25'x25' Deck W/ Roof HELP! - Carpentry - Contractor Talk
Old 07-21-2016, 03:24 PM   #1
CTC Builders's Avatar
Rewards Points: 38
I have a customer that wants an extremely out of the ordinary deck and I have a few questions.
To give you a little knowledge.
-Ranch Single Story Home
-House Roof angle 23 Deg.
-Roof over deck not attached to house but at the same direction of the slant as if it was getting attached to the back side of the house against the wall not roof.
-Open concept porch roof (No Ceiling rafters, Just cross supports/rafters)
-Fully shingled roof w/ siding on end caps of the roof.
For a 25'x25' Deck w/ Roof what is span I can get away between master support posts(6x6) w/ concrete tube footing? And will I need the posts from deck surface to cross member for extra support? See Fig A
Due to the long span of the rafters will I need the cross supports as shown in Fig B?
Answers will lead to questions... Appreciate everyones help
CTC Builders is offline
The Following User Says Thank You to CTC Builders For This Useful Post:
country_huck (07-23-2016)
Old 07-21-2016, 03:28 PM   #2
Rewards Points: 38
Re: 25'x25' Deck W/ Roof HELP!
Figures (These figures do not represent the deck size/style anything..)
25'x25' Deck w/ Roof HELP!-untitled.png
Old 07-21-2016, 04:12 PM   #3
Dan_Watson's Avatar
Rewards Points: 2,748
Where are you located? Some of those terms must be regional.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
aaron_a (07-24-2016)
Old 07-21-2016, 04:13 PM   #4
Dan_Watson's Avatar
Before you get bashed, they are pretty simple questions for a somewhat complicated build.
I would say you are way over your head.
And you may want to consult an engineer and architect for a design.
Old 07-21-2016, 04:25 PM   #5
Rewards Points: 38
Its not complicated. About any dumb **** can build a pergola. Only concern is the 24' span. Illinois is where I am located.
Not ever person knows the weight to support calculation and center span.
If this was a 16'x16' I wouldn't even be on here talking to you all.
Old 07-21-2016, 04:27 PM   #6
Rewards Points: 38
Your an a$$hole.
Old 07-21-2016, 04:30 PM   #7
Dan_Watson's Avatar
Apparently not.
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
aaron_a (07-24-2016), onmywayup (07-21-2016)
Old 07-21-2016, 04:31 PM   #8
Dan_Watson's Avatar
Your an a$$hole.
And I am bowing out of this one before it is closed.
Old 07-21-2016, 04:37 PM   #9
Rewards Points: 38
Pergola does not have nearly as many factors as what im dealing with. Pergolas that distance typically get mounted to the house. The design that is on the house side is different framing from a pergola. If you do not recall **** brick that pergolas have typically a 16" overhangs which distributes the weight of the rafters more evenly
Old 07-21-2016, 04:38 PM   #10
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 5,476
Your an a$$hole.
You ain't seen nothin yet. There's a couple books and tables you need to be reading before going around calling people assholes, it's readily available span tables. If any dumbass can do it... Why ask?
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is online now
Old 07-21-2016, 04:38 PM   #11
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 11,486
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Cole is offline
The Following 7 Users Say Thank You to Cole For This Useful Post:
builder2345 (07-28-2016), Calidecks (07-21-2016), Deckhead (07-21-2016), heavy_d (07-21-2016), onmywayup (07-21-2016), slowsol (07-21-2016), Warren (07-21-2016)
Residential Flat roof Nac Roofing 15 04-28-2018 08:46 AM
Roof gone Bad! Round Dormers, Anyone have experience with them? stombaugh85 Roofing 10 01-03-2013 09:42 AM
Roof top Deck issue mandaloril Decks & Fencing 22 04-24-2012 10:19 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
