Load Bearing Wall Help - Remodeling Picture Post - Contractor Talk
Old 08-15-2017, 02:37 PM   #1
CUEUPU's Avatar
Trade: Home Remodel/Carpentry
Rewards Points: 16
So I am removing this wall that was partitioning the family room/living room from the kitchen and dining area. In addition to this wall, I am also removing a shed that is accessed from the outside and making it part of the interior remodel by bricking up the exterior access door and installing window.
My question: Is an LVL beam required in my case? If so, what is the minimum suggested? The entire width of the house that the ceiling joists run are 24'. The joists are butted together on top of a partitioning beam that runs the full length of the house. Seems to be double 2x4s.
Once shed is removed the open space will become approximately 24'x16'.
I am under the assumption that I need an LVL or at least some 2x6s to run as a beam directly underneath this double 2x4 partitioning beam and it will be supported by triple 2x6 or 2x4??
Please see attached pictures.
Thanks in advance!
Load bearing wall help-img_3821.jpg   Load bearing wall help-img_3822.jpg   Load bearing wall help-img_3818.jpg   Load bearing wall help-img_3816.jpg   Load bearing wall help-img_3817.jpg
Load bearing wall help-img_3819.jpg   Load bearing wall help-img_3820.jpg   Load bearing wall help-img_3823.jpg   Load bearing wall help-img_3824.jpg   Load bearing wall help-img_3825.jpg
CUEUPU is offline
Old 08-15-2017, 03:01 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 8,480
Re: Load Bearing Wall Help
You need load calculations to see what size beam you need. Contact your architect and have him do that because this has to go for a building permit.
greg24k is offline
The Following 4 Users Say Thank You to greg24k For This Useful Post:
Calidecks (08-29-2017), hdavis (08-21-2017), ScipioAfricanus (08-22-2017), Workingmanvan (08-21-2017)
Old 08-15-2017, 04:29 PM   #3
TimNJ's Avatar
Rewards Points: 5,712
I'd be willing to bet it's going to take more than a beam made out of 2x6's.
I have a flush beam running the width of my house (24').
It got spec'd as a triple 16" microlam.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
greg24k (08-15-2017)
Old 08-16-2017, 11:23 AM   #4
CUEUPU's Avatar
Rewards Points: 16
The beam won't run the width of the house, but rather the 16' span from end of house to far left of kitchen entry.
CUEUPU is offline
Old 08-16-2017, 12:31 PM   #5
CliffsConstruct's Avatar
Rewards Points: 4
Most reputable lumber yards can help you with load calculations (like ProBuild formerly Carter-Lee here in Indianapolis). They will ask you a few questions like load span and what is above the load. Then they will guide you to what size beam you need and then sell you that beam. That part is simple.
As for temporary walls and installation that will be on you.
CliffsConstruct is offline
The Following 2 Users Say Thank You to CliffsConstruct For This Useful Post:
A&E Exteriors (08-21-2017), SmallTownGuy (08-22-2017)
Old 08-21-2017, 12:48 AM   #6
Workingmanvan's Avatar
Trade: Carpenter-Renovations/Repairs
Rewards Points: 276
All of this is in the building code. Best to have permits and proper structural plans drawn up. Especially if you are asking on an internet forum, no offense but it sounds like you don't know much about framing. Find someone who does. Who understands point loads, etc.
Workingmanvan is offline
Old 08-21-2017, 03:40 PM   #7
Dan_Watson's Avatar
Rewards Points: 2,748
Well that header is doing a lot
Might want to get a professional in there sooner than later.
Dan_Watson is offline
The Following 6 Users Say Thank You to Dan_Watson For This Useful Post:
A&E Exteriors (08-21-2017), Calidecks (08-22-2017), greg24k (08-22-2017), Jaws (08-22-2017), Rio (08-23-2017), Workingmanvan (08-22-2017)
Old 08-21-2017, 10:31 PM   #8
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 14,488
Do yourself a favor and hire this out before you hurt someone
A&E Exteriors is offline
The Following 2 Users Say Thank You to A&E Exteriors For This Useful Post:
Old 08-22-2017, 01:13 AM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,372
Just remember, a load bearing wall cannot be longer than 62 feet by code.
Mike.
_______________
Calidecks is offline
Old 08-22-2017, 06:53 PM   #10
Renaissance Man
superseal's Avatar
Rewards Points: 5,840
When we guess, we just use 18" lvl
Load bearing wall help-img_0450.jpg   Load bearing wall help-img_0446.jpg   Load bearing wall help-img_0482a.jpg
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
A&E Exteriors (08-22-2017), greg24k (08-22-2017)
Old 08-22-2017, 08:11 PM   #11
Agreed ...when in doubt build it stout...not with a 2x6...lol
.i was guessing when i did this and went with 11 7/8
Rio (08-23-2017), superseal (08-22-2017)
Old 08-22-2017, 08:14 PM   #12
To be fair I was out of 2x10 and had these
Old 08-29-2017, 10:30 PM   #13
BattleBornNV's Avatar
Trade: General contractor
Rewards Points: 422
If I had to guess, I'd say 6.75x28.5 GLB F2 3000'r 1.8E
Because guessing with someone else's life isn't my business, that will carry a semi truck.
But, start here and call an engineer. Or call AITC direct, or Weyerhaeuser, or Boise-Cascade, or Rosboro.
http://www.aitc-glulam.org/pdf/Capacity/DF_25.PDF
BattleBornNV is offline
The Following User Says Thank You to BattleBornNV For This Useful Post:
A&E Exteriors (08-30-2017)
Load bearing wall removal Quality5280 Carpentry 1 09-06-2016 10:18 PM
Load bearing wall mikem201 Framing 2 01-21-2013 04:26 PM
Sagging floors, over spanned joists, load bearing walls without support and more technique Remodeling 104 05-14-2010 04:16 AM
Load Bearing Wall SLAVE DRIVER Construction 7 05-24-2008 08:27 AM
