Looking For A Smart Ass - Carpentry - Contractor Talk
Old 05-21-2010, 07:04 AM   #1
mutley's Avatar
Trade: carpentry
hi im looking for a way to hang a mantle to a rammed earth fire place
its about 6' 6'' long 10'' deep and 7'' thick its a rustic peice of jarrah with a wavy edge
other than drilling a hole and inserting chemical anchor into the rammed earth and then trying to align it up to corresponding holes in the back of the mantle i cant think of a better way right now
this sucker ways 130lbs i put it on the bathroom scales
thanks in advance for any ideas
ps rammed earth is quite soft and she who must be obeyed dose not want brackets or chains
mutley is offline
Old 05-21-2010, 08:00 AM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 17,559
Re: Looking For A Smart Ass
She who must be obeyed needs to make a decision. To have or not to have a mantle. If you shoot down the only viable option, the anchor, and she wants no brackets or fasteners showing and you can't glue it. Maybe just lean it up against it and tell her to be careful it doesn't tip over and crush her while shes cleaning it.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
SAH (05-21-2010)
Old 05-21-2010, 09:13 AM   #3
Railman's Avatar
Trade: Railing
Rewards Points: 1,219
"looking for a smart ass "
I can be one when the conditions are right!
The easiest way to do it would be to make a template out of scrap plywood ( or 1x) the same width, & ht as the back side of the mantle.
Then do a hole layout on the template, taking into consideration where the holes will be in the rammed earth. I'm not familiar with rammed earth , but I assume it's very soft, so you may have to use 6 to 8, 12" (12mm?)rebar rods ( or expansion studs?) to support. At 6, each rod would only need to support #20 or so. I would probably stagger the rods from top to bottom, maximizing spacing, so as to not fracture the wall.
Once you do the layout, on the template, fasten the template to wall exactly where you want the mantle. Drill through the template & into the wall. Be sure to label the wall & mantle side of template. Once bored, fasten template to rear of mantle, & bore. All holes need to be square to the mantle, & wall. Set the rods into the wall with the template in place, using machinery grout, being sure to keep rods square to wall. I would probably keep bores a few mm bigger than the rods, in the wall, & into the mantle.
If the rammed earth won't support the 1/2" rods, you might have to install treated wood plugs into the wall to support the rods. Maybe
2" (50mm) diameter plugs would be sufficient?
Just my $.02
Joe
Railman is online now
Old 05-21-2010, 09:24 AM   #4
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
what happens if you extract a section of rammed earth wall and mix the soil with mortar mix, pack it back in. let it set, and then do some sort of pin anchoring to the mantle? Don't know how you would re-pack that stuff horizontally.
it worked great on this recurring mud puddle i had on the sidewalk to curb apron next door. From visitors driving up on the non existent curb and parking. And me making the sweep to back into my driveway. Mixed a bunch of fill with a half bag of mortar mix. Never had that mud puddle form again. Course you cant plant grass there anymore. But my neighbor don't know that. Just looks like dirt.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 05-21-2010, 01:16 PM   #5
YesMaam27577's Avatar
Trade: Small-jobs contractor
Why not use a combination of a router, an angle grinder, and some chisels -- oh, and lots of hours too -- to hollow out the back of the mantle?
That would reduce the weight by maybe 50%, and would also allow for the use of maybe a french cleat, maybe a number of anchors to spread the weight around.
YesMaam27577 is offline
Old 05-21-2010, 09:37 PM   #6
Railman's Avatar
Trade: Railing
After thinking about my previous post, I think the way to go would be to bore some big holes, maybe 2 1/2", in the rammed earth. Then mortar them in with 5/8" (15 to 16 mm?) rod, using the previously mentioned template to hold everything in place while the mortar sets up. Making the holes bigger would give more support surface against the rammed earth. That way, you could get by with only four rods.
Joe
Old 05-22-2010, 05:28 AM   #7
mutley's Avatar
Trade: carpentry
what a great resource this is, just good to get other ideas espesialy if you work alone
i forgot about the french cleat
think ill go with joes last idea
thans again
mike
mutley is offline
Old 06-05-2010, 07:36 AM   #8
SK Remodeling's Avatar
Trade: residential remodeling contractor
Rewards Points: 244
How about drilling 1" holes in the wall and mantle and using 1" dowels and an adhesive
SK Remodeling is offline
Old 06-05-2010, 12:11 PM   #9
Cletus's Avatar
Trade: Tube Installer
Rewards Points: 150
The job is probably done already, but another option is to use an adobe anchor. This is simply three opposing wedges of wood tapped into a hole oriented in such a way that a pulling force on the center wedge increases the wedging effect. Similar to a fox wedged mortise and tenon joint.
Cletus is offline
Old 06-05-2010, 01:49 PM   #10
LRG WoodCrafting
Leo G's Avatar
That is a cool concept Cletus. Awesome.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Smart Vent kpatteri Roofing 12 05-18-2010 07:01 PM
best smart phone case for contractor AustinDB Technology 13 05-04-2010 02:27 PM
thermostats w/ 'smart' technology AustinDB HVAC 5 01-18-2010 04:58 PM
Smart Circle wpc07834 Marketing & Sales 2 07-27-2009 12:48 PM
Smart Contractor Software Sarah9910 Technology 10 06-12-2008 02:34 PM
