First Stringers - Page 2 - Carpentry - Contractor Talk
First Stringers
Old 01-21-2012, 07:51 AM   #21
General Contractor
greg24k's Avatar
Rewards Points: 8,790
Re: First Stringers
I've seen many different ways people attach stringers, I can say I would not agree with some ways... But building hundreds if stairs and installing them, I always made sure the full back of the top stringer is fully rested against solid reinforced surface, and the bottom of the staircase stringer is also fully rested on sound solid surface and both ends properly anchored and secured preventing stairs from any movement. I don't believe notching top stringer and going under between the joist, or having the back of it hanging half way down or not fully seated on solid surface unsupported is wrong way of doing it .
Stringers are important structural part of any stairway and they should handle a much better load the min load requirement is... If I was a building inspector, I would flunked 100 of decks just because of the way stairs were build and attached... and I am not surprised why there is so many deck builders around, but not many out there who know how to layout and build stairs the right way.
greg24k is online now
thomasjmarino (01-21-2012)
Old 01-21-2012, 02:15 PM   #22
Thomas J Marino, Inc
thomasjmarino's Avatar
Trade: Custom Home Builder/General Contractor
Re: First Stringers
Originally Posted by jb4211 View Post
I always screwed through rim joist of the top platform into the riser. And possibly Simpson make a stringer tie-in braket I used before, but they're ugly so it has to be hidden.
Do it the way I said.
Sooooooo much better!!
thomasjmarino is offline
Old 01-21-2012, 03:19 PM   #23
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
Re: First Stringers
First set of stringers - always a milestone for a carpenter. Nice to have that under your belt . Congrats.
Grace is bestowed upon the soul - not upon the ego.
RS Sam is offline
Old 01-21-2012, 03:53 PM   #24
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Re: First Stringers
It's a good feeling isn't it?
Keep that feeling alive and you will never work again.
Thanks for posting it. It has me feeling good too, mostly for you
Gus Dering is offline
Old 01-21-2012, 03:57 PM   #25
jb4211's Avatar
Rewards Points: 2,306
Re: First Stringers
First, I had no idea there were so many ways to build stair and cut stringers. I was trying to find a way that explained how I do it. I was never "taught". I learned by reading and doing. I always use 2 x 12's. I know some use 2 x 10's and I've seen plenty, but there isn't enough stock left for my fat ass when the stringer is finally cut unless a 2 x 12 is used. Plus, I think code calls for over 3" of material to remain between the corner of the thread/riser and the back of the stringer when cut. I know some use LVL's too.
Anyway, below is the best that I could find that explains how I do it. Is this wrong? I like to build steps where the final step is the actual landing and not a bump-out of sorts to the final landing. I think the latter looks weird.
http://www.finehomebuilding.com/PDF/Free/021100054.pdf
Jon
jb4211 is offline
Old 01-21-2012, 04:07 PM   #26
WildWill's Avatar
Rewards Points: 504
Re: First Stringers
First, I had no idea there were so many was to build stair and cut stringers. I was trying to find a way that explained how I do it. I was never "taught". I learned by reading and doing. I always use 2 x 12's. I know some use 2 x 10's and I've seen plenty, but there isn't enough stock left for my fat ass when the stringer is finally cut unless a 2 x 12 is used. Plus, I think code calls for over 3" of material to remain between the corner of the thread/riser and the back of the stringer when cut. I know some use LVL's too.
I prefer to hook under the box at the top of the stairs and if the joists are running perpendicular then I tie into the next joist as well.
WildWill is offline
Old 01-21-2012, 04:08 PM   #27
jb4211's Avatar
Re: First Stringers
I never did that, but it sounds like a more solid way to connect the stringers
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
Old 01-21-2012, 04:23 PM   #28
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
Re: First Stringers
The nice thing about stringer is after cutting a few sets it becomes easy. Rafters too.
CK Carpentry
chris klee is offline
Old 01-21-2012, 04:24 PM   #29
WildWill's Avatar
Rewards Points: 504
Re: First Stringers
I like it for the cleanliness of it all. The less is more concept.
Either works fine though.
WildWill is offline
Old 01-21-2012, 04:39 PM   #30
jb4211's Avatar
Re: First Stringers
But Greg is talking about another way that I think is completely different for your, and my, way.
Jon
jb4211 is offline
Old 01-21-2012, 07:57 PM   #31
WildWill's Avatar
Rewards Points: 504
Re: First Stringers
I haven't seen a picture of what Greg is talking about. I did read the words but it didn't really explain much. Maybe I missed something?
WildWill is offline
Old 01-21-2012, 07:59 PM   #32
jb4211's Avatar
Re: First Stringers
agreed. I'm waiting for him to clarify
Jon
jb4211 is offline
Old 01-21-2012, 08:31 PM   #33
jb4211's Avatar
Re: First Stringers
I gotta run, QFT (Quality Family Time)
But, I'm watching the post, because I'm confused.
Jon
jb4211 is offline
Old 01-21-2012, 08:35 PM   #34
Re: First Stringers
Old 01-21-2012, 08:37 PM   #35
jb4211's Avatar
Re: First Stringers
I understand that, but what's Greg talking about. Because his design seems different
Jon
jb4211 is offline
Old 01-21-2012, 08:39 PM   #36
jb4211's Avatar
Re: First Stringers
Originally Posted by greg24k View Post
...I always made sure the full back of the top stringer is fully rested against solid reinforced surface, and the bottom of the staircase stringer is also fully rested on sound solid surface and both ends properly anchored and secured preventing stairs from any movement. I don't believe notching top stringer and going under between the joist, or having the back of it hanging half way down or not fully seated on solid surface unsupported is wrong way of doing it .
This is the part that has me confused.
Jon
jb4211 is offline
Old 01-21-2012, 08:48 PM   #37
WildWill's Avatar
Rewards Points: 504
Re: First Stringers
He might in part be talking about this situation.
WildWill is offline
Old 01-21-2012, 09:18 PM   #38
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: First Stringers
I do them the same as Wildwill. If the stringers are finished materials, like oak, that's the only way to do them and have the stringers finish cleanly into the ceiling.
katoman is offline
Old 01-21-2012, 09:29 PM   #39
JustaFramer's Avatar
Trade: Exiled For Life
Re: First Stringers
I remember my first set of stairs. I thought I learned the best kept secret. When I was doing piece work. Anyone could do wall, joists or truss roofs. Well anyone can wall bang. Joist should be easy but you can be surprised. Roof even truss can be challenging to a newb.
Stairs are the gig I went for. Never needed a dumb **** partner for this gig. Rolled solo.
JustaFramer is offline
Old 01-21-2012, 09:30 PM   #40
General Contractor
greg24k's Avatar
Re: First Stringers
Sometimes if not in all cases, the first tread of the stringer when coming off the deck must be notched around the rim joist and raised up to keep the same riser hight, which will create the the bottom point of the stringer under the first tread the weak point.
technique for mitering PVC stringers JDSR Finish Carpentry 11 01-22-2011 09:20 PM
Best saw for stringers? Chris G Decks & Fencing 70 12-07-2009 10:07 PM
Stringers for trex stairway joebuilderinc Construction 8 07-02-2009 01:08 AM
Concrete Pads for Wood Deck Stair Stringers Bodger General Discussion 12 12-12-2008 08:55 PM
Bamboo on stairs with warped stringers tgeliot Flooring 6 11-02-2008 12:35 PM
