Extending Your 'Slide' - Carpentry - Contractor Talk
Old 03-09-2006, 08:06 PM   #1
Tom R's Avatar
Rewards Points: 2,036
OK, - - here's a few pics that may (hopefully) help those who were asking about how to extend the 'length-of-stride' capacity on their SCMS saws.
My particular saw is a Bosch 4412, - - it's 'length of cut' is about 12 1/2", - - these pics will demonstrate a simple method to extend that length of cut to about 16 1/2". I did this (for demonstration purposes only), - - by making (I should say 'throwing-together') an L-shaped 'Tilt-Board-Table' made of 1/4" luanne and 1 X 3 spruce, - - measuring about 7 1/2" X 2 1/4".
Obviously, - - each particular saw will need it's own 'custom-dimensioned' table, - - and also, just as obvious, your tables can be made as intricate as you want them, - - this demonstration is just enough to get your own wheels turning!!
The first pic is of the saw ending at it's maximum 'stride' (about the 12 1/2" point), - - the second pic is how I normally pivot the piece upward and into the 'fuller' diameter of the blade while I'm cutting to achieve a much longer stride (I DO NOT RECOMMEND ANYONE TRIES IT THIS WAY!!), - - the third pic is a simplified version of a much smarter, much safer, and much more recommended way of doing it.
OK, - - with all that understood, - - here goes (I hope they don't come out too blurry) . . .
Tom R is offline
Old 03-09-2006, 08:35 PM   #2
Tom R's Avatar
Re: Extending Your 'Slide'
Oh, - - and like I say, - - I just made a small 'demo-version' table here, - - but if you were to make one similar (but longer) you would want to 'set' your saw 'depth of cut' adjustment to 1/4" high (in this instance), - - so as not too cut completely through the base of your customized 'tilt-board'.
Tom R is offline
Old 03-09-2006, 08:39 PM   #3
ContractorTalk Flunkie
dayspring's Avatar
Thanks Tom, good trick. It will come in handy I'm sure.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 03-09-2006, 09:01 PM   #4
Tom R's Avatar
Good, - - glad to hear it!!
Tom R is offline
Old 03-09-2006, 09:46 PM   #5
Teetorbilt's Avatar
Rewards Points: 2,000
#3 is a good tip and thanks for downsizing #2 and I know that most of us have done it. We call it 'chasing the blade', know that it is dangerous and keep doing it.
Albert Einstein
Teetorbilt is offline
Old 08-08-2007, 06:16 PM   #6
Tom R's Avatar
bumpety-bump . . .
Tom R is offline
Old 08-08-2007, 06:35 PM   #7
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Rewards Points: 2,022
Thanks for the bump Tom, I must of missed this thread the first time around.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 08-08-2007, 06:55 PM   #8
Kent Whitten's Avatar
Rewards Points: 2,040
OK, those fingernails are too clean. Those are white collar fingers! LOL.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 08-08-2007, 08:03 PM   #9
Tom R's Avatar
Any decent carpenter knows the importance of his nails . . .
Tom R is offline
Old 08-09-2007, 01:03 AM   #10
Average Joe
Heritage's Avatar
Trade: Design/Build
Rewards Points: 524
Ahem...table saw has a great "length of stride". And you don't have to worry about the kick-back and various other hazards from that operation.
Not tryin' to dog you Tom, just my 2 cents. I've never had to work with a miter cut on my scms that didn't fit. If you're making straight cuts, just drop it on the table saw.
Hey, you can hate me even outside the politics forum
Toronto General Contractor
The foundation stones for a balanced success are honesty, character, integrity, faith, love and loyalty.
-Zig Ziglar
Heritage is offline
Old 08-09-2007, 10:05 AM   #11
Tom R's Avatar
That's alright, no problem, - - it's just a method for your SCMS to get wider cuts. Some guys don't happen to have a table saw on the job, - - or, - - they've already got the miter saw set up and are looking to save time.
Also, the table saw is not only more dangerous to use for crosscutting (more chance of kickback), - - but it's usually highly inconvenient for crosscutting long pieces.
Any crosscutting done on a table saw is much safer with a crosscut-sled. But again, - - the SCMS, if already set up, can be much more convenient.
Like any other advice or ideas, - - it's only applicable to those who percieve a value to it for their own particular situations . . .
Now, - - maybe I should just go and start a thread about you in Politics for that . . . J/K
Tom R is offline
Old 08-12-2007, 08:03 AM   #12
extreme birdhouse builder
cranbrook2's Avatar
Trade: framing ,trim ,roofing,fences and decks .
Rewards Points: 288
If i am cutting a piece say 13" wide i will lift the piece to cut the last bit but anything bigger i flip the board over and then you have another 12 " to cut with
cranbrook2 is offline
Old 08-12-2007, 08:20 AM   #13
Tom R's Avatar
Jeez, - - I bet no one here ever even though of that.
Thanks loads . . .
Tom R is offline
Old 08-12-2007, 08:22 AM   #14
Tom R's Avatar
Talking about carpentry, - - is it my imagination or this 'board' starting to go down-hill??
Tom R is offline
Old 08-12-2007, 08:27 AM   #15
Tom R's Avatar
And to think I was about to give an explanation today on how to increase the bevel of your circular saw without the aid of a jig or bevel-block.
I think instead, - - I'll hereby offer 'the floor' to Heritage and Cranbrooke to explain it . . .
You're on, guys, - - let's hear how it can be done, - - your fan clubs are waiting on you's . . .
Tom R is offline
Old 08-12-2007, 08:32 AM   #16
cranbrook2's Avatar
Rewards Points: 288
Thanks loads . . .
Don,t mention it
10" Dual-Bevel Slide Miter Saw dcarpentry Finish Carpentry 22 11-19-2007 11:39 PM
Customer Does Not Pay! PLC-Landscape General Discussion 40 01-26-2007 11:30 AM
Extending or rerouting pipes tate16t Plumbing 8 10-22-2006 10:58 PM
Extending CAT5 cable JPV123 Technology 6 01-28-2006 12:20 PM
extending soffit? WilsonInc. Finish Carpentry 7 05-23-2005 05:52 PM
