Got My First Cordless Paslode Framing Nailer Today! - Carpentry - Contractor Talk
Old 09-13-2011, 11:07 AM   #1
CJ21's Avatar
Rewards Points: 702
I got my paslode framing nailer today, I need to clean it up. I think this might be a Made in USA model.
CJ21 is offline
Old 09-13-2011, 08:01 PM   #2
WildWill's Avatar
Rewards Points: 504
Re: Got My First Cordless Paslode Framing Nailer Today!
That looks pretty cool!
Hey the trimmer that we were talking about is the IM250 II
WildWill is offline
Old 09-13-2011, 08:03 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
That looks to be in decent condition. Hopefully the internals are in good shape.
loneframer is offline
Old 09-13-2011, 08:26 PM   #4
CJ21's Avatar
Rewards Points: 702
Cool Will, Hey so far It works. I charge the battery and I got a green light. I cant fired it because I dont have any fuel cells. I think I am going to order Paslode cleaning products to give it a good cleaning before I start using it.
CJ21 is offline
Old 09-13-2011, 08:47 PM   #5
KemoSabe
loneframer's Avatar
I would try it first, to rule out possible self inflicted damage.
get fresh fuel, prime it a few times by depressing the nose-piece and releasing, then give it a shot. Make sure it'll fire before you open it up. A few shots won't hurt it if it's dirty.
If you want to clean it after you try it, at least you'll know it's your fault if it misfires after you put it back together.
Old 09-13-2011, 08:50 PM   #6
doncando's Avatar
Trade: carpentry and painting
Rewards Points: 25
Are you, or someone else, looking for the Paslode IM250?
I have one that I don't need and I'd like to find it a new home for a very reasonable price.
doncando is offline
Old 09-13-2011, 08:57 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 1,762
Hey CJ, Good Luck & have fun...
griz is online now
Old 09-13-2011, 09:01 PM   #8
CJ21's Avatar
Rewards Points: 702
Thanks loneframer, I will try that. The Operating Manual says it takes cliphead nails? Is that true? Or could I use the Palsode 30 degree off set framing nails?
CJ21 is offline
Old 09-13-2011, 09:03 PM   #9
KemoSabe
loneframer's Avatar
How reasonable? I run a shelter for unwanted fastening equipment.
The Following User Says Thank You to loneframer For This Useful Post:
woodworkbykirk (09-14-2011)
Old 09-13-2011, 09:05 PM   #10
KemoSabe
loneframer's Avatar
I might be wrong, but I think the offset rounds are designed to run through all Paslode guns. I don't think Paslode offered the offset rounds when that gun went into production.
Old 09-13-2011, 09:36 PM   #11
Fire up the BBQ
griz's Avatar
A shelter or a hoarder
griz is online now
J F (09-14-2011)
Old 09-13-2011, 09:37 PM   #12
CJ21's Avatar
Rewards Points: 702
I dont think so, I will have to check with my local building code to see if they allow cilp head nails.
CJ21 is offline
Old 09-13-2011, 10:12 PM   #13
doncando's Avatar
Rewards Points: 25
Wow, well at least I know it won't be lonely.
I was thinking $100, but I have to check out the battery and charger because one or the other may not be working.
I know the gun works because I put the battery in from my newer Paslode.
I'll be away for 4 days after tomorrow. If you're interested, you can email me at doncando @ verizon . net
doncando is offline
Old 09-13-2011, 10:32 PM   #14
CJ21's Avatar
Rewards Points: 702
I may be inserted as well.
CJ21 is offline
Old 09-14-2011, 12:08 AM   #15
Dirtywhiteboy's Avatar
Rewards Points: 14,562
I used to have that gun and it took cliphead nails
Edit==I stand corrected see below
Dirtywhiteboy is offline
Old 09-14-2011, 02:51 AM   #16
jamesdc's Avatar
Rewards Points: 75
Congrats on the new toy, don't let what everyone else was saying in the other thread put you down. You made a decent purchase on a good gun that will work great as a starting framer. The older black paslode guns got a bad rap because the paslode reps were trying to push them into a production environment where they had no chance of keeping up, in speed or reliability. They are a little finicky but at least you got a gen 2 IM325 which is the last black gun before they switched to the orange ones so it has slightly revised internals. The newer orange guns like the 900420 will downright smoke the IM325 in speed and productivity but at a much higher cost. Plus there is something to be said about the build quality of the older guns, everything was machine screws with washers and nuts instead of screws into plastic. To this day I am still running 2 of the Im325 positive placement guns with no problems at all. I service quite a few of the older paslode guns so I'd be happy to answer any questions you may have. Also the Im325 shoots the offset round head nails fine so throw away those clipped heads.
As for the cleaning start with the battery contacts. I've had many of these guns come to me not working simply because the battery contacts had a little corrosion from leaving the battery in there. Make sure the battery's are drained of a charge and clean the contacts with a wire brush, next are the ones on the gun. To access the battery contacts on the gun you must fully disassemble the magazine and you'll find them. Its basically a spring inside a spring, I usually use a dremel with a wire wheel to clean the surface of the contacts. You also want to clean the contacts on the top of the magazine that feed the gun and the ones on the gun housing too. After that you can start on the regular gun cleaning, if you follow the paslode cleaning procedures manual it will do a fairly good job but won't get it perfect. I recommend tearing the gun down completely and doing a full service since its an older used tool. If you need help with this I can guide you through it, its fairly easy but requires moderate mechanical ability. Once you get the gun serviced and dialed in grab some fresh fuel cells and get to work!! I recommend keeping a few extra upper seal rings around because its good to replace it after every service or 2. The only thing your probably going to have to replace in that kit is the charger, those older black chargers are crap and never work right. The batteries are probably OK and if not you can get new ones on ebay pretty cheap.
jamesdc is offline
The Following User Says Thank You to jamesdc For This Useful Post:
CJ21 (09-14-2011)
Old 09-14-2011, 02:23 PM   #17
CJ21's Avatar
Rewards Points: 702
Ok thanks James, I was thinking the new offset nails would work.
CJ21 is offline
Old 09-14-2011, 07:21 PM   #18
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
riz, you say its a center for unwanted fastening equipment, i think i have some sleeping space for a impulse 18 gauge and 16 gauge, plus 2 hitachi air spikers
woodworkbykirk is offline
Old 09-17-2011, 03:26 PM   #19
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
Got my first paslode today, too.
Sheathing stapler (we are allowed here, so one one go off ranting )
My internet classified searching has paid off. The gun let me run a rack of staples through 'er. Runs good.
Brutus is offline
Old 09-17-2011, 03:32 PM   #20
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
The offset nails are ment to run through all 30 degree clipped head guns. They were released so you could keep your clipped head nailers yet work in areas that only allow FRH
TBFGhost is offline
Paslode Cordless Nailer NRV2 Tools & Equipment 19 03-25-2012 12:29 PM
Do anyone have a Paslode 900420 Cordless IMCT Framing Nailer for sale? CJ21 Contractor Swap 3 07-29-2011 08:43 PM
makita cordless framing nailer framer dude Tools & Equipment 4 08-15-2010 02:31 PM
problems with paslode framing guns/cleaning platinumLLC Tools & Equipment 7 07-09-2009 06:38 PM
Paslode 16 gauge Straight Finish Nailer For Sale JPV123 Contractor Swap 0 02-22-2009 06:56 PM
