Best Trick You Learned From An Old Schooler - Page 43 - Carpentry - Contractor Talk
Old 05-15-2013, 10:19 PM   #841
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Re: Best Trick You Learned From An Old Schooler
I taught myself this one.
If your hanging something on walls etc. And need to be an 1", 1.5, 2" etc. Away from an adjacent object, instead of measuring it all out just use the width of blue painters tape.
For example i was hanging a mirror and i wanted it 2" away from the corner of the room. I just stuck some 2" painters tape on the wall and used that as a nice even 2" spacing from the corner.
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
The Following 2 Users Say Thank You to Rich D. For This Useful Post:
Mavis Leonard (05-16-2013), mikeswoods (05-21-2013)
Old 05-15-2013, 11:31 PM   #842
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Exclamation
On blueprints, call outs, doors, windows, plywood, reams of paper, etc.
WIDTH IS ALWAYS THE FIRST DIMENSION.
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
Rich D. (05-15-2013)
Old 05-16-2013, 12:14 AM   #843
Mavis Leonard's Avatar
Trade: Different phrases of construction
Rewards Points: 250
Originally Posted by tenon0774 View Post
I think the new guy took your line!
...or is paying homage to you.
My tricks from old timers:
A plumb bob attached to the cloth, or nylon end of a chalk line. It's compact, can be reeled in, and the weight of the chalk box, counteracts the weight of the bob: So no reason to keep a bob on a string.
(no chalk of course).
Using "catfish" fishing line for all my chalk boxes. It is a finer line than the "furry" cotton crap they stock cheaper boxes with.* (Tajima, excluded of course)
On your final pass of "level 4", with the halogen and a pencil, after you have sanded the room; mix your 20 or 45 with a puff of blue chalk.
So you won't have to hunt and peck for your final patches.
*This I pulled out of an old FHB.
i do tht it does tak morthan apuff
Mavis Leonard is offline
Old 05-16-2013, 12:16 AM   #844
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
Alritght then, a couple of puffs.
Better?
-Scott
tenon0774 is offline
Old 05-16-2013, 08:15 AM   #845
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
I'd say it depends on how big your puffs are! :-)
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
The Following User Says Thank You to svronthmve For This Useful Post:
tenon0774 (05-18-2013)
Old 05-17-2013, 08:19 PM   #846
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Taught myself this one. When doing concrete form work,especially footing forms,you can use an air nailer,just shoot through a wood shim.When you go to strip form,bust the shim with claw hammer,nail head gets exposed so you can pull it out of form.
fjn is offline
schaefercs (05-22-2013)
Old 05-18-2013, 12:18 AM   #847
Repair & Renovation
Rich D.'s Avatar
Or just use duplex's
Good trick when your in a bind though!!
Rich D. is offline
Old 05-18-2013, 01:01 AM   #848
Rewards Points: 250
iu nevr seen an air nailer tht will shoot doubleheaded nails.
Old 05-18-2013, 10:22 AM   #849
Repair & Renovation
Rich D.'s Avatar
I agree..
I hand bang my forms though..
Rich D. is offline
Old 05-21-2013, 04:56 PM   #850
Sabagley's Avatar
Trade: General contractor
Rewards Points: 880
Not really a trick, but a useful bit of math
Bills and behavior always come due.
Sabagley is offline
Old 05-21-2013, 08:46 PM   #851
steex's Avatar
Trade: repair and remodeling
Rewards Points: 510
Here, sabagley.
I still can't read it though, so here is a link that explains how to calculate the radius of an arc.
http://www.mathopenref.com/arcradius.html
steex is offline
The Following User Says Thank You to steex For This Useful Post:
Sabagley (05-21-2013)
Old 05-21-2013, 08:49 PM   #852
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 564
Originally Posted by steex View Post
Here, sabagley.
Or, nowadays you can do this faster with your smartphone. I have a free radius calculator saved in my browser. There are aps that do it too, but I am too cheap to pony up the $1.99
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Old 05-21-2013, 09:21 PM   #853
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
when swinging doors yourself use a small piece of 3/4'' pipe under the door. You can easily maneuver the door in place to get it screwed
ubcguy89 is offline
Old 05-21-2013, 11:24 PM   #854
Sabagley's Avatar
Rewards Points: 880
Maybe faster, but can you do it without them?
I've spent a lot of money on construction masters only to go back to the basics of a Ti-30XA. Why? Cause I can... Lol
Sabagley is offline
Old 05-21-2013, 11:57 PM   #855
RCCIdaho's Avatar
Trade: framing
Rewards Points: 119
Originally Posted by Sabagley View Post
....only to go back to the basics of a Ti-30XA.
There is an app for that too..
https://play.google.com/store/apps/d...RealCalc&hl=en
RCCIdaho is offline
Old 05-22-2013, 12:16 AM   #856
C2projects's Avatar
Trade: General Contracting
Rewards Points: 1,084
If you turn the blade on your circular saw backwards it will cut through vinyl siding like butter. ( just remember to turn it back around when you need to cut some wood again.)
Proper Prior Planning Prevents Piss Poor Performance
C2projects is offline
The Following User Says Thank You to C2projects For This Useful Post:
Gregory D (01-02-2014)
Old 05-22-2013, 12:19 AM   #857
Rewards Points: 250
ever tryit on alumiminunm
Old 05-22-2013, 12:27 AM   #858
Rewards Points: 250
not a trikc , but i was talkingto the 71 yaer old guy my uncl hired this spring. We are going to starta addition an remodle to a hous he helped build 50 yaers ago he said he jus got bakc to work hangin siding after lunch an a naighbor ran ovr from thehouse nex dooor an tol hm kennedy had beenkilled. damn peopl do remembr whrer they were. the mos amzingg part is this guy isstil working lik a champ 50 yeaers later. this fall we willl be strippin that same sidin off he was puttin on 50 yaers later.
The Following User Says Thank You to Mavis Leonard For This Useful Post:
Dmitry (05-25-2013)
Old 05-22-2013, 12:42 AM   #859
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Callbacks are a bitch.
Metro M & L is offline
The Following 4 Users Say Thank You to Metro M & L For This Useful Post:
A&E Exteriors (05-22-2013), hdavis (05-23-2013), wireless (05-22-2013)
Old 05-22-2013, 12:43 AM   #860
kiteman's Avatar
Rewards Points: 16
Cool story. I was in 8th grade math class.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Tags
tricks of the trade
Simple Old Trick for Finding Centers... basswood Finish Carpentry 9 10-03-2010 06:58 PM
trick lookin drip system wopachop Landscaping 1 09-29-2010 01:08 AM
Beware of this trick cleveman Off Topic (Non Trade) 3 04-17-2009 09:16 AM
Learned to post pics SAcarpenter Carpentry Picture Post 2 10-16-2008 07:28 PM
Learned A New Trick Today CJKarl Masonry 8 06-28-2008 06:33 AM
