How Do You Sharpen Your Pencil? - Page 2 - Carpentry - Contractor Talk
Old 03-24-2009, 06:55 PM   #21
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
Re: How Do You Sharpen Your Pencil?
I use a table saw tapering jig to get the rough shape. A couple of passes over the jointer (really fine- don't be too aggressive), then sand it with 60-grit, followed by 100-, 150-, and 220-grit paper. Finally I use a cabinet scraper to remove the fine sanding marks. It sucks when I snap the tip on my first mark and have to start all over...
Jeremy E is offline
Old 03-24-2009, 07:01 PM   #22
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
That all depends upon how sharp her *%^$ is!!!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 03-25-2009, 07:34 PM   #23
ecooke21's Avatar
Trade: Rremodeling..finish carpentry, etc
Rewards Points: 75
Originally Posted by JLTrim View Post
Lately I've been carrying one of these Accuscribes around, has a built-in sharpener, and it's a little cheaper than a cnc machine.
same
A bunch of little rabbit turds banding together usually just makes one bigger piece of crap. -Mike Finley
ecooke21 is offline
Old 03-25-2009, 09:38 PM   #24
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Anything I can find, sandpaper, knife, concrete sidewalk, block plane.
I use #2 pencils for trim.
silvertree is offline
Old 03-28-2009, 08:48 PM   #25
Sasquatch's Avatar
Rewards Points: 150
I like to use my teeth to sharpen pencils. blades not always sharp
"If the women don't find you handsome, they should at least find you handy". - Uncle Red form the Red Green Show
Sasquatch is offline
Old 03-29-2009, 09:00 AM   #26
Ten Fingers's Avatar
Trade: carpenter, builder
Rewards Points: 75
ball point pen if the wood is dry. Utility knife is always in my pocket. Pencil sharpener mounted on the trailer side door.
Ten Fingers is offline
Old 03-29-2009, 09:39 AM   #27
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Typically with a utility knife, but have used a block plane in a jam.
loneframer is offline
Old 03-29-2009, 01:52 PM   #28
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
This is what I do:
http://www.youtube.com/watch?v=rY9YTeiExrk
Takes 7-10 seconds per pencil. This is what the OSS sharpened pencils look like:
basswood is offline
Old 03-29-2009, 05:08 PM   #29
irockwithdirt's Avatar
Trade: Carpentry, Remodeling
Rewards Points: 75
Utility knife most often. I've been known to grab a belt sander if it's close LOL.
Ever seen those pencils with liquid lead? Looks like a yellow #2 pencil, but it's not. They can be good for some fine stuff, but not everything.
irockwithdirt is offline
Old 03-31-2009, 09:16 PM   #30
HSConstruction's Avatar
Rewards Points: 250
man you guys are serious about pencils. If it has a lead showing...good nuff, for framing anyway. I had no idea there were ppl out there drum sanding points and block plane, that must hurt like hell in your bags.
what do I know I am new maybe I will improve my skills if I have a pencil with a pointy point.
you could have the sharpest pencil but in the end the cut man determines the fit.
HSConstruction is offline
Old 04-01-2009, 01:47 PM   #31
Trust but verify
atnas's Avatar
Trade: Instructor & Finish Carpentry
Rewards Points: 25
Originally Posted by john5mt View Post
man things must be slow at the machine shop
I sent this to a friend who is a machinist and he said the same thing!!
If you don't have time to do it right the first time..., when will you have time to do it again?
Klaus Finish Carpentry
atnas is offline
Old 04-01-2009, 06:20 PM   #32
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
I have a pencil addiction....I buy them by the dozens!!!
I've always loved Dixon Ticonderoga pencils. About a year ago I started using the big pencil that kids use. I was replenishing my supply when I found the best pencil ever. Ticonderoga "My First tri-write". They work great for framing, and finish work!!
I fastened a pencil sharpener to the side of my table saw with a couple zip screws.
http://www.instaoffice.com/my-first-....7.htm#gallery
WNYcarpenter is offline
Old 04-20-2009, 06:09 PM   #33
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
wow, some great pencil conversations here, lol.
Anybody here turn away vendors that dont come bearing gifts. I expect pencils but shirts get your business card to the boss...
MattK is offline
Old 04-20-2009, 06:16 PM   #34
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Utility knife here. Watching carpenters write with dull points drive me nuts! I've been known to take a pencil off a guy and sharpen it for him!
-Dennis
WarriorWithWood is offline
Old 04-21-2009, 04:04 AM   #35
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
these are the best...
http://www.amazon.com/Panasonic-Port...JVK4JC5FNQK2N6
m1911 is offline
Old 04-21-2009, 01:49 PM   #36
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Whatever is closest...typically my pocket knife or utility knife. I need a tracking device for my pencils I think I'm up to 3 a day with a 60% recovery rate...they don't even get the chance to get dull.
As a side note I had a friend who is not-so-handy help me out on a job onece and first thing i did was toss him a knife and a pencil and said sharpen it....4 minutes later all I hear is cursing as the pencil has been reduced to 3 inches and still no exposed lead. That marked the beginning of a long day.
Inner10 is offline
The Following User Says Thank You to Inner10 For This Useful Post:
JT Wood (12-01-2009)
Old 04-24-2009, 04:23 PM   #37
GBAR's Avatar
Rewards Points: 25
Framing, a knife, sharpen both ends.
In '75, I was too cheap to buy a wooden keel holder, so I made one. I keep one end in a 3" piece of washing machine hose, keel in the other end. 3 colors of keel plus pencils when doing layout. I don't stop to sharpen as often.
Years ago, I showed that to my mobile nail supplier, a week later his company had similar with logo on. Two months later, all the yards and box stores had their own. I missed on that one!
Trim work, mechanical pencil, one click, sharp. Sharpen pencil per day=6 times x 5 days a week=30 x 1 minute each =30min. x 50 weeks = 25 hours a year ----- you could be earning $$ Be safe, GBAR
GBAR is offline
Old 04-25-2009, 06:51 AM   #38
LC
Boogga's Avatar
Trade: Building
Rewards Points: 344
Stan does it!
oils are back!
Boogga is offline
Old 04-26-2009, 03:26 PM   #39
katoman's Avatar
Trade: carpenter
I need 15 posts before I can post a URL. Just filling in time here. When framing I use a piece of clear tubing to connect blue and red crayons together. Could do this with pencils and only have to go to the sharpener half the time.
katoman is offline
Old 04-26-2009, 10:08 PM   #40
Handle It!
Originally Posted by Boogga View Post
Stan does it!
Stan???
Is that not the guy who drove his car and his biotch off of the bridge?????
+ YouTube Video
http://www.youtube.com/watch?v=KQR6yBwFHQU
Anybody know who sells a cranking carpenter's pencil sharpener? Mike Finley Tools & Equipment 55 12-24-2008 09:03 AM
sharpen your pencil Bone Saw General Discussion 40 08-19-2008 07:51 PM
Pencil me in Trimcat Finish Carpentry 15 04-17-2008 02:54 AM
Best way to sharpen carbide stone chissels michiganmason Masonry 7 01-15-2008 08:45 PM
How often do you sharpen blades? Chris G Carpentry 13 11-04-2007 12:25 PM
