Hidden Door - Carpentry - Contractor Talk
Hidden Door
Old 01-04-2010, 11:50 AM   #1
Carpenter
woodbutchr's Avatar
Rewards Points: 150
Hidden Door
I have to build a hidden door to an upstairs attic/bedroom in a very old house. When you open the door you are immediately going to land on the first step so I gotta make the door around 87" tall to get as much headroom from that first step as I can.
The kicker is I gotta use 6" beadboard on the horizontal as the facing. The wall is 7' long & I have a 32" door in the middle of it so there's gonna have to be a couple butt joints in the BB. I need some baseboard also which will interfere with the opening clearance unless I use a pipe hinge as it was done here http://www.woodworkingcorner.com/hiddendoor.php
I'm thinking about a 3/4" piece of ply with the BB nailed to the face? How am I gonna hide the butt joints?
woodbutchr is offline
Old 01-04-2010, 12:11 PM   #2
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
Re: Hidden Door
Panel the entire wall and make one of the panels hinged.
reveivl is offline
Old 01-04-2010, 12:29 PM   #3
genecarp's Avatar
Rewards Points: 2,000
Re: Hidden Door
The applicatio you describe will not let you hide the baseboard butt joint, can you build a narrow bookshelf on the wall that opens? Even an 8'' deep shelf unit will let you completely conceal. GMOD
genecarp is offline
Old 01-04-2010, 01:30 PM   #4
Carpenter
woodbutchr's Avatar
Rewards Points: 150
Re: Hidden Door
The area is in the kitchen so do ya think a bookshelf will look outta place? If I put any kinda shelf on the door, that will move the pipe hinge further toward the center of the door to accommodate the swing, right? With a 32" door, I don't have much room.
Thinking more about it now, if I don't have room between the door and 1st step for a pipe hinge to swing I may have to raise the door up to the top of the step & that'd let me run the base full length with having to incorporate it into the door itself.
Just gotta hide the joints! I'm waiting on her to get back with me on running the BB vertically. That would make it all elementary.
Old 01-04-2010, 03:18 PM   #5
Cjeff's Avatar
Trade: Renovations
Re: Hidden Door
Some sort of shelving unit, or even a decorative panel/artwork. Any chance of pictures?
A booksehlf/display shelf can look good in a kitchen. Can you recess it into the wall?
Cjeff is offline
Old 01-04-2010, 06:06 PM   #6
gregj's Avatar
Rewards Points: 150
Re: Hidden Door
Go with a "built in" bookshelf recessed into the wall. It will look like it belongs in the kitchen. The face frame hides everything. Make it around 6-8" deep with the bottom just high enough that it passes right above the first step when closed. Hopefully that is high enough to be above the baseboard. Extend the first step all the way to the face so there's no gap between the step and the wall. (this might make the first step out of code because it's a different depth but otherwise you'll have a joint in the baseboard that will scream "Door here!".
BTW that door in the link is not what I'd call hidden. One glance and it's obvious that it's a door.
gregj is offline
Old 01-04-2010, 06:12 PM   #7
Carpenter
woodbutchr's Avatar
Rewards Points: 150
Re: Hidden Door
Thanks Greg, that's exactly what I'm trying to talk her into at this time.
Old 01-04-2010, 06:12 PM   #8
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Re: Hidden Door
make sure and post some b4 and after pics
Anderson is offline
Old 01-04-2010, 06:32 PM   #9
Atlanta Remodeling
bdoles's Avatar
Trade: Home Repairs and Remodeling
Rewards Points: 154
Re: Hidden Door
Here's a few photos from a house I recently worked in. I didn't build/install the bookcases, so no details from my end.
bdoles is offline
Old 01-04-2010, 06:42 PM   #10
BillD's Avatar
Trade: General contractor
Rewards Points: 424
Re: Hidden Door
I agree with gregj.
Trying to put a "hidden door" in a wall that has horizontal finishes does not work. I've been asked to hide doors when doing home theaters and the term "hidden door" is subjective. Some people are happy to make it less noticeable than a regular door and others want it to disappear.
Good luck, and I'd like to see the finished product as well.
Bill
BillD is offline
Old 01-05-2010, 07:34 AM   #11
Carpenter
woodbutchr's Avatar
Rewards Points: 150
Re: Hidden Door
Thanks y'all for your input. She has had some unexpected college expenses to come up so this little project is on hold for awhile.
This economy sucks!
Garage Security... DCPP General Discussion 4 11-22-2009 12:36 PM
Door install hell - customer angry HellisLikeNewrk General Discussion 17 06-04-2008 09:40 AM
Altering an interior hollow core door Painter James Windows, Siding and Doors 2 12-30-2007 07:24 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
