7" Natural Crown - Carpentry - Contractor Talk
7" Natural Crown
Old 05-16-2014, 05:50 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 16,260
7" Natural Crown
Got asked to put up some 7" prefinished crown.
I could use some pointers on both the hugeness and the prefinishedness, as I don't often deal with either and have never done both at once.
I like doing butt joints for seams and coping my corners. Any reasons I should stray from this?
Also, what do you guys do for blocking on stock this big?
We're gonna need a bigger boat.
Easy Gibson is offline
Old 05-16-2014, 06:12 PM   #2
TRMolnar's Avatar
Rewards Points: 398
Re: 7" Natural Crown
Originally Posted by Easy Gibson
Got asked to put up some 7" prefinished crown. I could use some pointers on both the hugeness and the prefinishedness, as I don't often deal with either and have never done both at once. I like doing butt joints for seams and coping my corners. Any reasons I should stray from this? Also, what do you guys do for blocking on stock this big? We're gonna need a bigger boat.
Pre finished is always time consuming. Take your time, make sure all your blades are sharp and get good a splitting 16th's in your measurements.
How many linear feet?
I'd use a 2x2 or 2x3 for nailers - but make your own from 2x4's or 2x6's... I've never seen a 2x2 or 2x3 that was worth a chit. Depending on your spring you might even want to stack 1x's to compensate.
Truth be told I've never done a true 7" crown in one piece. Good luck If you go through with it!
TRMolnar is offline
The Following User Says Thank You to TRMolnar For This Useful Post:
markpage (05-18-2014)
Old 05-16-2014, 06:15 PM   #3
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,162
That is some big crown. Put it up primed and finish in place. Also you might have to cut it flat depending on your saw. When you do butt joints do you biscuit them?
overanalyze is offline
Old 05-16-2014, 06:47 PM   #4
avenge's Avatar
Rewards Points: 122
It's prefinished. And I don't have any advice except charge 3 times normal.
avenge is offline
Old 05-16-2014, 07:05 PM   #5
Thanks for the responses.
If I do this I'm going to have to either rent or buy a new saw. I don't have a slider so I can only handle 5 1/4 max and I cut it angled.
Linear footage is roughly ~150? It's a lot of work. Only one outside corner which is nice, but there's 4 22's.
I've biscuited my joints before but it's extremely time consuming and I didn't feel like it yielded results that were much better than I can get from just nailing solidly after lining my joints up by hand.
This would be for a guy I've done a lot of work for but who keeps insisting I work hourly on this current job(complained about this one in other threads). There's no way I'm doing 7" crown hourly.
Ok, one last laugh. I was painting this place a couple weeks ago and while I was there a hangaround from the GC crew that built the place was there supposedly doing punchlist work but really was standing around talking to me. He kept asking me questions about my technique or what have you. Acting like a big shot. Then he asked who was doing the trim. Told him I probably was. He said, "Oh yeah, probably do this in two hours, right? What do you charge, 50 an hour? Probably more for something like this right? 75?"
I just stared at him for a minute then said, "So you're saying you'll put up this crown for $100? You're hired."
What a maroon.
The Following User Says Thank You to Easy Gibson For This Useful Post:
mikeswoods (05-21-2014)
Old 05-16-2014, 07:08 PM   #6
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Measure twice,cut once,be extremely careful. Do not be the guy who said "I cut the board twice and it is still to short"
fjn is offline
Old 05-16-2014, 07:34 PM   #7
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
Get a big bottle of 2P-10 and activator..
Splinter is offline
The Following 3 Users Say Thank You to Splinter For This Useful Post:
kambrooks (05-17-2014), mikeswoods (05-21-2014), Mrmac204 (05-20-2014)
Old 05-16-2014, 07:41 PM   #8
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
I LOVE pre finished.....
Why you guys freak out about it is beyond me.....
JMPOV...
B,
PrestigeR&D is offline
Old 05-16-2014, 08:16 PM   #9
Always Learning
JMPOV...
Stain work we install pre finished, painted I prefer site finished. I have done the pre finished on painted, I just think the nails and seems turn out better if you finish after...IMHO.
Old 05-16-2014, 08:21 PM   #10
Kevin M.'s Avatar
Rewards Points: 2,164
Originally Posted by Splinter View Post
Get a big bottle of
Jack
Kevin M. is offline
Old 05-16-2014, 08:27 PM   #11
JMPOV...
Well obviously because I can't caulk and paint pre-finished maple. hah
Old 05-16-2014, 08:43 PM   #12
Wood Craftsman
Arrow
You'll be fine, take your time,,,,,,
B,
Old 05-16-2014, 08:59 PM   #13
Tenon Cutter's Avatar
Trade: Timber Framming, Framing and Trim Carpenter
Rewards Points: 80
I wouldnot recommend butt joints for this. Glue and a 22 degree scarf joint. If you have a 22 gauge micro nailer, use it to "stitch"your joint. If you are buying a new saw, also buy one of these for this project. You can get a Hitatchi reconditioned for about $100
Tenon Cutter is offline
Old 05-16-2014, 09:03 PM   #14
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,011
I did 8" prefinished crown with my 8" Hitachi slider. Not really that fun. Came out beautiful though. With crown that big 0.1 degree will make a difference.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 05-16-2014, 09:08 PM   #15
jb4211's Avatar
Rewards Points: 2,306
While this stuff is great, it doesn't flex much: expansion/contraction. If go with a more forgiving adhesive.
Jon
jb4211 is offline
Old 05-16-2014, 09:10 PM   #16
Dan_Watson's Avatar
Rewards Points: 2,748
Time for a Kapex and a miterfast?
Dan_Watson is offline
Old 05-16-2014, 09:52 PM   #17
Always Learning
Totally missed the natural maple. Get some test pieces and practice cutting on the flat. I like cutting on the flat for large crown.
Old 05-16-2014, 10:00 PM   #18
Time to hire some other schmuck to do this while I sit home and post on CT.
You want in? Exit 98.
The Following 2 Users Say Thank You to Easy Gibson For This Useful Post:
A&E Exteriors (05-16-2014), JackP23 (05-26-2014)
Old 05-16-2014, 10:01 PM   #19
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 14,466
I prefer cutting all crown flat
A&E Exteriors is offline
Old 05-16-2014, 10:42 PM   #20
skillman's Avatar
Rewards Points: 1,968
So if you do the job . What saw were you looking at buying .
skillman is offline
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Lotta wood, #1 common white oak, finished natural pinwheel Flooring Picture Post 18 05-31-2013 10:01 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 08:08 AM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
