Epoxy Wood Top - Carpentry - Contractor Talk
Epoxy Wood Top
Old 05-23-2015, 08:45 PM   #1
LockTalk's Avatar
Trade: Cabinet maker
Rewards Points: 264
Epoxy Wood Top
I'm wondering if anyone has done any poured epoxy wood tops, if so
what did you use?
Can you post any pics?
What challenges did you run into?
Anyone familiar with the epoxy finishes can you provide any suggestions to dull the finish to take the sheen down so it's more of a matte finish
Thanks
David
LockTalk is offline
Old 05-27-2015, 09:13 PM   #2
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
Re: Epoxy Wood Top
plenty of stuff on you tube... steel wool to get your mattte finish
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 05-28-2015, 10:01 AM   #3
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 14,026
Re: Epoxy Wood Top
Pour it on generously. Work it quickly but the more you work it the quicker it dries. Getting the bubbles out can be a bit tricky, you have to blow on them to get them out. After the first time I did it I went ahead and blew up balloons before hand, tied them up, then used a drinking straw to let the air over the bubbles. Put a hole next to the tie so they don't pop and let air out slowly.
It's the CO2 that makes them rise and pop. I'm sure there are a million other ways but this worked on 15 sq ft of top. Only done them twice though.
[signature removed by admin]
Deckhead is offline
The Following 2 Users Say Thank You to Deckhead For This Useful Post:
BlueRidgeGreen (05-28-2015), kwunch (05-29-2015)
Old 05-28-2015, 10:29 AM   #4
Creter's Avatar
Rewards Points: 1,966
Re: Epoxy Wood Top
Have everything ready BEFORE you start to mix the product you are going to use.
Drops, floor protection and more protection if you will be doing in place as the stuff does run.
Have multiple throw away plastic putty knives to knockdown the bottom edge where the epoxy collects.
You may also use a BLUE propane torch NOT YELLOW MAPP but BLUE to help remove the bubbles. Obviously we're not looking to make smores so waving slowly a reasonable distance from the surface.
I recommend mocking up a small test drive model if this is your first time.
http://www.benhardtconstruction.com/...countertop.jpg
Creter is offline
Old 06-09-2015, 09:57 PM   #5
senorfish's Avatar
Trade: lighting design
Rewards Points: 36
Re: Epoxy Wood Top
In composite work.... mixing the epoxy very gently helps avoid pinhole bubbles. And dont use an up down motion with the stirring device (introduces air). Measure the hardner precisely. Work faster on a hot day. Change gloves frequently to avoid leaving epoxy finger prints everywhere. Can never have enough gloves, high quality paper towels, and acetone. Be very clean or you'll regret it!
senorfish is offline
The Following User Says Thank You to senorfish For This Useful Post:
Rio (06-16-2015)
Exterior Wood Post to Concrete bwiab Construction 4 04-11-2013 11:06 PM
Help on Bending wood for a greenhouse NC2X4 Finish Carpentry 1 03-28-2013 08:12 PM
Simpson Set 22 Epoxy into Parallam Columns? JesseCocozza Framing 0 09-19-2011 06:53 PM
Wood fire place insert job Joester_03 Masonry 13 02-11-2011 07:07 AM
