Need Help Keeping Nice Lady In A Bathtub From Crashing Into The Dining Room Below... - Carpentry - Contractor Talk
Old 08-10-2010, 07:07 PM   #1
Panzer5's Avatar
Rewards Points: 254
Pictures included...
(of the problem).
Need some creativity / more experience here. After the plumbers got through, I've been left with one top-notched joist with two nearby notches through the bottom 1/3 of the lumber - both within a few inches of each other, the adjacent joist with a gaping notch through the bottom 1/3 of the lumber, etc. They all run directly under the tub...
Situation is a bathroom remodel of a 70-80 YO home. Bath is on the second floor, dining room directly below. Plumbing for the original bath ran part way through the mud bed & tile, partway through the floor joists. Old plumbing was clogged & degraded lead / galvanized & we decided to redo all the plumbing...
The images are taken from below. Joists are 2x8's, partly obscured by the supports for the mudbed. In the first photo, you can see where the original plumbers notched the top and bottom of the joist under the drain. The adjacent joist was similarly bottom notched (obscured by ceiling).
The second photo pretty much speaks for itself.
So the question is - (short of lowering the ceiling) - how can I properly support / buttress these joists to keep the nice lady from falling through the floor the first time she bathes after we finish the remodel?
I've looked at Simpson's website, but can't figure out which strap(s) I need to fix the problem...
Other suggestions appreciated!
Need help keeping nice lady in a bathtub from crashing into the dining room below...-old-plumbing1.jpg   Need help keeping nice lady in a bathtub from crashing into the dining room below...-new-plumbing1.jpg
Scott (the ex-grunt-tanker-jarhead guy)
Panzer5 is offline
Old 08-10-2010, 07:11 PM   #2
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Re: Need Help Keeping Nice Lady In A Bathtub From Crashing Into The Dining Room Below...
Hydrofluoric Acid is certainly out of the question............
+ YouTube Video
http://www.youtube.com/watch?v=LM7Vsg_7WkU
Ultimate Wisdom---------
MALCO.New.York is offline
Old 08-10-2010, 07:24 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,498
You needed a plumber that didnt take the easy route.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 08-10-2010, 07:32 PM   #4
Too bad there wasn't a plan
before the joist were completely destroyed.
I'd start by tearing out the plumbing.
Then restructuring the joist.
Then routing the plumbing over,
or at least near the wall.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
thom (08-11-2010)
Old 08-10-2010, 07:33 PM   #5
iHandy's Avatar
Trade: (reformed) Small Projects Contractor
Rewards Points: 75
No strap will fix this problem.
Sister the joists
Re-routing makes sense. Can the drain go down through the wall cavity? If not, then a bulkhead...
Last edited by iHandy; 08-10-2010 at 07:36 PM. Reason: add more useful information
iHandy is offline
Old 08-10-2010, 07:52 PM   #6
Panzer5's Avatar
Rewards Points: 254
Yeah, I figured as much.
I'd looked at these ( metwood reinforcers but they're all for those with the forethought...
I'd left instructions for the plumber that any cuts he made needed to be properly reinforced - but didn't expect what I got (this all happened while I was off site on another install). I just about lost it when I saw this.
I'm having them pull the drainpipe anyway - since it has ZERO fall. I guess I can try to fix this with something like the metwood reinforcers.
* Sistering won't work - already rejected that - because the sisters would be identically weak.
Panzer5 is offline
Old 08-10-2010, 07:54 PM   #7
alboston's Avatar
Rewards Points: 680
I agree on the above comments, cut out plumbing, sister in new joists and reroute plumbing. The plumber should know better.
alboston is offline
Old 08-10-2010, 08:01 PM   #8
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,262
I agree with sistering the joists. Pipe should be re-done and placed in the center of the joist too. Notch in top looks too big which would be a code violation, check your code book.
KennMacMoragh is offline
Old 08-10-2010, 08:02 PM   #9
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Why can't the drain go in the wall next to the trap?
