WB Lacquer? - Painting & Finish Work Picture Post - Contractor Talk
WB Lacquer?
Old 06-10-2013, 10:49 AM   #1
MSLiechty's Avatar
Trade: Bender Of Nails
Rewards Points: 428
WB Lacquer?
When I'm forced to finish trim, I used to spray nitro lacquer But wanted to give water based a try on an upcoming trim project. Anyone have any recommendation or tips for spraying with an airless?
ML
MSLiechty is offline
Old 06-10-2013, 10:58 AM   #2
KAP's Avatar
Trade: Custom
Rewards Points: 40,334
Re: WB Lacquer?
MlCampbells makes a great WB...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
MSLiechty (06-10-2013)
Old 06-10-2013, 11:25 AM   #3
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Re: WB Lacquer?
MLCampbell makes a LOT of great stuff!
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
The Following User Says Thank You to CompleteW&D For This Useful Post:
KAP (06-10-2013)
Old 06-11-2013, 12:38 PM   #4
DKnafo's Avatar
Trade: Kitchen Refacer
Rewards Points: 250
Re: WB Lacquer?
I use Target Coatings. I am happy with the product.
DKnafo is offline
The Following User Says Thank You to DKnafo For This Useful Post:
jkfox624 (06-11-2013)
Old 06-11-2013, 06:04 PM   #5
Kent Whitten's Avatar
Rewards Points: 2,040
Re: WB Lacquer?
Yeah, spray it light. It will run on you if it is too heavy. Even the slightest bit heavy will run. I tried some a few years ago, it leaves a nice finish, but it was difficult for me to spray. Took longer to dry as well.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 06-11-2013, 06:48 PM   #6
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
Re: WB Lacquer?
Targets EM7000 high build lacquer you can spray pretty heavy. I Spray as much as i can flat though so dont have a ton of input on the sags. I notice the first coat dries alot slower than the second. But still usually coatable in 30-45 mins.
jkfox624 is offline
Old 06-11-2013, 07:06 PM   #7
DKnafo's Avatar
Rewards Points: 250
Re: WB Lacquer?
You really do notice the extra recoat time especially when you want to do both sides of a door.
DKnafo is offline
Old 06-12-2013, 04:39 PM   #8
GCTony's Avatar
Rewards Points: 494
Re: WB Lacquer?
I've never sprayed WB with an airless but someone told me they use a fine finish tip with pretty good results, not furnature quality but better than a brush or roller.
We use Target and Sherwin Williams Kem Aqua.
GCTony is offline
The Following User Says Thank You to GCTony For This Useful Post:
MSLiechty (06-12-2013)
Old 06-12-2013, 07:00 PM   #9
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Re: WB Lacquer?
Spraying wb lacquer with an airless will prove difficult. Microfoaming occurs easily at high pressure, and you will most likely witness it.
JHC is offline
Old 06-12-2013, 07:52 PM   #10
MSLiechty's Avatar
Rewards Points: 428
Re: WB Lacquer?
I have always used fine finish tips for nitro lacquer. Sounds like WB will be a learning curve
ML
Old 06-13-2013, 08:26 AM   #11
GCTony's Avatar
Rewards Points: 494
Re: WB Lacquer?
ML, If you're just spraying trim onsite, you may want to look into an inexpensive HVPL turbine and gun. Using a airless could be a pain not to mention the amount of material you would be waisting because of the hose. I've never tried but you may even get a pretty good finish with a good quality airless cup gun. I'm not sure what you call them but Wagner Power Painter comes to mind.
I was "forced" (kicking and screaming) to go with the new cutting edge WB finishes when I turn my "hobbie shop" into a professional shop. I also thought the learning curve would be a painful one. However I personally think once you learn how the WB finishes work, I find I like working with them better than solvent finishes.
The reason I was forced to go WB is I didn't have a compliant spray booth or even a system in place to even come close to being compliant. OSHA, EPA, Fire Marshal and the tons of recordkeeping required was going to take a lot of money so going "green" was going to be the only reasonable way to continue doing our own finishing. At the end of the day, I have no regrets getting away from the high VOC finishes.
GCTony is offline
The Following 3 Users Say Thank You to GCTony For This Useful Post:
jkfox624 (06-13-2013), MSLiechty (06-14-2013), Railman (06-13-2013)
Old 06-13-2013, 10:43 AM   #12
Jeff
jkfox624's Avatar
Rewards Points: 502
Re: WB Lacquer?
I got an asturo gun with a pressure pot. Run off my little compressor. Its a low CFM gun so you can run it on about anything. I think i got the pot, gun and 3 nozzles for $400. Has HTE and HVLP air caps.
jkfox624 is offline
The Following User Says Thank You to jkfox624 For This Useful Post:
Old 10-31-2013, 08:44 PM   #13
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Re: WB Lacquer?
I have used both of these and they both work great...I keep the EM7000 around and use it as my standard finish.
http://www.targetcoatings.com/produc...n-lacquer.html
http://www.targetcoatings.com/produc...d-lacquer.html
EDIT: How did I end up in a 4 month old thread?
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
MSLiechty (11-03-2013)
Old 03-07-2014, 11:29 AM   #14
Finish Carpenter
TBFGhost's Avatar
Re: WB Lacquer?
Just as an edit, I am thinking about moving to EM8000 Conversion Varnish as a standard finish now...it has a very nice feel to it when its dry...supposed to be more chemical and water resistant as well.
TBFGhost is offline
MSLiechty (03-08-2014)
Old 03-28-2014, 04:12 PM   #15
GCTony's Avatar
Rewards Points: 494
Re: WB Lacquer?
I really like the Target products, especially the CV. Seems very durable and has a nicer "glow" for a water borne.
However, last week I decided to check out the M.L. Campbell Aqualente that our local Wurth store. I think it's my favorite of the month. I tinted it with a touch of yellow and raw umber (universal tint) to give it a little "glow" to the unstained soft maple.
So far I've tried Crysalac (horrible product, never again) Both Target EM6000 and EM8000 CV are very good but find the CV a little unforgiving for those of use that aren't great at spraying. I don't like that you can't purchase from a brick and mortar store. I like the SW Kem Aqua, very similar to the M.L. Campbell. Both can be purchased locally.
Next on my list to try is General Finishes Enduro. It's looks a little pricey about $50 gal
GCTony is offline
MSLiechty (03-30-2014)
Test for Conversion Varnish vs. Lacquer DaVinciRemodel Finish Carpentry 10 01-18-2011 10:44 AM
catalyzed lacquer on different surfaces ? Laketahoedan Painting & Finish Work 2 04-24-2010 08:06 PM
Quick question...Acrylic lacquer over oil based stain? BKFranks Painting & Finish Work 13 01-04-2010 08:30 AM
Gloss Lacquer to Satin Lacquer Finish ak_aiken Painting & Finish Work 7 08-05-2009 10:34 AM
Cabinet finishing with Lacquer sclancy Painting & Finish Work 3 05-02-2009 07:43 AM
