Hanging Cabinets With Metal Studs - Carpentry - Contractor Talk
Old 05-17-2012, 05:08 PM   #1
Remodeler
mike d.'s Avatar
Trade: Professional Remodeler
Rewards Points: 298
I was wondering,, Is procedure for hanging wall cabinets to steel studa the same as wood studs? Do you use a fine thread screw?
mike d. is offline
Old 05-17-2012, 06:40 PM   #2
GRB's Avatar
Trade: Carpentry Contractor
Re: Hanging Cabinets With Metal Studs
Is the wall open or finished? If open, install solid lumber blocking horizontally between the studs & secure the cabinets to that as you normally would.
If you have to fasten to the studs, use screws designed specifically for the application. Do not use drywall screws, as they have no tensile strength & may fail in a shear application. BTW - we use trim washers with the above screws for a more finished appearance.
GRB is offline
Old 05-17-2012, 06:41 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
well well well lookie what the cat dragged in
Tom Struble is offline
Old 05-17-2012, 06:44 PM   #4
GRB's Avatar
GRB is offline
Old 05-17-2012, 06:57 PM   #5
slowsol's Avatar
Rewards Points: 2,248
If I can't install plywood backing, I use toggle bolts. In every stud.
-John
slowsol is offline
Old 05-17-2012, 07:37 PM   #6
MLCcarpenter's Avatar
Trade: Commercial Carpenter
Rewards Points: 85
Install 6" 20 ga backing strips at the top and bottom of cabinet location and use self tapping screws when installing cabinets. You can pick them up at your local drywall supplier.
MLCcarpenter is offline
Old 05-17-2012, 07:38 PM   #7
Rewards Points: 85
Also if plywood or 2 bys are used more than likely fire treated lumber will be required.
Old 05-17-2012, 08:43 PM   #8
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 512
I also attach fire treated 2x's in the studs. I'll cut out the drywall if it's there, install my backers, and either re-attach the drywall, or use the same thickness ply. The cabs cover the patch, so it's no biggie.
KnottyWoodwork is offline
The Following 4 Users Say Thank You to KnottyWoodwork For This Useful Post:
chris klee (06-07-2012), go dart (06-08-2012), Old Grumpy (05-17-2012), WarriorWithWood (06-24-2012)
Old 05-17-2012, 08:52 PM   #9
Holy Crap!
ROVACON's Avatar
Trade: General Contracting-Renovations-Carpentry
Rewards Points: 296
http://www.danback.com/
This is what we use.
Brian
ROVACON is offline
The Following User Says Thank You to ROVACON For This Useful Post:
Old 05-17-2012, 09:27 PM   #10
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Ive done that in the past to hang heavy jewlery display cabinets..
Just screwed the flat stock on the face of the drywall into the studs and the cabinet hides it.
And of course you can cut the drywall out and install the flat stock and patch and hang on that
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 05-18-2012, 08:41 AM   #11
Tom M's Avatar
Rewards Points: 3,534
For those of you who do this often I have a question.
I installed wood blocking in between the studs a few times at best and when I did I use a hand seamer metal bending tool to flatten the stud rollover so my blocking laid nicer.
It obviously worked okay but I wonder how much strength was lost by doing it. Is there a better technique?
Tom M is online now
Old 05-18-2012, 08:54 AM   #12
packer_rich's Avatar
Trade: unemployed carpenter
Rewards Points: 346
I always cut a kerf in the backing material to avoid weakening the stud.
packer_rich is offline
The Following 7 Users Say Thank You to packer_rich For This Useful Post:
Builderbob 72 (05-20-2012), chris klee (06-07-2012), KnottyWoodwork (05-18-2012), slowsol (05-18-2012), thecabinetguy (06-14-2012), Tom M (05-18-2012), WarriorWithWood (06-24-2012)
Old 05-18-2012, 09:10 AM   #13
Tom M's Avatar
I like that, probably the same effort in the end and safer.
Tom M is online now
Old 05-18-2012, 09:18 AM   #14
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
these work great and are firetreated
iDAHOchris is offline
Old 05-18-2012, 12:05 PM   #15
Dirtywhiteboy's Avatar
Rewards Points: 10,144
I just screw to the studs
Hanging Cabinets with   metal studs-img_2130-1-.jpg   Hanging Cabinets with   metal studs-img_2131-1-.jpg
Dirtywhiteboy is online now
Old 05-18-2012, 06:51 PM   #16
Rewards Points: 512
I just set up the table saw with the dado blade, and go for it.
Old 05-20-2012, 10:06 PM   #17
3bar's Avatar
Trade: carpenter
Rewards Points: 492
toggle bolts in studs
3bar is offline
Old 05-21-2012, 10:54 PM   #18
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,108
Use a screw, if its a really heavy sucker use quarter inch zip toggles.
Inner10 is online now
Old 05-21-2012, 10:56 PM   #19
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,584
I never once thought about using a metal stud to hang a cabinet..........
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 05-21-2012, 11:32 PM   #20
Hardly Working's Avatar
Rewards Points: 812
We did a Ferguson showroom that way. They ran the flat stock to the studs prior to putting the drywall up and it worked great. The sheet rock helps keep the flat stock secure. 15 mock kitchens and solid as a rock.
Hardly Working is offline
Hanging Cabinets on Metal Studs Bummie Commercial Construction 24 03-24-2013 12:23 AM
shelf supports into metal studs cleveman Carpentry 17 04-17-2012 12:34 PM
Mounting Flat Panel TV to wall with Metal Studs plazaman General Discussion 40 12-25-2011 11:20 AM
Cabinets faceframe coming off... ApgarNJ Finish Carpentry 9 10-28-2011 06:50 PM
Insulation clips for metal studs. festerized Insulation 6 09-15-2010 04:34 AM
