Building Wood Screen Doors - Carpentry - Contractor Talk
Old 09-22-2016, 08:56 PM   #1
Dan_Watson's Avatar
Rewards Points: 2,748
I am building 3 wood screen doors, a single door and a double door.
Before I go an re-invent the wheel, are there any good sources of info on design and building? Any good material sources?
Specifically t-astrigals, weather stripping, sweeps, and jamb stops.
Dan_Watson is offline
Old 09-22-2016, 09:10 PM   #2
TimNJ's Avatar
Rewards Points: 6,080
Re: Building Wood Screen Doors
Use really dry and smooth tight grain pine. Long dowels to keep it as dimensionally stable as possible or it will be "floppy" feeling.
I ordered a few wood screen/storm doors from a company in CO.
I forget their name. They always ran a constant ad in Fine Homebuilding.
You can get an idea of design and construction by checking out their catalog photos.
Astragal is very easy to make out of 5/4 on the table saw and then run a router down the edge for a little design.
TimNJ is offline
Old 09-22-2016, 09:14 PM   #3
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,272
Darcy should have some good input...
overanalyze is online now
Old 09-22-2016, 09:15 PM   #4
Dan_Watson's Avatar
The doors will be 6/4 Utile Mahogany.
With the astrigal is there an easy way of sealing it for insects?
Vintage Door?
Old 09-22-2016, 09:16 PM   #5
Dan_Watson's Avatar
But procurement of the machinery he is going to belittle me for not having is not in the budget.
The Following User Says Thank You to Dan_Watson For This Useful Post:
overanalyze (09-22-2016)
Old 09-23-2016, 05:59 AM   #6
TimNJ's Avatar
Vintage Door?
Some good quality foam tape. Not too soft it will fall apart and not too hard that it won't compress.
It will also absorb the sound when it closes so as not to bang.
TimNJ is offline
Old 09-24-2016, 03:34 PM   #7
tjbnwi's Avatar
Rewards Points: 2,832
CRT.
http://www.conservationtechnology.co...therseals.html
Building wood screen doors-img_3970-1-.jpg   Building wood screen doors-img_3976-1-.jpg   Building wood screen doors-img_3975-1-.jpg
tjbnwi is online now
Tom M (09-24-2016), Tom Struble (11-26-2016)
Old 09-24-2016, 08:38 PM   #8
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 5,512
Vintage Door?
I know Darcy usually uses Sapele (pretty much the same thing except I like Sipo) and was cutting the rail and stiles on his shaper. Now he would probably run a bunch of the parts on his sash sticker. He did a ton of them a few months back. If you don't have a shaper I've rabbeted out a tennon and mortise before on a table saw, not quite as good but works.
I know nothing about screen doors, our bugs down here break through the screens. But hey today it rained while it was sunny
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is online now
Old 09-24-2016, 08:46 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,794
I will give you my two cents tomorrow. My girls birthday has worn me out.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 09-24-2016, 08:59 PM   #10
tjbnwi's Avatar
Her birthday today?
If so we share the day.
Old 09-24-2016, 09:19 PM   #11
I like Green things
Originally Posted by tjbnwi View Post
Her birthday today?
It was on the 22nd.
Warner Mill Works
Facebook
YouTube
Old 09-24-2016, 09:27 PM   #12
Deckhead's Avatar
Trade: Carpentry,
It was on the 22nd.
Tell'em I said happy birthday! Those are some cool kids.
The Following User Says Thank You to Deckhead For This Useful Post:
WarnerConstInc. (09-24-2016)
Old 09-25-2016, 10:01 AM   #13
I like Green things
Weather stripping on a screen door is almost worthless. Tried several sweep styles on bottoms, none anymore.
Most of the knobs (kind that latch) suck, even ones that are solid brass and run 75 bucks each.
I just started using my sash sticker for all the parts now, I use traditional M &T joints on all my screen doors.
I know guys who use floating tenons (same concept as the big domino) an urathane glues.
I make separate screen frames for mine.
Warner Mill Works
Facebook
YouTube
hdavis (09-25-2016)
Old 09-25-2016, 08:47 PM   #14
tjbnwi's Avatar
I use the CRT receiver and sweep. So far no issues with them.
Building wood screen doors-img_3977-1-.jpg   Building wood screen doors-img_3978-1-.jpg
Justin Huisenga (09-25-2016)
Old 09-25-2016, 09:01 PM   #15
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,740
Vintage Door?
I've built a couple doubles. Used overlapping rabbets instead of an astragal. Kerfed the inside corner for RCT silibead. The RCT router makes the cut easy. You can also use a Pemko weatherstripping handsaw. It's technically designed for kerfing a jamb to accept interlock but I changed the tooth set on mine so it cuts about a 1/8" kerf for silibead.
Justin Huisenga is offline
Old 11-25-2016, 08:14 PM   #16
Dan_Watson's Avatar
Decided to skip the weather stripping on the jamb. Undecided on the sweep and door to door.
The Following 12 Users Say Thank You to Dan_Watson For This Useful Post:
BillD (01-11-2017), griz (11-26-2016), hdavis (12-31-2016), Justin Huisenga (11-25-2016), overanalyze (11-26-2016), Philament (11-25-2016), PRP (11-25-2016), rblakes1 (02-13-2017), Rio (11-26-2016), sunkist (11-26-2016), TLHWindows (12-01-2016), Tom Struble (11-26-2016)
Old 11-26-2016, 08:46 AM   #17
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Thats some good looking work !
But i smell a festool add in your future
sunkist is offline
Old 11-26-2016, 11:53 AM   #18
Dan_Watson's Avatar
The XL? If I do more doors it will be the first purchase, second will be a better (and larger) drum sander.
Old 11-26-2016, 01:11 PM   #19
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Any worry about warpage? I see lots of solid sash mahogany doors warp to crap.
Inner10 is offline
Old 11-26-2016, 02:43 PM   #20
I like Green things
Never had a screen door warp yet, but I am picky about the lumber I choose.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Warner Mill Works
Facebook
YouTube
Spraying new bare wood interior doors in the shop. Derek1157 Painting & Finish Work 13 04-06-2013 09:45 PM
Best Roller for Wood Shelves ? We Fix Houses Painting & Finish Work 8 03-22-2013 06:01 PM
Bad wood mystery ssroofpros Roofing 7 02-20-2013 09:54 AM
Roof rafters, floor joists. Wood to mortar contact. Baltimore Masonry 16 08-04-2012 02:58 PM
Any advice on building interior doors? pinwheel Finish Carpentry 4 02-03-2010 06:53 PM
