't even check for pipes or electric, just use cut off finish nails or screws and some adhesive. If don't even bother to hit studs, just mount it where it works the best.
hdavis is online now
Old 02-28-2019, 09:10 PM   #14
Inner10's Avatar
You couldn't give them a flat rate for 6 hooks? I'd probably just say I have an x number hour minimum....here it is...
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Old 03-01-2019, 08:44 AM   #15
90%-er
onmywayup's Avatar
Rewards Points: 2,462
Yeap. I'd have lost 'em right away with our minimum... Although I have been surprised in the past by what people are willing to pay for a half hour job
onmywayup is offline
Old 03-01-2019, 11:47 AM   #16
If it were a large enough office, I would give away the 6 hooks for virtually nothing, then demand they call me for everything else.
This strategy and more can be found in my latest book, "How I Turned a $100 Window Caulking Job Into a $10,000 Painting Job."
Old 03-01-2019, 11:48 AM   #17
Inner10's Avatar
100 sounds pretty fair to hang 6 hooks...
Inner10 is offline
Old 03-01-2019, 11:51 AM   #18
Yup. Nobody is going to mind $100 to solve a problem. You just made $100/hr and made a new customer.
Let's leave the written estimate out of this. Print up an invoice and hand it to them. Bada bing, baby!
The Following User Says Thank You to Easy Gibson For This Useful Post:
Mordekyle (03-04-2019)
Old 03-01-2019, 12:27 PM   #19
Texas Wax's Avatar
Rewards Points: 2,170
What good is that if your not confident enough to avoid something like disconnecting the internet by unknowingly drilling into the dark fiber backbone, hidden in an office partion wall?
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Easy Gibson (03-01-2019)
Old 03-01-2019, 12:45 PM   #20
I like living on the edge.
Some might pop up a ceiling tile or use a pilot bit. Not me. I go right for it. Nail gun. Let the chips fall where they may.
Tall Residential Concrete Foundation Wall Question John 1979 Masonry 8 12-11-2016 03:19 PM
Dead wall sconce box. bob_cntrctr Electrical 5 03-09-2013 06:50 PM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
