First Stringers - Page 3 - Carpentry - Contractor Talk
First Stringers
Old 01-21-2012, 09:40 PM   #41
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: First Stringers
Greg, where your arrow is pointing to the weak point, I use material size so that doesn't happen.
katoman is offline
Old 01-21-2012, 09:46 PM   #42
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Re: First Stringers
Am I the only one who believes in trying to incorporate a ledger under the tops, (if possible), and a full "stop block" across the bottoms?
No, the stringers and joist aren't drawn correctly on the left, I know that..... the picture is just to show the ledger.
And I would never do that bolt thing on the far left........ not without something else to help out. I'd probably cut the joist tails back, and fasten on a doubled header joist to their ends, and ledger that.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
The Following 2 Users Say Thank You to Willie T For This Useful Post:
greg24k (01-21-2012), JustaFramer (01-21-2012)
Old 01-21-2012, 09:59 PM   #43
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 354
Re: First Stringers
I do them like that also Willie.
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Willie T (01-21-2012)
Old 01-21-2012, 10:05 PM   #44
General Contractor
greg24k's Avatar
Rewards Points: 8,660
Re: First Stringers
I know that but depends on the stringer size you use and how much of a notch you make. Even if using 2x12 stringer on decks after the notch you remove a good portion of the stringer.
greg24k is offline
Old 01-21-2012, 10:06 PM   #45
WildWill's Avatar
Rewards Points: 504
Re: First Stringers
I don't ledger the tops of mine but I do stop block the bottoms depending on the situation.
WildWill is offline
The Following User Says Thank You to WildWill For This Useful Post:
Old 01-21-2012, 10:18 PM   #46
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Re: First Stringers
Same.
Winchester is offline
Old 01-21-2012, 10:30 PM   #47
General Contractor
greg24k's Avatar
Re: First Stringers
I made a little sketch and if you have a 2x12 with a 7.5" rise, and you make a notch and if you have 2x10 joist on the deck you will not have much left of that stringer which will make a very weak stair.
greg24k is offline
Old 01-21-2012, 10:33 PM   #48
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Re: First Stringers
I always use a stop bock at the bottom like Willie. But just blocks in between the stringers at the top.
I have sent the stringers into the joists beyond the stairwell opening before but generally find that to only work where the joists are not that deep, say 2x6 up to 2x8. Taller floor systems and you have that issue Greg is pointing out.
If I have the room to determine the starting point of the stairwell, I just incorporate the first tread to be flush with the deck. Basically adding one tread to the length of the opening. This way the stringer can land on the face of the header. New framing, I can leave the subfloor extended into the opening to create the first tread with that and cut the stringers accordingly. I find this to be the easiest of them all.
The Prazi chain saw attachment was a nice tool for the production work for carpeted stairs.
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Old 01-21-2012, 10:33 PM   #49
JustaFramer's Avatar
Trade: Exiled For Life
Re: First Stringers
Stop block and simpson the tops.
JustaFramer is offline
Old 01-21-2012, 10:40 PM   #50
Gus Dering's Avatar
Re: First Stringers
Greg,
Your measurement of the meat should be square to the bottom edge to the notch of the stringer. That will tell you what is left as structure.
Have you ever extended the notches up so there was some top edge of the stringer left un-cut to increase the meat below? That little void that is left under the leading edge of the stringer can be supported by the riser. It's one way to increase the strength of a staircase without wider material.
jb4211 (01-21-2012)
Old 01-21-2012, 10:45 PM   #51
General Contractor
greg24k's Avatar
Re: First Stringers
It's never a problem with interior oak box stairways, all you do is drop them in place and secure them... I stopped building my own stairs for the houses I build in the late 80's its cheaper to buy them then build your own this days... but I still love to mess around building deck stairs
greg24k is offline
Old 01-21-2012, 10:50 PM   #52
General Contractor
greg24k's Avatar
Re: First Stringers
Greg,
I did my stairs this way 1 time and I didn't like it, it was to much of a pain in the a$$ and I re did the stringers my way.
greg24k is offline
Old 01-21-2012, 11:39 PM   #53
jb4211's Avatar
Rewards Points: 2,306
Re: First Stringers
Has anyone ever used the Simpson Ties pictured at the bottom? I have and I like them, they're just an eye sore.
Will, I've used blocking under the last, bottom step, but not at the top. In my opinion, if you notch the stringer to accommodate the ledger, you weaken the stringer from say a 2 x 12 to a 2 x 10. Same as if you notched joists. Just my opinion. Like Gus said, I've used blocking between the stringers before. I've done some pretty wide steps before, as much as 6 - 8 feet for a low deck (maybe five steps). I just bought those stringers. I think you can buy up to 6 steps off the shelf.
It may be a better way to attach the stringers, but I don't like the look of the top step being a bump-out from the actual landing.
http://www.strongtie.com/products/co...SU.asp#gallery
Jon
jb4211 is offline
Old 01-21-2012, 11:40 PM   #54
jb4211's Avatar
Re: First Stringers
Here's a picture of one
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
Metro M & L (01-22-2012)
Old 01-22-2012, 12:20 AM   #55
General Contractor
greg24k's Avatar
Re: First Stringers
Attachment 63835
USP has a concealed hanger out for the stringers, its a much better way to connect a stringer and it will be hidden and you can bend the seat also to match stringer slope.
greg24k is offline
Old 01-22-2012, 01:53 AM   #56
Re: First Stringers
I used to use roll strap for the tops. LS25 I think it was the 1 1/2 stuff. Used 8's for the nailing.
Old 01-22-2012, 02:29 AM   #57
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Re: First Stringers
I've used those Simpson stair hangers pictured below. What an eye sore..
I only went with one in the center stringer and on the left and right I went with just right angle brackets...
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
The Following User Says Thank You to Rich D. For This Useful Post:
WildWill (01-22-2012)
Old 01-22-2012, 10:11 AM   #58
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Re: First Stringers
i use a hanger board.
1/2" plywood and nailed and screwed like crazy
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 01-22-2012, 10:24 AM   #59
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
Re: First Stringers
This was a good thread on stringers a few years ago.
https://www.contractortalk.com/f50/au...n-style-43998/
Joe Carola
Joe Carola is offline
The Following User Says Thank You to Joe Carola For This Useful Post:
greg24k (01-22-2012)
Old 01-22-2012, 01:33 PM   #60
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Re: First Stringers
Assuming the basic stringer material is strong enough for your span and will not shrink very much, you can just lean the top of the stringer against a solid fascia and notch in the bottom to a solid plate, and you stringers cannot fall down. Basic geometry.
I guess I am just agreeing with Willie (without the top ledger) and Gus.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
technique for mitering PVC stringers JDSR Finish Carpentry 11 01-22-2011 09:20 PM
Best saw for stringers? Chris G Decks & Fencing 70 12-07-2009 10:07 PM
Stringers for trex stairway joebuilderinc Construction 8 07-02-2009 01:08 AM
Concrete Pads for Wood Deck Stair Stringers Bodger General Discussion 12 12-12-2008 08:55 PM
Bamboo on stairs with warped stringers tgeliot Flooring 6 11-02-2008 12:35 PM
