Drop Down Bar Entrance Hardware? - Carpentry - Contractor Talk
Old 08-11-2019, 01:59 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,712
I think I'm overthinking this. I may be overthinking whether I'm overthinking it too.
Building a bar top. It's done, it's lovely. They've decided that they want a "gate" in the counter where initially it was to just be an opening. Plenty of leftover material to make it. NBD.
What's different is they're asking for it to drop down and be able to be propped up. I've only ever done the classic "flip up" bar entrance. I've seen some hardware that looks like what I want, except that it'd have to be paired and you'd have to access the "unlock" button from both sides of the counter, which seems annoying as hell.
Should I just be using a piano hinge and a flip down stick? Should I be using a piano hinge on one side and a catch of some kind on the other?
Set me straight. Thanks.
Easy Gibson is online now
Old 08-11-2019, 02:25 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,596
Re: Drop Down Bar Entrance Hardware?
couple of issues from past experience.
if anyone leans on the drop down section it likely will not support their weight. ever seen a bar where someone isn't leaning on it???
can be VERY awkward trying to open it from either side.
we did manage to do it with a sliding bolt in the middle of the top.
you could just reach under from either side and drop down the top.
but it was awkward.
griz is online now
Easy Gibson (08-11-2019)
Old 08-11-2019, 02:42 PM   #3
Texas Wax's Avatar
Rewards Points: 1,728
Couldn't ever really find a decent solution for a locking mechanism.... so do what ya gotta do.
Find A pre-made SOLUTION?, would like to know.
Piano hinge of a proper size is the solution. Most other options have too much play or slop, making alignment in general and specifically the "lock", probklematic.
A really a solid solution?, worked for me LOL
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Old 08-11-2019, 07:52 PM   #4
rrk's Avatar
Rewards Points: 1,778
Check Richelieu ( Outwater hardware ) in Lincoln Park
They have a drop down brackets that is used in laundry rooms for a folding table.
When you lift up the lock releases and top can drop down
rrk is online now
Old 08-12-2019, 07:12 AM   #5
That's what I had in mind, but Griz is scaring me a bit with the pressure issue.
Old 08-12-2019, 07:31 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,051
Does the bar top have a rail, and who's going to catch their leg on it first?
Also, who's going to want to reach down, lift it up and lock it? Having done that only once or twice/year for a drop-left table during holiday dinners, I can say that's it's aggravating.
Here's an idea...make it fold upward, then rotate 180....somehow.
MarkJames is offline
Old 08-12-2019, 07:50 AM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 778
I was thinking of a similar locking solution, just not that complicated. A double rod connected by one long handle so it could be reached from both sides. 2 pieces of pipe slightly larger than locking rods to guide & carry the rods.
pinwheel is online now
Old 08-12-2019, 10:10 AM   #8
This problem sucks.
I figured there would be tons of off the shelf solutions for this, but it appears there really aren't. Just a bunch of crappy catches and arms for drop leaf tables that aren't weight rated for the job.
Hmmmmmmmmm
Old 08-12-2019, 11:53 AM   #9
Texas Wax's Avatar
Originally Posted by Easy Gibson View Post
This problem sucks.
Hmmmmmmmmm
And thus the Rube Goldberg lock mechanism. Did wood because it was easier and cheaper than metal. Needed to have metal parts parts milled at a machine shop vs being able to pattern make out of wood.
Good luck have fun
Old 08-12-2019, 12:01 PM   #10
I'm picturing a large sliding bolt. Not that your way isn't much more aesthetically pleasing...
Old 08-12-2019, 12:07 PM   #11
Texas Wax's Avatar
whelp the wood latch pieces are tapered so it snugs up tight. Seemed best solution as they wanted a smooth continuous work surface.
Old 08-12-2019, 12:13 PM   #12
Texas Wax's Avatar
had little to do with pleasing rather functional-easy to lock as was all about making it solid. Need two locking points for that and could'nt come up with a better more elegant solution.
Old 08-12-2019, 12:20 PM   #13
After having visited Outwater(the parts superstore rrk mentioned above), I am astonished there isn't an off the shelf solution for this.
There's a mint to be made for one of us here. The current leading flip up mechanism is a tortion bar system that wholesales for f'n $500+
Old 08-12-2019, 01:00 PM   #14
Texas Wax's Avatar
My magic mechanism retails for $499.95, CTalk discount: $500.01. I'll even throw free shipping and paraffin 'Wax' to lube to the sliding parts for you Easy!
""There's a mint to be made for one of us here."" let's hit the shark tank
Easy Gibson (08-12-2019)
Old 08-12-2019, 02:49 PM   #15
pinwheel's Avatar
Rewards Points: 778
Seriously dude, it dont have to be that hard. A couple pieces of conduit & a couple pieces of all thread to slide through the conduit sleeves.
I'll do a sketchup drawing of how I envision it later on.
Use a piano hinge on one side & a ledge on the other side for the tip up bar to land on. Then the latch underneath. 30 minute hack on the latch & $10 worth of parts.
Old 08-12-2019, 02:51 PM   #16
rrk's Avatar
And $100k of insurance when someone gets a scratch on their fingers
rrk is online now
Old 08-12-2019, 02:59 PM   #17
pinwheel's Avatar
Rewards Points: 778
Same claim if they smash their finger closing the gate. Must suck living life in a bubble.
Old 08-12-2019, 03:00 PM   #18
That's the thing.
Ideally there would be something like the flip up mechanisms but just... upside down. I'd pay the $500 if it were guaranteed to work for the duration of the lease and able to be utilized by your typical wine store salesperson, who does not match the build of your typical contractor. No ouchies allowed.
I'll figure it out... probably not tonight though. I've had about enough of thinking about this.
The Following User Says Thank You to Easy Gibson For This Useful Post:
rrk (08-12-2019)
Old 08-12-2019, 03:38 PM   #19
Texas Wax's Avatar
Seemed they specified drop "down" .... changes the animal. Hell I wouldn't have needed my fancy mechanism if there was a ledge to land the tip "up" bar on
pinwheel (08-12-2019)
Old 08-12-2019, 05:32 PM   #20
danrush's Avatar
Trade: cabinet installation
Could you use a strike from a door lockset, and mock up a lower profile handle to operate it from below? Kind of like a door mounted horizontally.
Sent from my SM-T580 using Tapatalk
danrush is online now
