Looking To Build A Portable Outdoor Shed, Need Some Suggestions. - Carpentry - Contractor Talk
Old 02-27-2019, 07:57 PM   #1
Learn-Build-Enjoy
ASidhu's Avatar
Trade: Carpentry and Landscaping
Rewards Points: 142
Hi,
I would like to build a shed big enough to store extra plywood sheets, fasteners, tools, etc.
The size I am thinking is 4 feet wide x 10 feet long x 8 feet total height. (4 feet wide works great for where I am planning on placing it)
I need it to be portable without the use of any special equipment.
I was thinking of using some sort of heavy duty caster wheels or similar.
The shed will be located on my side lot that is paved solid with asphalt and therefore do not need to worry about getting stuck in dirt/mud.
The construction method I am planning on using is a typical wood frame house construction with 2x4 wall framing, plywood sheathing, vinyl siding and something solid in the floor framing for the casters to fasten onto.
I haven't built a portable shed like this before and would love some suggestions and tips.
Things to consider:
-What kind of caster wheels to use?
-How many caster wheels?
-Will it tip over?
Thanks.
ASidhu is offline
Old 02-27-2019, 10:54 PM   #2
Mordekyle's Avatar
Rewards Points: 5,592
Re: Looking To Build A Portable Outdoor Shed, Need Some Suggestions.
Enclosed trailer?
I would think a shed would cost a minimum of $1500 for materials, unless you salvaged materials from somewhere. Depending on how you value your time, a couple days to build it might be worth that much as well.
If you put a shingled roof and a sturdy door on it, the weight makes it less and less portable.
$3000 for a used enclosed trailer sounds like a decent solution. Lockable portable dry storage with resale value.
Mordekyle is online now
The Following 5 Users Say Thank You to Mordekyle For This Useful Post:
ASidhu (02-28-2019), Frank Castle (02-28-2019), griz (02-27-2019), MarkJames (02-28-2019), onmywayup (02-27-2019)
Old 02-27-2019, 10:57 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 642
agree with Mordekyle....
buy a enclosed trailer.
more useful, and great resale value.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
ASidhu (02-28-2019), Calidecks (03-01-2019)
Old 02-27-2019, 11:03 PM   #4
TheConstruct's Avatar
Rewards Points: 1,438
I built something like this about 10 years ago to be used in a warehouse to store peoples contents with the intention of building several more eventually. But despite being very conscientious about weight, the thing was still pretty tough to roll around and it didn't have siding or a roof on it. I wouldn't plan on moving it if you build one.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
ASidhu (02-28-2019)
Old 02-28-2019, 07:25 PM   #5
Learn-Build-Enjoy
ASidhu's Avatar
Rewards Points: 142
Thanks for the suggestions.
I will most likely either just buy a used enclosed trailer or build something on a trailer frame.
ASidhu is offline
The Following 2 Users Say Thank You to ASidhu For This Useful Post:
hdavis (02-28-2019), TheConstruct (02-28-2019)
Old 02-28-2019, 09:23 PM   #6
hdavis's Avatar
Rewards Points: 2,152
Of you want to be able to drag it around with a truck, build the base as a sledge. If you want to drag it around by hand, build the base as a sledge and use rollers.
You'd need buckets full of casters, probably a few hundred $ worth.
Lightest weight construction would use fir ply and cedar for joints. Built like a plywood boat or a single wall house. Lightest weight roofing is rubber. PVC, EPDM, whatever. Cheapest is 6 mil poly attached with battens under the eaves. May have to change that every 5 years.
Stick built you can go to 24oc framing. Cedar makes it light but very expensive.
The only downside to building on a trailer is you'll have to deal with the step height.
If you build one, consider it disposable, it isn't going to have much resale value.
hdavis is online now
ASidhu (03-01-2019)
Old 03-01-2019, 05:56 PM   #7
Learn-Build-Enjoy
ASidhu's Avatar
Rewards Points: 142
interesting options there.
I would rather build what I can just for the fun of it and to expand my skill set.
I am looking into just welding something up. It's just a side home project, no rush.
Thanks for the tips.
ASidhu is offline
Old 03-01-2019, 10:33 PM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,998
Build the frame from aluminum square tubing.
Or light guage steel.
Better yet steel studs
Mike.
_______________
Calidecks is online now
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
ASidhu (03-02-2019), hdavis (03-02-2019)
Old 03-02-2019, 02:25 AM   #9
hdavis's Avatar
I like the steel stud idea. I may do that on my next shed.
Old 03-02-2019, 07:27 AM   #10
woodspike's Avatar
Rewards Points: 724
Originally Posted by ASidhu View Post
Hi,
Things to consider:
-Will it tip over?
Thanks.
i get storing tools
but why store plywood , and lumber and fasteners ?
leave them at the supply house till you need them , and get them in perfect shape everytime.
woodspike is offline
The Following User Says Thank You to woodspike For This Useful Post:
Calidecks (03-02-2019)
Old 03-02-2019, 04:26 PM   #11
Learn-Build-Enjoy
ASidhu's Avatar
Rewards Points: 142
Originally Posted by woodspike View Post
i get storing tools
Good point. This is just at my house and I would like to organized my garage up. I usually have some scraps left over from projects. Maybe not full 4 x 8 sheets, but off cuts and sometimes might get a good deal on stuff and need to store a few sheets for later use. Good to have the extra space.
ASidhu is offline
Old 03-02-2019, 04:44 PM   #12
VinylHanger's Avatar
Rewards Points: 11,666
Don't bring things home. Don't bring things home. Don't bring things home..
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
mrcat (03-02-2019), TheConstruct (03-02-2019)
Cost differences to build different styles climb Construction 12 12-21-2016 10:38 PM
Capitol gains on self build? maninthesea Off Topic (Non Trade) 15 12-21-2014 04:37 PM
Submitting and signing estimates and contracts with iPad, suggestions? Roofcheck Marketing & Sales 2 04-15-2013 11:04 AM
Making a Dollhouse Bookcase. Suggestions on paint type and finishing... rdr8887 Painting & Finish Work 9 06-24-2012 10:37 PM
