Cabinet Rails - Carpentry - Contractor Talk
Cabinet Rails
Old 04-08-2018, 01:47 PM   #1
txgencon's Avatar
Rewards Points: 468
Cabinet Rails
For the cabinetmakers here:
How do you decide the width of rails for face frame cabinets?
3 or 4 drawers in a 36" high base?
Client specs? Minimum dimensions?
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 04-08-2018, 02:04 PM   #2
Hack
asevereid's Avatar
Rewards Points: 346
Re: Cabinet Rails
I always thought the standard was 2-1/4"?
For the record, I don't build cabinets professionally, and for every custom one I've bid, I've been denied because of price... But every one was designed with 2-1/4" gave frames in mind.
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
Old 04-08-2018, 02:31 PM   #3
tjbnwi's Avatar
Rewards Points: 4,102
Re: Cabinet Rails
Cabinet rails and stiles I make 1-3/4" wide. 5 piece door or drawer rails and stiles I make 2-1/4"
tjbnwi is online now
pinwheel (04-08-2018), rrk (09-12-2018)
Old 04-08-2018, 02:33 PM   #4
rrk's Avatar
Rewards Points: 4,922
Re: Cabinet Rails
I make them 1 1/2"
rrk is offline
Old 04-08-2018, 02:52 PM   #5
txgencon's Avatar
Rewards Points: 468
Re: Cabinet Rails
How 'bout the 3 or 4 drawers question?
txgencon is offline
Old 04-08-2018, 04:06 PM   #6
KAP's Avatar
Trade: Custom
Rewards Points: 39,906
Re: Cabinet Rails
Also depends on style... full overlay versus semi...
But as a standard, 1 1/2" rails... as to 3 or 4 drawers, it all depends on what's being stored... cutlery versus pots for example...
KAP is offline
Old 04-08-2018, 04:12 PM   #7
tjbnwi's Avatar
Re: Cabinet Rails
All rails are made the same width. Number of openings does not matter.
Old 04-08-2018, 05:41 PM   #8
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,877
Re: Cabinet Rails
Apparently no standard.
FF inset I do 2" for the frame and 1 1/4" for the divider rails between the drawers.
Overlay which I rarely do is usually 1 1/2" all the way around on the lowers. On the uppers the top rail is wider, usually 4".
Usually 3 drawers in a 34 3/4" tall lower box. You can go to 4 in a frameless cabinet or a 1 1/2" rail system. That usually yields a 5 3/4" opening for the 4 drawer system.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
Texas Wax (04-08-2018), txgencon (04-08-2018)
Old 09-11-2018, 09:56 PM   #9
don't be a crapenter.
5280carpenter's Avatar
Trade: Finish Carpentry / Cabinets
Rewards Points: 142
Re: Cabinet Rails
I want to make sure I can get 2 good pocket holes in a rail for how I build face frames. That's the limiting factor IMO. If I'm trying to keep cost down, less drawers is less $. If they have deep storage elsewhere, I'd do 4 drawers in a 36" cab because client can more likely overload a deep 36" drawer and have me out for a warranty call.
5280carpenter is offline
Old 09-12-2018, 12:00 AM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 1,992
Re: Cabinet Rails
Originally Posted by 5280carpenter View Post
...I'd do 4 drawers in a 36" cab because client can more likely overload a deep 36" drawer and have me out for a warranty call...
why would you build with failure in mind?
griz is offline
pinwheel (09-12-2018)
Old 09-12-2018, 12:15 AM   #11
LRG WoodCrafting
Leo G's Avatar
Re: Cabinet Rails
He said he makes smaller drawers so they can't be overloaded preventing callbacks.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Wile E Coyote (09-12-2018)
Old 09-12-2018, 12:18 AM   #12
Fire up the BBQ
griz's Avatar
Re: Cabinet Rails
Didn't read it that way...
Still sounds confusing....
griz is offline
Old 09-12-2018, 12:35 AM   #13
LRG WoodCrafting
Leo G's Avatar
Re: Cabinet Rails
Not worried about my clients overloading drawers. Blum Tandem slides and dovetail drawers aren't going anywhere.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
KAP (09-12-2018)
Old 09-12-2018, 12:36 AM   #14
Fire up the BBQ
griz's Avatar
Re: Cabinet Rails
baby blue???....
griz is offline
Old 09-12-2018, 12:41 AM   #15
LRG WoodCrafting
Leo G's Avatar
Re: Cabinet Rails
Stratton Blue
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-12-2018, 02:58 AM   #16
Rewards Points: 142
Re: Cabinet Rails
Those look great. Just learning as I go. Still using cardboard drawer boxes and 3/4 extension side-mounts
Old 09-12-2018, 07:39 AM   #17
LRG WoodCrafting
Leo G's Avatar
Re: Cabinet Rails
What I've learned is use good hardware.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
B.D.R. (09-16-2018)
Old 09-12-2018, 08:03 AM   #18
tjbnwi's Avatar
Re: Cabinet Rails
I do a lot of 4’ drawers under cooktops. Those get pots and pans normally. These drawers get 3/8” plywood bottoms with supports, 5/8” solid maple sides, 569H slides instead of 563H slides and slide balance systems.
As Leo said, dovetails and good hardware.
Old 09-12-2018, 09:22 AM   #19
KAP's Avatar
Trade: Custom
Re: Cabinet Rails
Agreed... And more than a couple of screws like I see most use...
Only had one callback for Blum glides over the years... unfortunately it was when I learned that the lifetime warranty is in essence bogus as they shift all the costs onto the business that installed it...
To make a warranty claim, they want you to ship it back to be examined, at your cost (which costs almost as much as the glide), to determine if the glide failed, and IF it's determined the glide failed, then they will provide a new one... in the meantime, you've been to the customer, removed the glide, and unless you want to go back AGAIN after getting a replacement, you've replaced it with a new one at your cost... so you are basically underwriting their warranty... and the kicker is, it's not the cost of the glide, but the amount of hourly revenue you lose dealing with it...
The one saving grace, told my supplier about it, and they said if it ever happens again, they'd replace it...
Still an excellent product, but that left a sour taste in my mouth... apparently, we (us and our supplier) treat our customers better than they do...
KAP is offline
Old 09-12-2018, 09:41 AM   #20
LRG WoodCrafting
Leo G's Avatar
Re: Cabinet Rails
I don't deal with Blum. I deal with my supplier. If something fails, they deal with me.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Miter saws wooddan Tools & Equipment 77 05-13-2013 03:51 PM
The Showcase Cabinet Kent Whitten Carpentry Picture Post 54 12-30-2012 02:30 PM
Jorgy cabinet claws have gotten exspensive Jasen Finish Carpentry 4 09-22-2012 01:17 PM
Cabinet Rails & Stiles - Supplier blackte Finish Carpentry 3 04-03-2010 06:48 PM
