FRP - Adhesive On Wall Or Board ? - Carpentry - Contractor Talk
Old 09-27-2018, 06:10 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,410
Have about 14 sheets FRP to do tomorrow. Remodel restaurant build out. Pretty straight forward.
Adhesive on the wall or back of the panel ? What are you guys doing ?
Steve
We Fix Houses is offline
Old 09-27-2018, 07:46 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,030
Re: FRP - Adhesive On Wall Or Board ?
I've only done it and seen it done with adhesive on panel.
griz is online now
We Fix Houses (09-27-2018)
Old 09-27-2018, 07:58 PM   #3
I've done it both ways. Been a good while...just want to re-up a bit.
Steve
Old 09-27-2018, 08:22 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 718
On the wall. That way you don't get your fingers all gooey.
Well, in theory anyway.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
B.D.R. (09-30-2018), Calidecks (10-29-2018), TheConstruct (09-27-2018)
Old 09-27-2018, 08:34 PM   #5
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 162
Never did panel - always the wall
So looks like a fun little tie - shoot what do the directions state?
SLSTech is offline
Old 09-27-2018, 08:57 PM   #6
AustinDB's Avatar
Rewards Points: 1,474
on the wall-easier to use the alignment point (last sheet/corner, etc)
AustinDB is online now
Old 09-27-2018, 08:58 PM   #7
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
paper
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Jay hole (09-27-2018)
Old 09-27-2018, 09:22 PM   #8
Fire up the BBQ
griz's Avatar
pretty sure if you RTFD/specs adhesive is to be applied to panel.
if specs/instructions do not matter PTFO....
should there be a warranty claim for whatever reason, and it is shown you did not follow directions, you will likely be buying and installing new FRP on your dime....
griz is online now
Caleb1989 (09-27-2018)
Old 09-27-2018, 09:45 PM   #9
Caleb1989's Avatar
Rewards Points: 394
Make sure to space it for expansion inside the couplings and trims.
I have always applied adhesive to the panel with a notch trowel, leaving it back from the edge about an inch so you donít get fingers messy. Then a vinyl roller over the whole sheet to press in the glue.
-Caleb
John 3:16
Caleb1989 is offline
The Following User Says Thank You to Caleb1989 For This Useful Post:
rescraft (09-28-2018)
Old 09-27-2018, 11:05 PM   #10
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,440
MESH.
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
SmallTownGuy (09-27-2018)
Old 09-27-2018, 11:06 PM   #11
Fire up the BBQ
griz's Avatar
Ford....
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
fjn (11-03-2018), SmallTownGuy (09-27-2018)
Old 09-28-2018, 03:00 PM   #12
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,176
Notched trowel on the wall. Only way I've ever seen it done.
Fishindude is online now
The Following User Says Thank You to Fishindude For This Useful Post:
sparehair (10-01-2018)
Old 09-28-2018, 04:31 PM   #13
90%-er
onmywayup's Avatar
Rewards Points: 2,282
Yeap. Snap a level chalk line on the wall, then put glue on up to within a half inch of it or so.
onmywayup is offline
Old 09-29-2018, 10:18 AM   #14
Anyway...vertical 9 ft panels. Put adhesive on the panel. Worked out pretty good.
Finish up today.
Steve
Old 09-29-2018, 08:39 PM   #15
Thanks for the input.
I volunteered my labor at this small restaurant build out.
They will be hiring mostly folks with autism and intellectual challenges. It's a coming trend in the biz, coffee shops, etc.
The owner was an exec. asst for a restaurant co. -- got me from CL during the bad times. Did a good bit of work for them. She's on her own now...so give back a bit during good times.
Steve
The Following 2 Users Say Thank You to We Fix Houses For This Useful Post:
hammer7896 (09-29-2018), sparehair (10-01-2018)
Old 10-28-2018, 12:06 AM   #16
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,990
It was on the panels 95% + of the time.
Mostly because it was easier.
B.D.R. is offline
Old 10-29-2018, 12:12 AM   #17
GC/carpenter
Calidecks's Avatar
Rewards Points: 6,320
I put the adhesive on the wall when I built my dogs shower.
Mike.
_______________
Calidecks is offline
Robie (10-29-2018)
can any one id this wall sensor HUDSONVALLEYEXT General Discussion 8 06-15-2012 07:20 AM
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 03:30 PM
Best way to clean adhesive off wall? shanekw1 Painting & Finish Work 4 10-28-2010 09:06 PM
Insulation Board at Foundation Wall Mitch M Insulation 6 10-21-2010 10:36 PM
vertical wall board mics_54 Drywall 11 09-26-2009 04:58 PM
