First Stringers - Carpentry - Contractor Talk
First Stringers
Old 01-20-2012, 08:25 PM   #1
carpenter jr
Carpenter eyes's Avatar
Trade: how hard can it be?!
First Stringers
Built my first set of basement steps today.
Not done yet. One more tread and more support below
i cut this thing 3 times and its still too short!!
Carpenter eyes is offline
Old 01-20-2012, 08:36 PM   #2
Greg's Avatar
Trade: Custom Decks
Rewards Points: 282
Re: First Stringers
Someone once said that the first time is always the best. That might have been about something else...
Good Job!!
Greg is offline
Old 01-20-2012, 08:39 PM   #3
carpenter jr
Re: First Stringers
Little stressful. Took my time and triple checked everything. Due to super unlevel floor some shimming was needed.
Old 01-20-2012, 08:46 PM   #4
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 2,788
Re: First Stringers
Congrats!!
What did your riser:tread ratio turn out to be?
wallmaxx is online now
Old 01-20-2012, 08:52 PM   #5
carpenter jr
Re: First Stringers
It worked out to 8 10
Old 01-20-2012, 09:07 PM   #6
WildWill's Avatar
Rewards Points: 504
Re: First Stringers
Nice! What is the deal with the part that is facing us though?
WildWill is offline
Old 01-20-2012, 09:12 PM   #7
jb4211's Avatar
Rewards Points: 2,306
Re: First Stringers
I never did them like that. Your's seem to tie-in past the end joist at the top.
Mine looked more like the one on the far left.
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
Brutus (01-21-2012)
Old 01-20-2012, 09:15 PM   #8
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: First Stringers
Is that a 2x12 your using. Sure looks like you got a lot of meat left on the stringer for steps that meet code. I am normally left with about 4"
www.bcconstructionllc.com
BCConstruction is offline
Old 01-20-2012, 09:20 PM   #9
jb4211's Avatar
Re: First Stringers
Ya, I missed that. They do look beefy
Jon
jb4211 is offline
Old 01-20-2012, 09:30 PM   #10
carpenter jr
Re: First Stringers
Had to add a few more poinrs to tie into. New HEAVY furnence will be headed down those in the next few days. Thats y they are beefy like that. Also supporting with 4x4s on the top and mid. Rather overkill them then have them fail
The Following User Says Thank You to Carpenter eyes For This Useful Post:
Willie T (01-21-2012)
Old 01-20-2012, 09:31 PM   #11
Thomas J Marino, Inc
thomasjmarino's Avatar
Trade: Custom Home Builder/General Contractor
Re: First Stringers
Little confused by jb's and Bc's posts.
You always use 2x12's for stringers. Why wouldn't you?
Provides more structural stability.
And I always cut my stringers so they slide behind the box beam, top riser or whatever you would call it. And I cut them so that they sit flush to the underside of the deck boards, subfloor, etc.
Again, provides more structural stability.
You can fasten them much better this way.
Through the riser (box), decking or subfloor and the floor joist.
thomasjmarino is offline
The Following 4 Users Say Thank You to thomasjmarino For This Useful Post:
BC Carpenter (01-22-2012), Jaws (01-20-2012), Mud Master (01-24-2012), WildWill (01-20-2012)
Old 01-20-2012, 09:39 PM   #12
jb4211's Avatar
Re: First Stringers
I always screwed through rim joist of the top platform into the riser. And possibly Simpson make a stringer tie-in braket I used before, but they're ugly so it has to be hidden.
Jon
jb4211 is offline
Old 01-20-2012, 09:40 PM   #13
carpenter jr
Re: First Stringers
Yeah i used a 2x12 that was frozen. The workdrive dosnt like icy lumber
Old 01-20-2012, 09:41 PM   #14
jb4211's Avatar
Re: First Stringers
Neither do I. lol
Jon
jb4211 is offline
Old 01-20-2012, 09:43 PM   #15
carpenter jr
Re: First Stringers
Originally Posted by jb4211
Neither do I. lol
Adds a few pounds lol
Old 01-20-2012, 09:46 PM   #16
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: First Stringers
I always attach my stringers with approved lag bolts attached directly to piers we drive deep into the bedrock. Its the only way you can really be sure.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
bluebird5 (01-20-2012)
Old 01-20-2012, 09:54 PM   #17
skillman's Avatar
Rewards Points: 1,968
Re: First Stringers
Congrats on your first stringer steps well done.
skillman is offline
Old 01-20-2012, 10:03 PM   #18
carpenter jr
Re: First Stringers
Thank you thank you
Old 01-20-2012, 10:04 PM   #19
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,510
Re: First Stringers
It is still rewarding to me ,after cutting out tons of stringers, to walk up the finished set. Good job!
overanalyze is offline
Old 01-20-2012, 11:21 PM   #20
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Re: First Stringers
But did you remeber to run the drain tile and gutter drainage directly into the mississippi?
bluebird5 is offline
The Following User Says Thank You to bluebird5 For This Useful Post:
cssconstruct (02-23-2012)
technique for mitering PVC stringers JDSR Finish Carpentry 11 01-22-2011 09:20 PM
Best saw for stringers? Chris G Decks & Fencing 70 12-07-2009 10:07 PM
Stringers for trex stairway joebuilderinc Construction 8 07-02-2009 01:08 AM
Concrete Pads for Wood Deck Stair Stringers Bodger General Discussion 12 12-12-2008 08:55 PM
Bamboo on stairs with warped stringers tgeliot Flooring 6 11-02-2008 12:35 PM
