Ground Level Deck Framing - Carpentry - Contractor Talk
Old 09-26-2012, 07:01 PM   #1
Nside's Avatar
Trade: Residential Remodel
I posted an intro quite a while ago, but I hadn't been on in a while. I'm a residential renovation contractor in the Atlanta area. We do a wide variety of renovation work, primarily remodel and fix-up "stuff".
I've been scratching my head with a ground level deck design. I can't seem to get myself to understand how to frame it without having ground contact with the PT lumber. It's a level lot so excavating, even a little, will cause drainage issues underneath. There's only room for a
2x4 joist and 5/4 board for the deck. The only solution I can come up with is to pour a slab on the entire area and lay the 2x4's directly on that. There must be a better way to do it to meet code requirements, but I've burned enough brain cells trying to figure it out. I come to the brilliance of this forum for suggestions. Any help would be greatly appreciated.
Nside is offline
Old 09-26-2012, 07:16 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, decks, additions
Rewards Points: 14,222
Re: Ground Level Deck Framing
I smell a HO
A&E Exteriors is online now
Old 09-26-2012, 07:24 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Options:
1. Built deck higher with a step up to the deck from the yard or door.
2. Pour a slab.
3. Use hardscaping instead.
RobertCDF is offline
Old 09-27-2012, 05:01 AM   #4
Nside's Avatar
Thanks Robert. The step-up might be the answer. I've built several decks over the years but none at ground level. It had me stumped.
Nside is offline
Old 09-27-2012, 05:44 AM   #5
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
So are going to pour concrete?
ohiohomedoctor is offline
Old 09-27-2012, 05:27 PM   #6
Nside's Avatar
I'm going to propose the step-up option. Exit the door at level then raise the rest of the deck a step higher. That will leave room under the joists the keep the code officials happy.
Nside is offline
Old 09-27-2012, 11:23 PM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 744
Why don't you suggest colored and stamped concrete?
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
confused about framing a second story deck with a roof dvatt Framing 12 05-21-2012 10:34 AM
First ground level deck...need advice please!! steelhumm Decks & Fencing 23 05-12-2009 08:55 PM
ground level deck Tom M Decks & Fencing 3 07-02-2007 08:38 PM