Gus Dering is offline
Old 08-10-2010, 08:08 PM   #10
Panzer5's Avatar
Rewards Points: 254
There is no internal wall below the trap. It would have to go down the exterior wall, which is uninsulated. While I'll admit I am not as well educated on plumbing issues as I should be, I've always heard that plumbing in an exterior wall in a freezing zone is a no-no. (Although, since water doesn't stand in the drain pipe - I guess it wouldn't be as problematic as if the supply were there...).
Panzer5 is offline
Old 08-10-2010, 08:12 PM   #11
Panzer5's Avatar
Rewards Points: 254
Re: sistering;
I'm okay with sistering the joists - so long as we can re-route the drain pipe. But sistering around the problem won't work. I don't even mind them re-running water service through after I sister the joists with whole lumber - so long as they don't drill through the bottom 1/3 of the joists.
But see the above comment; the only other route for the drain is down the outside wall...
Panzer5 is offline
Old 08-10-2010, 08:17 PM   #12
Remodeling GC
kevjob's Avatar
Rewards Points: 2,084
I hope you didn't pay the plumber. They are requried to know how and where to drill the joists. unbelievable.
kevjob is online now
The Following 3 Users Say Thank You to kevjob For This Useful Post:
dprimc (08-12-2010), thom (08-11-2010), Tom M (08-10-2010)
Old 08-10-2010, 08:19 PM   #13
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
Wow!!!
First, boots won't fix that. 2nd, those guys aren't licensed. Anyone can buy a crimper at home cheapo and call themselves a plumber. All the plumbers I know use expandable aqua pex. Those holes for the pex are uneven, fine. But their on the bottom 3rd of the joist. And is that a 3 1/2" hole for 1 1/2" pipe. 2 7/16" is really the max hole size for 2x8's, but you don't even need more than 2 1/8" tops. It doesn't look like it will drain either.
Definitely sister up some joists. And fire them and get someone else. Really should of fixed the joists first.
Guilford, CT Remodeler and Carpenter Web-site [email protected]
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 08-10-2010, 08:21 PM   #14
Gus Dering's Avatar
If it was so cold out that the water draining from that tub froze harder than a honeymoon peter, I'd say there will be bigger fish to fry.
Plus you would have the chance to get some insulation in there when it's open, right?
Old 08-10-2010, 08:23 PM   #15
Mike Finley's Avatar
Trade: Bathroom Remodeling
You need to get another plumber from craigslist.
Anybody who penetrates a joist should know the code, there is no excuse of "I'm just a plumber, or I'm just an electrician", if you are going to penetrate joists and studs you better take responsibility for doing it right.
What a mess that is.
Mike Finley is offline
The Following 2 Users Say Thank You to Mike Finley For This Useful Post:
MAD Renovations (08-10-2010), olligator (08-11-2010)
Old 08-10-2010, 08:25 PM   #16
I like Green things
We always used to say stiffer then a wedding d*ck.
Warner Mill Works
Facebook
YouTube
Old 08-10-2010, 08:25 PM   #17
Rewards Points: 538
could build a chase
Facebook
Old 08-10-2010, 08:28 PM   #18
Professional Instigator
rbsremodeling's Avatar
There is actually a bracket made for that.. I can not for the life of me remember who makes it..
It has the notch for the pipe and nails to the bottom of the joists..
I thought I saw a picture of the product here once before..
rbsremodeling is offline
Old 08-10-2010, 08:29 PM   #19
Panzer5's Avatar
Rewards Points: 254
At this point, I wish I'd gotten these guys from craigslist. Then I could just punch myself in the head for being stupid.
Silly me, I went with a large, respected (& well insured) company in town. Service manager is easy to get along with - and responsive - but it seems the guy he sent is a hack. He's definately not coming out on any future jobs.
Panzer5 is offline
Old 08-10-2010, 08:33 PM   #20
Large plumbing company smells like a service company, do they spend most of their time snaking drains and such? That would explain a lot.
Heating new Family Room w/ gas fireplace? Slowtrawl HVAC 56 06-20-2010 05:50 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
Dining Room Fixture CPETRO Electrical 10 11-25-2007 11:01 PM
Dining room ceiling fan jbfan Electrical 39 08-20-2007 08:08 PM
Creating new dining room Floorwizard Flooring Picture Post 5 11-18-2003 06:12 PM
