Engineering Prank? - Carpentry - Contractor Talk
Engineering Prank?
Old 02-22-2013, 10:22 PM   #1
Talking Head
EthanB's Avatar
Rewards Points: 438
Engineering Prank?
I just got a set of engineering specs for a good sized remodel that calls for all 9 1/4" LVL's. Is this a thing or is the engineer a nut? My yard is all 9.5".
Planer.....
EthanB is offline
Old 02-22-2013, 10:24 PM   #2
Dan_Watson's Avatar
Rewards Points: 2,748
Re: Engineering Prank?
http://www.gp.com/build/product.aspx?pid=1392
9 1/4" is real
Dan_Watson is offline
The Following 3 Users Say Thank You to Dan_Watson For This Useful Post:
greg24k (02-23-2013), griz (02-22-2013), Jaws (02-23-2013)
Old 02-22-2013, 10:28 PM   #3
bconley's Avatar
Trade: Kitchen and bath design+remodel
Be happy its 9 1/4 it will match the 2x10s if you're using them
bconley is offline
The Following 7 Users Say Thank You to bconley For This Useful Post:
Brutus (02-23-2013), Dan_Watson (02-22-2013), FGCC (02-22-2013), hdavis (02-23-2013), Jaws (02-23-2013), ScipioAfricanus (02-22-2013), slowsol (02-23-2013)
Old 02-22-2013, 10:28 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,840
It's never been a problem to go over spec.
Write an RFI to use the 9-1/2" LVL's.
Make certain it is not a cost issue.
griz is online now
Old 02-22-2013, 10:29 PM   #5
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
9.25 is so you can use them in a floor system with 2x10 material without a hump.
RobertCDF is offline
Old 02-22-2013, 10:29 PM   #6
RobertCDF's Avatar
You type faster than i do...
Old 02-22-2013, 11:17 PM   #7
Talking Head
EthanB's Avatar
Rewards Points: 438
Thanks. He's been so lame about getting the info to the arch that I wouldn't have been surprised if it turned out to be a wacky item. I requested three specs and have only received one after two months. It was in red marker written across the plan.
Planer.....
EthanB is offline
Old 02-23-2013, 07:05 AM   #8
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
This is about the time when I would stop the project and send the engineer an email, copied to the owner and architect outlining the importance of the required information, time is of the essence, perhaps if he is too busy or lost interest in the project that we should part ways and get a new engineer.
It's usually enough to get their attention, and it has only been once last summer when we actually did bring in a new engineer
Chris
Chris Johnson is offline
Old 02-23-2013, 08:34 AM   #9
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I thought this thread was about imported flooring...
You want engineer prank froor
-Steve
TimelessQuality is offline
The Following 5 Users Say Thank You to TimelessQuality For This Useful Post:
donerightwyo (02-24-2013), FramingPro (02-23-2013), griz (02-23-2013), J L (02-24-2013), RobertCDF (02-23-2013)
Old 02-23-2013, 08:57 AM   #10
Carolina Surface Prep
Rob1954's Avatar
Trade: Media blasting and residential restoration
Rewards Points: 202
There is no problem with ripping 9.5" to 9-1/4" depth. Just don't do it until you are ready to install it, because you will be removing the edge seal which provides some moisture protection.
We often rip 11-7/8" to 11-1/4" to match up with 2x12 framing.
Rob1954 is offline
The Following 3 Users Say Thank You to Rob1954 For This Useful Post:
fourcornerhome (02-23-2013), FramingPro (02-23-2013), FullerFramer (02-26-2013)
Old 02-23-2013, 10:49 AM   #11
General Contractor
greg24k's Avatar
Rewards Points: 8,652
Standard sizes are 9-1/4", 9-1/2", 11-1/4", 11-7/8", 14", 16", and 18"... can also get custom sizes is 20" 22" and 24.
Someone here mentioned ripping them from 11 7/8 to 11 1/4" ... you have to be out of your mind to do that.
greg24k is offline
Old 02-23-2013, 12:12 PM   #12
Rob1954's Avatar
Rewards Points: 202
Out of your mind would be to pay special order prices and wait a couple of days for the 11-1/4" depth, when it takes just a few minutes to rip the 11-7/8" to size.
Rob1954 is offline
Old 02-23-2013, 03:16 PM   #13
CarpenterSFO's Avatar
Rewards Points: 2,044
Warranty issue?
- Bob
CarpenterSFO is offline
Old 02-23-2013, 08:12 PM   #14
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
When you rip them, wear gloves or they will rip you.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 02-23-2013, 08:19 PM   #15
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
I've done it.
If the yard only sells 9 1/2'' LVL and you need it slipped inside of 2 x 10
floor system.
Padding down all the joist after the fact,
now that you gotta be outta your mind to do.
-Scott
tenon0774 is offline
The Following 2 Users Say Thank You to tenon0774 For This Useful Post:
greg24k (02-23-2013), slowsol (02-23-2013)
Old 02-23-2013, 10:05 PM   #16
EricBrancard's Avatar
Rewards Points: 986
Hopefully. The 2x10s may still shrink down some more. The LVLs will not. The last shipment of 2x10s I received for floor joists ranged from 9 1/4 to 9 1/2. I wish I just used engineered stuff for everything...
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
jhark123 (02-26-2013)
Old 02-23-2013, 11:43 PM   #17
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
I've done it. When you order a 11-7/8" lvl, and it comes 12-1/2" on one end, tapering off to 11-3/4" in the middle and 12-1/4" on the other end....... Pick your best edge, set the rip fence on the circ, and trim. Install cut up..
I've taken a 3" piece of LVL to the arm. Went to the clinic, doc couldn't get it out... I said screw it, went back to work.... it worked it's way out by the end of the day.
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
Old 02-23-2013, 11:47 PM   #18
tenon0774's Avatar
I use electrical tape wrapped a couple times around my first finger, to use it as the "edge guide"
-Scott
Old 02-23-2013, 11:48 PM   #19
tenon0774's Avatar
So you cut a "crown" in them?
-Scott
Old 02-24-2013, 09:25 AM   #20
Nail-Bender
Brutus's Avatar
No. One edge is pretty darn straight, the other is all over the place. We cut the one that is all over the place to make it straight.
Brutus is offline
Good Prank or bad Prank? Snobnd Off Topic (Non Trade) 13 10-30-2012 06:47 AM
Working for engineering firms.... [email protected] General Discussion 10 09-18-2012 07:56 PM
My first question: Engineering paradisemike Framing 8 11-24-2010 06:39 PM
What to do after engineering school pyroracing85 General Discussion 6 05-22-2009 12:00 PM
Engineering Degree? J Howard General Discussion 14 09-29-2008 09:50 PM
