Cutting 7" X 22" Vision Panels For Existing Solid Wood Doors - Carpentry - Contractor Talk
Old 05-30-2015, 05:11 AM   #1
Tonkadad's Avatar
Rewards Points: 85
I have to cut 7 vision panels (7" x 22") into existing 1 3/4" birch doors (wood core), was gonna make a ply template to position on door and cut with 2 - PORTER-CABLE 690LR and 1/2" shank spiral bits. The first one setup to cut just under an 1" and the second router setup to finish cut.
Does this sound reasonable? What is the smallest I can go on bit diameter before breakage becomes an issue? Is there a better way to do it?
Doors will be removed from frames.
thanks,
Bruce
Tonkadad is offline
Old 05-30-2015, 07:30 AM   #2
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,442
Re: Cutting 7" X 22" Vision Panels For Existing Solid Wood Doors
What you're looking to do sounds reasonable. I'd run a 1/2" bit with 1/2" shank to do the cutting. You mention fixed base routers, but I'd use the depth stops on a plunge router to cut 1/4" per pass or so.
If you made a mirrored template on both sides of the door, you could get away with one router just by flipping the door over and routing the opposite side and meeting the cut in the middle.
J L is offline
Old 06-01-2015, 12:07 PM   #3
Tonkadad's Avatar
Rewards Points: 85
Excellent advise, that's the way I will do it.
thanks
Tonkadad is offline
Old 06-01-2015, 04:19 PM   #4
AustinDB's Avatar
Rewards Points: 1,108
I did this with 11 solid core doors. Built a nice template and tried the route, but the tearout/wandering was not good and trying to get the exact same cutout on the opposite side was impossible (for me).
method two was to use the track saw and finish the corners by hand. Very good results. I had to glue a frame inside of the cutout with mitered corners.
AustinDB is offline
Old 06-02-2015, 09:58 PM   #5
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,960
Track saw and finish with a jig saw.
It may take longer to make the jig than cut the doors.
B.D.R. is offline
Old 06-06-2015, 08:05 AM   #6
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
You guys over think this stuff. It's 4 straight cuts with a regular circular saw. And finish with a jig saw. I have finished these cuts in doors with a sawzall. You have trim pieces to cover the cut. A track saw to cut 7"!?!???
ubcguy89 is offline
Old 06-07-2015, 06:24 AM   #7
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
for sure over thinking the easy way.
pappagor is offline
Sealing painted wood panels Pbpaints Painting & Finish Work 15 04-30-2015 09:22 PM
Cutting a positive arch in a wood fence jshomewood Decks & Fencing 35 06-16-2011 09:26 PM
Cutting panels into solid wood doors. BentheBuilder Windows, Siding and Doors 8 03-06-2008 11:28 PM
