How Do You Secure Half Walls - Carpentry - Contractor Talk
Old 01-17-2019, 01:15 AM   #1
Stunt Carpenter's Avatar
Rewards Points: 2,298
Hey Guys,
Wondering what everyone’s approach to securing half walls on a wood framed floor.
I have two methods that I use.
1. Run end stud through the subfloor and fasten to floor joist or block between two floor joists
2. When the wall sits on a beam making option 1 not possible I have added a metal L bracket to the stud and lag bolted it to the beam.
Wondering what other options are out there. Any new Simpson type products that simplify this ?
https://builddaley.com/
Stunt Carpenter is offline
Old 01-17-2019, 01:26 AM   #2
Ed Hartmann's Avatar
Rewards Points: 266
Re: How Do You Secure Half Walls
I have done option 1 a lot. I have also worked on a lot of homes that had neither done. It leaves a wobbly half wall.
Ed Hartmann is offline
Old 01-17-2019, 10:26 AM   #3
diplomat
Golden view's Avatar
Rewards Points: 674
When over a beam, I've run a metal strap down under the beam and up each side of the end stud of the half wall. Very strong.
If the wall length and height are similar, double top plate it, 2-3x end stud, and glue and screw sheetrock and it will be amazingly stiff, like better than a stud down to the joist. More so if you do the same with plywood. Make sure it's lagged both down along the bottom plate and at the stud next to the full height wall.
Golden view is online now
Old 01-17-2019, 10:32 AM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,022
When doing a half wall in my bathroom I did the #1 way sure makes for a solid wall.
Randy Bush is online now
Old 01-17-2019, 11:11 AM   #5
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 976
Threaded rod from top plate down through beam, or attached to joist with a hanger, like a DTT2Z.
Cinch in down really tight. Obviously, it needs to run right along a stud, and use a large flat washer.
Works OK.
overanalyze (01-18-2019)
Old 01-17-2019, 12:29 PM   #6
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 278
#1 is what I normally see.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Texas Wax (01-17-2019)
Old 01-17-2019, 07:13 PM   #7
90%-er
onmywayup's Avatar
Rewards Points: 2,236
Just failed a rough building inspection twice a couple weeks ago over a partial shower wall that the inspector felt was too wobbly.
Solution eventually agreed upon was to remove the second top plate, turn two 2x4s on their side with a strip of half inch osb between them, run the new 2x4s past the half wall and straight into the adjacent exertior wall and secure them to a stud. Then we ran 3" deck screws in two rows up through the remaining top plate and into the extra long two by fours.
After we skinned the wall with drywall and did all that, thing was stiffer than a virgin's dick.
"Internet Commando"
onmywayup is offline
Old 01-17-2019, 07:39 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Works OK.
It works like sh!t because over time it will pull the wall one direction or the other hinging the bottom plate against the floor.
Inner10 is offline
Old 01-17-2019, 08:23 PM   #9
Tom M's Avatar
Rewards Points: 7,878
I have used all of the methods listed above but I now use a new method.
I use a surface mounted deck post at the corner. Some are slender enough where you can pocket screw 3/4 play around the steel and end up @ a 2x4 width while grabbing a plate and adjoining studs.
Very stiff.
Tom M is online now
Old 01-18-2019, 09:53 AM   #10
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,100
It's never a bad idea to put a little 90 degree return at the end of a half wall to help stiffen it up if possible.
Fishindude is offline
Old 01-18-2019, 10:44 AM   #11
hdavis's Avatar
Rewards Points: 1,854
Any method for installing Newell posts and any method for stiffening walls helps.
I've seen them plenty solid, but just attached to the subfloor, not the framing. Worked fine next to a front load washer until the spin cycle hit wall resonance, then it would shake like crazy.
hdavis is online now
Old 01-18-2019, 12:00 PM   #12
builditguy's Avatar
Rewards Points: 1,956
Have done all of those in the different circumstances.
On a concrete slab, we have been welding up a rectangular box out of 2" square tube. We bolt the steel rectangle to the floor and then screw the wall to the steel box. We've only done this on metal framing, but wood should work also.
It has worked very well, for us.
builditguy is offline
Old 01-18-2019, 07:06 PM   #13
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 832
Not a half wall but a newel mount.
Big Johnson is offline
hdavis (01-22-2019)
Old 01-22-2019, 06:06 PM   #14
BillD's Avatar
Trade: General contractor
Rewards Points: 424
If the wall ends on a beam or is on a concrete slab I use what several local suppliers call a "low wall support bracket". Mostly used for steel studs but they work great for wood also.
It is a piece of steel channel about 1-1/2"x3"x1/8" thick welded to a base plate with a couple of holes for mounting. I don't have a pic but here is a drawing. The plate is closer to the size of the channel than my drawing shows.
Bill
BillD is offline
Old 01-22-2019, 10:25 PM   #15
Trade: Highwayman
Rewards Points: 976
Then don't use the method.
I've never done one like that, but I've removed a few, and they weren't wobbling.
Floor first or walls first agcinc General Discussion 5 04-01-2015 05:16 PM
permits to remove kitchen half walls in condo? NJ WaltWillysmooth Demolition 23 11-08-2014 01:59 PM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
Sagging floors, over spanned joists, load bearing walls without support and more technique Remodeling 104 05-14-2010 04:16 AM
Covering block walls? barefootbuilder Remodeling 6 03-15-2010 01:28 AM
