40° Crown - Carpentry - Contractor Talk
40° Crown
Old 02-20-2015, 07:55 AM   #1
LockTalk's Avatar
Trade: Cabinet maker
Rewards Points: 264
40° Crown
Does someone have the formula for cutting crown flat (not nested) for the bevel and Mitre angle, I can do the math but I'm in a pinch to find the formula...
We make our crown custom and they like to make things difficult...
I can't cut it nested because it's "on top" crown fastened to the top of cabinets as to a face frame so it doesn't have a flat
I normally have a jig but someone in my shop threw my last one out and because of the size I can't just quickly whip one up
The angle is 40 degrees
Thanks
David
LockTalk is offline
Old 02-20-2015, 08:45 AM   #2
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Re: 40° Crown
http://www.construction-resource.com...wn-molding.php
This will help you
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Roofcheck (02-20-2015)
Old 02-20-2015, 11:38 AM   #3
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: 40° Crown
send barry a e mail at [email protected] see if he has the protractor ready for sale
pappagor is offline
Old 02-20-2015, 12:45 PM   #4
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Re: 40° Crown
Or buy the build calc app. It's got many great features.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Justin Huisenga (02-22-2015)
Old 02-20-2015, 12:49 PM   #5
LockTalk's Avatar
Rewards Points: 264
Re: 40° Crown
Originally Posted by Xtrememtnbiker View Post
Attachment 146538
LockTalk is offline
Old 02-20-2015, 12:50 PM   #6
LockTalk's Avatar
Rewards Points: 264
Re: 40° Crown
Originally Posted by Gus Dering View Post
Thanks
I have done both!
Also looking into that app
LockTalk is offline
Old 02-20-2015, 12:51 PM   #7
Rewards Points: 340
Re: 40° Crown
Yes, that is the app. Lots of guys on here use it. Has many handy calculators and layout tools on it. Had an excellent manual and at least one member on here is a beta tester for it and would be able to answer probably any question you had.
Old 02-20-2015, 01:41 PM   #8
Lanya LaPunta's Avatar
Rewards Points: 565
Re: 40° Crown
Here's a link that allows you to input your wall angle and the spring angle:
I believe that this is the one that was developed, years ago, by Joe Fusco ... may he rest in peace.
Before I bought my angle finder / crown calculator (and that was quite some time ago) .... used this all of the time (or at least I used Joe's ... which seems to be the same).
Lanya LaPunta is offline
Old 02-20-2015, 05:13 PM   #9
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: 40° Crown
get one of these and call it a day...
http://www.amazon.com/Bosch-DAF220K-...dp/B001MUHXQ6/
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 02-20-2015, 05:21 PM   #10
LockTalk's Avatar
Rewards Points: 264
Re: 40° Crown
Issue isn't finding the miter angle... I have the starett version works well it's the bevel angle I need to cut the crown flat
Thanks for everyone's help made it through the day and it turned out awesome, almost better then with my jig
LockTalk is offline
Old 02-20-2015, 05:36 PM   #11
m1911's Avatar
Re: 40° Crown
With the Bosch angle finder, you enter the spring angle, and the it gives you the miter and bevel angles
m1911 is offline
Old 02-22-2015, 05:25 PM   #12
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,738
Re: 40° Crown
Lock Talk
The Build Calc app that Travis recommended is excellent. It simplifies layout and in many ways is better than the Construction Master. The Bosch Angle Finder is also useful particularly for crown on the flat. Like you I typically use the Starret.
I'm interested to see the jig you would have normally used to cut this particular crown. If you make another post some pictures or a description.
Justin Huisenga is offline
Old 02-22-2015, 06:24 PM   #13
LockTalk's Avatar
Rewards Points: 264
Re: 40° Crown
Originally Posted by Justin Huisenga View Post
Lock Talk
I can post some pictures tomorrow when I get to the job, typically our crown is face nailed making a larger flat to cut in the up right position, however we just finished a large commercial job (it was our first commercial job ever) that required top mount crown and I hated it, since that job they have decided to make that crown our new standard and have it coming up on a number of jobs including a massive commercial golf course.
