Amateur Night: What's The Best Wood For Building A Fence? - Carpentry - Contractor Talk
Old 08-07-2019, 07:52 PM   #1
EarlVorhees's Avatar
Trade: landscaping
Rewards Points: 50
I imagine redwood heartwood but would you also want it pressure treated or is that overkill? Would you use the same wood also for the posts and kickers? I want to build the most long-lasting fence that I can with the best possible materials. Any help appreciated. My first fencing project.
EarlVorhees is offline
Old 08-07-2019, 08:01 PM   #2
KAP's Avatar
Trade: Custom
Rewards Points: 34,872
Re: Amateur Night: What's The Best Wood For Building A Fence?
No matter the cost?
KAP is offline
Old 08-07-2019, 08:13 PM   #3
Trade: landscaping
Rewards Points: 50
Originally Posted by KAP View Post
No matter the cost?
Wooden. And within reason. What's the top-shelf that most non-billionaires would purchase?
Old 08-07-2019, 08:19 PM   #4
KAP's Avatar
Trade: Custom
Therein lies the rub... what do you consider reasonable? I'm not trying to dodge your question, but you have to define your budget before you can determine the materials... it's an exercise in futility to come up with the best materials if they're not in the budget...
Is this for you or a customer? Because that's also a consideration as you as a contractor can get the materials for less so it gives you a little more flexibility in material choices depending on the budget...
KAP is offline
Old 08-07-2019, 08:34 PM   #5
Stunt Carpenter's Avatar
Rewards Points: 1,798
Go Vinyl,
Install is way easier and and not needing maintenance over the years pays back huge
https://builddaley.com/
Stunt Carpenter is offline
Old 08-07-2019, 10:02 PM   #6
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,374
Black Locust.
Then Clear Heart Redwood, with a tight grain pattern. Salvaged Old Growth if you can get it, older, tight Second Growth if you can't.
Then Ground Contact Rated PT. Douglas Fir.
Don't use Birch.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 08-07-2019, 10:05 PM   #7
Trade: Highwayman
Forgot about Western Juniper.
Probably as good as Black Locust.
Location is going to matter a lot. I'm on the West Coast, so just shipping Black Locust out here is gonna put it price-wise up there with salvaged OG Redwood.
Get Off My Lawn.
Old 08-07-2019, 11:12 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 2,630
4x6 posts on 6' centers.
soaked in and repainted with woodlife copper.
2x4 PT rails. re-painted with woodlife copper.
full 4/4 x 6' cedar fence boards.
Redwood if you can get it & afford it.
All fasteners are stainless steel.
the one at my house on the coast is 28 years old and just recently is in need of minor repair.
not cheap but you asked....
griz is online now
hdavis (08-08-2019)
Old 08-07-2019, 11:26 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 19,964
.40 or.60 ACQ. DF I had that stuff buried in the mud under my AC condenser (4x6) for 9 years and barely showed any signs of rot. It was constantly wet from irrigation year round as well.
Mike.
_______________
Calidecks is online now
Patrickstew (08-17-2019)
Old 08-08-2019, 05:30 AM   #10
hdavis's Avatar
Rewards Points: 3,948
50 year woods include black locust, Osage orange, Pacific yew. Heartwood only.
Constructively, those are post materials and tough to come by most places.
Old growth of some woods can approach that performance, especially redwood.
Imports like purpleheart can give you the best performance.
When you start factoring in workability, stability, availability, I'd go with black locust for the posts and old growth redwood for the rest. Fastening boards to hardwood backers isn't something that would be much fun.
hdavis is online now
griz (08-08-2019)
Old 08-08-2019, 08:37 AM   #11
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,069
Help us visualize. Whereabouts? What's the climate and soil type?
MarkJames is online now
Old 08-08-2019, 09:05 AM   #12
Mordekyle's Avatar
Rewards Points: 4,824
Lineal footage of fence?
Value of house?
Depth of pockets?
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Idothat (08-08-2019)
Old 08-08-2019, 07:11 PM   #13
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,966
i am west coast . did a seven foot recently .used 4x4 treated[below ground treatment] .should of used 4x6 for that height . shorter fence can handle 4x4 without wiggle .screws i believe are better then gun nailing . we use redwood for the face boards .
make sure post go in the ground . close to 3'. i only go close to 3 because thats as far as i can get with my demo hammer .clay out here is seriously hard . clean out the loose stuff [if you have any] from those holes before post and concrete go in .a shop vac will do this .
i tend to believe it is good to toss gravel in the bottom of hole so water can drain out of post . with this new treated maybe not an issue .it was what i was taught and maybe just putting the post against the dirt/bottom of the hole is fine .
So what lumber can you get where you are .Methods change with areas .
JFM constr is online now
Old 08-08-2019, 08:30 PM   #14
hdavis's Avatar
So true!
Old 08-08-2019, 08:33 PM   #15
hdavis's Avatar
Not the most durable choice, but I always wanted to use post oak posts. That's how post oak got it's name.
One of the white oaks, so it has good decay resistance.
Deckhead (08-10-2019)
Old 08-08-2019, 08:51 PM   #16
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,322
Concrete or metal posts. Ipe fencing.
Golden view is online now
The Following 3 Users Say Thank You to Golden view For This Useful Post:
Deckhead (08-10-2019), hdavis (08-08-2019), Patrickstew (08-17-2019)
Old 08-08-2019, 11:38 PM   #17
Dirtywhiteboy's Avatar
Rewards Points: 10,670
To keep from rotting and rusting we use a schedule 40 square tubing for the post. In come with holes in it so the water drains out. 2x4s screws to the sides and fence builds off of that. No wood in the ground here.
Dirtywhiteboy is offline
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
hdavis (08-09-2019), Rio (08-10-2019)
Old 08-09-2019, 12:14 AM   #18
Caleb1989's Avatar
Rewards Points: 290
Hat channel metal posts set in concrete. Then redwood or cedar 2x4 rails, and pickets. You can put a single picket on the backside of each post to hide the metal.
Caleb1989 is offline
Old 08-10-2019, 07:12 AM   #19
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 14,548
Ipe would last forever but it's a bitch fastening anything to it. You could get b-grade ipe cheaper then you could old growth redwood. B grade cumaru or massaranduba is even less expensive and looks a lot like ipe and performs almost as well.
Personally, I like white oak and it's as good as anything domestic outside. With a stain it's going to last years and years. Getting ready to do one, horizontal 4/4x6 and 4/4 ◊4 or 4/4◊4 and 4/4◊2 depending what they like more. It was going to either be oak or sapele and they chose the oak because of the contrast with the Ipe deck it abuts. Going to be cool.
If you're in the south, cypress is your best bet for longevity vs cost. Cypress lasts a long time outside especially if its stained. I supplied all the lumber for a treetop park in cypress and it's about 30,000 bd ft outside in Florida for the past 8 years and it's still going strong.
Dont make fun of the people who post from their moms basement... they're a little unstable.
Deckhead is offline
The Following User Says Thank You to Deckhead For This Useful Post:
Rio (08-10-2019)
Old 08-17-2019, 10:58 PM   #20
Patrickstew's Avatar
Trade: Exterior Remodel and Repair Contractor
Rewards Points: 286
PVC. HDPE. unless you donít live underwater in Charleston like Iím working with.
Sent from my iPad using Tapatalk
Patrickstew is offline
