Composite Tongue And Groove Siding - Carpentry - Contractor Talk
Old 07-29-2010, 03:26 PM   #1
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 52
Anyone know of a manufacturer that makes composite tongue and groove siding?? prefer 7 1/4" reveal and rough sawn look to match. Need to replace some rotted cedar T & G and customer asked about any composite material available. Azek has some that is smooth and 5 1/4".
goneelkn is online now
Old 07-29-2010, 04:22 PM   #2
Rewards Points: 2,000
Re: Composite Tongue And Groove Siding
Far better to address the problem
that caused the rot.
I would think there would be major
expansion issues siding an entire house
with PVC, not to mention moisture
problems behind it.
Properly installed, there's no reason
cedar can't last 100 years.
neolitic is offline
Old 07-29-2010, 04:45 PM   #3
goneelkn's Avatar
Rewards Points: 52
It's on a short wall between two roofs, the siding is only 3' tall, roof to roof. I told HO that i could replace with cedar and leave a 1" gap at bottom of siding so it would drain/breathe better. Rot seems to be from siding wicking moisture up from step flashing. Existing siding has only a 5/8" gap between bottom and shingles. Didn't consider the expansion issue, only going on what HO asked for. I'll tell them they would be better off with the cedar and more gap at bottom, especially since it's southern exposure. Thanks
The Following User Says Thank You to goneelkn For This Useful Post:
neolitic (07-30-2010)
Old 07-30-2010, 09:50 AM   #4
If they are worried about seeing
the step flashing between the roof
and the siding, run a piece of
appropriately colored coil as a
counter flashing behind the cedar.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
goneelkn (08-01-2010)
Old 07-30-2010, 06:32 PM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
neo...you are the carsiding king
Tom Struble is offline
Cathedral Roof Tongue and Groove Ceiling Pricing Help Kel-Kat Finish Carpentry 14 10-23-2011 06:13 PM
tongue and groove exterior planking? [email protected] Decks & Fencing 3 05-04-2010 09:11 AM
Installing Hardwood over Tongue and Groove subfloor CT Cruiser Flooring 4 03-14-2009 09:10 PM
fastening ipe tongue and groove AltonAyer Decks & Fencing 0 09-05-2008 07:51 PM
Gluing Tongue & Groove Planks to the Floor Journeyman T Flooring 11 10-21-2007 06:02 PM
