Humidifier - HVAC Picture Post - Contractor Talk
Humidifier
Old 02-15-2014, 08:08 PM   #1
Broods's Avatar
Trade: Hvac
Humidifier
I installed a General Aire 1042 for a customer in a 2000 sq' house. On a high velocity system. The system is wired properly cause the solenoid opens and water flows on a call for humidity. The customer has a hygrometer upstairs and registers 27% relative humidity. We can't get the RH up any higher is the problem. New house. New air handler. High Velocity system works well enough according to the customer. Humidifier is attached to the return with a 2"insulated bypass from the 8" supply on top of the air handler. Water supply was recently changed to the hot side hoping that would help with no success. The side of the humidifier is a 6" opening that I've installed a 6"cap and attached the 2" bypass as per the air handlers manufacturers instructions. Yes, the damper is open. Has anyone got any suggestions?
Broods is offline
Old 02-16-2014, 12:24 AM   #2
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Humidifier
2" bypass?
cleveman is offline
The Following 2 Users Say Thank You to cleveman For This Useful Post:
belangerheating (02-18-2017), TimelessQuality (02-16-2014)
Old 02-16-2014, 10:47 AM   #3
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,532
Re: Humidifier
I don't think that humidifier is the best fit for a high velocity system
http://www.37flash.com/
flashheatingand is offline
Old 02-16-2014, 11:40 AM   #4
Broods's Avatar
Trade: Hvac
Re: Humidifier
What humidifier would you recommend? Yes, 2" bypass. It's for a high velocity air handler. 2" is recommended by the air handlers manufacturer.
Broods is offline
Old 03-01-2015, 05:09 AM   #5
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,256
Re: Humidifier
When you connected it to the hot water line. Was this the how water pipe at the water heater. Or just one that was near the humidifier? Needs to be at the water heater. Can't be bigger then 1/4" either, and you may need to insulate it. Have the water temp set up to 140F.
What is the air handlers heat source. Is it a hydrocoil, electric strip? Is the bypass before or after the heat source.
Probably should have ran a 6" pipe off the humidifier for about 2 foot, then attached the 2" line. So more of the humidifiers pad got air going across it.
beenthere is offline
Old 03-01-2015, 11:31 AM   #6
GettingBy's Avatar
Rewards Points: 6,486
Re: Humidifier
Does anyone make single room humidifiers that mount in walls or in ducts, for local control? I could use one myself.
GettingBy is offline
Old 03-01-2015, 11:49 AM   #7
beenthere's Avatar
Trade: HVAC
Re: Humidifier
Aprialiare makes one that mounts in a closet, and another that mounts through the floor. Both are designed to do a whole house though.
The Following User Says Thank You to beenthere For This Useful Post:
GettingBy (03-01-2015)
Old 03-01-2015, 04:07 PM   #8
GettingBy's Avatar
Re: Humidifier
So you will get short-cycling if used for just one room?
Old 03-01-2015, 04:38 PM   #9
beenthere's Avatar
Trade: HVAC
Re: Humidifier
Probably.
Old 03-01-2015, 04:51 PM   #10
GettingBy's Avatar
Re: Humidifier
Maybe one of these can be adapted to add small quantities of moisture to the air
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 03-01-2015, 05:01 PM   #11
beenthere's Avatar
Trade: HVAC
Re: Humidifier
Maybe. I didn't bother to look at the search results.
Old 03-01-2015, 06:21 PM   #12
GettingBy's Avatar
Re: Humidifier
This search or the first should work.
Old 03-01-2015, 06:26 PM   #13
beenthere's Avatar
Trade: HVAC
Re: Humidifier
Those are all for ducts systems.
If you just want one room. You will nee a portable room humidifier.
HE100 humidifier wiring problem cleveman HVAC 2 12-10-2013 03:19 PM
humidifier question cleveman HVAC 8 11-24-2013 08:08 PM
Does a humidifier lower your cooling costs? BCConstruction General Discussion 27 07-04-2012 10:46 AM
Humidifier cleveman HVAC 7 01-16-2009 12:24 AM
Rheem Classic 90 humidifier trouble norcim HVAC 5 11-26-2008 02:12 AM