Part of what made this crown so hard is when they put it through the moulder the top angle didn't match the bottom angel (mounting angle) so when you cut it nested it could pivot so easily
After spending Friday cutting the crown laying down I think it's the way to go for our on top crowns, because they have no flat, all of our other crowns have a very large flat for nailing to face frames but when they designed this particular crown they also wanted to ensure the best yield out of the wood they had to use
I will post this crown and our standard and the jig I would use for that.
And after using the bevel feature on the saw (dewalt 12" non slider) I could see how the counter weight of the kapex would be beneficial. And if I did more I would consider it (I've only used it 3 times to cut one inch by 1/2" material) so I don't have a ton of experience with it but adjusting the bevel on the dewalt was tough to get down and look while holding the saw to lock it in place
LockTalk is offline
Old 02-23-2015, 07:46 AM   #14
LockTalk's Avatar
Rewards Points: 264
Re: 40° Crown
Lock Talk
Here they are...
First is the crown we have been using as of late... Told mount... Second is our standard face mount third is the jig I created for the new crown (still needs a pc on the btm as a stop, fourth is the jig style id normally use for our standard crown and and last is the new crown in the jig
-imageuploadedbycontractortalk1424695534.322514.jpg-imageuploadedbycontractortalk1424695546.803465.jpg-imageuploadedbycontractortalk1424695560.571044.jpg-imageuploadedbycontractortalk1424695572.320452.jpg-imageuploadedbycontractortalk1424695584.144566.jpg
LockTalk is offline
The Following User Says Thank You to LockTalk For This Useful Post:
Justin Huisenga (02-23-2015)
Old 02-23-2015, 07:19 PM   #15
Re: 40° Crown
Thanks for the pics.
I've had to install top mount a few times on frameless boxes never face frame. The crown I was using had a small flat milled into the back for fastening rather than the angle on yours.
The jigs you made look like they'd work fine in position. The only thing I'd do differently is to swap the full flat angled back with a ripped piece with the spring angle cut on the top like the quick sketch below. I'd be a little worried that the crown would tend to cup when they cut out as much material as they did in the crown you pictured. The open back would minimize the effect the cup would have on the cut. For the stuff I used I made the jig like the one pictured with a flat shelf on the fence leg instead of the angled one shown.
I hate cutting on the flat with a fixed miter saw. Sliders are much better for this.
Old 02-23-2015, 09:12 PM   #16
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,871
Re: 40° Crown
When I see someone in this age cut crown in box instead flat with compound cut I just live without saying uniting. I left and didn't say nothing.
tipitop is offline
Old 02-23-2015, 09:32 PM   #17
Re: 40° Crown
Crown is commonly cut in position in a miter saw with no compound cuts only simple miters. The advantages in both accuracy and speed are numerous. The jigs pictured are for doing so with an abnormal crown in a miter saw.
Old 02-24-2015, 01:16 AM   #18
m1911's Avatar
Re: 40° Crown
Perhaps it's better you don't say anything...
m1911 is offline
Old 02-24-2015, 01:19 AM   #19
GC/carpenter
Calidecks's Avatar
Rewards Points: 1,582
Re: 40° Crown
I have these, for cutting crown.
Calidecks is offline
Old 02-24-2015, 01:21 AM   #20
m1911's Avatar
Re: 40° Crown
Well of course you do. Mr. fancy, I weigh buck fiddy...
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Calidecks (02-24-2015)
Crown molding and pilasters in party hall TIGHTER MITER Finish Carpentry 1 02-23-2013 05:59 PM
How would you price this crown job? MarkJames Finish Carpentry 25 01-15-2013 11:15 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 08:08 AM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
