Fixing Knot Hole - Carpentry - Contractor Talk
Fixing Knot Hole
Old 03-06-2019, 08:26 PM   #1
Stunt Carpenter's Avatar
Rewards Points: 1,800
Fixing Knot Hole
Hey Guys,
I have a barn door that I installed a few weeks back that has had a knot fall out.
The door is alder and was acclimatized before finishing to try and prevent this from happening.
Whatís the best was to fix it now?
Do I need to remove the finish and then fill the hole?
Thanks
https://builddaley.com/
Stunt Carpenter is offline
Old 03-06-2019, 11:45 PM   #2
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,976
Re: Fixing Knot Hole
clear epoxy ? What results are you looking for
JFM constr is offline
Old 03-07-2019, 12:14 AM   #3
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,333
Epoxy it back into place, sand to level finish, and recoat with what you used originially. Good luck!
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
pinwheel (03-07-2019)
Old 03-07-2019, 12:30 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,666
depending on the looks, a little super glue may work wonders....
griz is offline
Old 03-07-2019, 09:29 AM   #5
Either way it sound like Iím refinishing a portion of the door.
The knot is mia now so the entire hole will need to get filled in
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 03-07-2019, 10:07 AM   #6
hdavis's Avatar
Rewards Points: 3,984
I always fill first and then remove finish. It keeps sanding of the wood to a minimum, the finish will help protect the existing.
hdavis is offline
Old 03-07-2019, 07:29 PM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 794
Tint wood bondo with dye & sand flush & finish.
pinwheel is offline
Old 03-08-2019, 05:02 PM   #8
builditguy's Avatar
Rewards Points: 1,394
The flooring guys have a kit for repairing hardwood floors. Has multiple colors and a heating iron. They can melt a putty and press it in the bad area.
Might be an option.
I would try to fill it with epoxy and sand smooth.
An old timer always told me to use sawdust and glue. We did many like that. I always thought it looked like crap.
builditguy is offline
Old 03-08-2019, 06:49 PM   #9
rescraft's Avatar
An old trick--mix coffee grinds w/epoxy and fill/sand/finish.
rescraft is offline
concrete into a hole, no access to pump bruno12345 Concrete & Paving 3 08-18-2013 03:28 PM
Haying foundation hole Upchuck Excavation & Site Work 18 03-30-2013 09:23 PM
Let me explain this and tell me if I'm wrong Dustincoc Electrical 9 03-18-2013 10:48 PM
Post hole nightmare Jer Decks & Fencing 11 10-19-2011 10:02 AM
1" to 2" countersink hole in precast concrete see spot run Tools & Equipment 4 10-11-2011 04:15 AM
