Wow! That Was A Big Explosion! Guy Did His Own Plumbing! - Off Topic (Non Trade) - Contractor Talk
Old 12-01-2013, 05:06 PM   #1
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 2,670
I did significant work on this house 7-8 years ago. We framed it and dried it in for a guy, who then did all the mechanical himself and finish out himself. He then moved, and someone else lived there up until last night. They're saying it was caused by a propane leak in the basement.
Not one log wall left standing. The pics in the link aren't great, but you can see the round log ridge beam (probably 30' long) sticking out of the ground.
My buddy who lives 10 miles away was woken up by it.
http://www.khou.com/news/texas-news/...233999511.html
Bearded Wonder is offline
Old 12-01-2013, 05:12 PM   #2
tjbnwi's Avatar
Rewards Points: 4,772
Re: Wow! That Was A Big Explosion! Guy Did His Own Plumbing!
There was something similar in Indianapolis (NG not LPG), they determine to was intentional. Charged the homeowners with murder, they killed one of their neighbors.
tjbnwi is offline
Old 12-01-2013, 05:51 PM   #3
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,526
Unfortunately 'tis the season...in NW Ohio we've had 3-4 explode in similar fashion...scary!
mstrat is offline
The Following User Says Thank You to mstrat For This Useful Post:
camaroman2125 (12-02-2013)
Old 12-01-2013, 06:33 PM   #4
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
This is exactly why i will not touch propane lines for any reason! I have customers get upset with me, even my helper is like "we can do this" but i flat out refuse to do it. Way too much risk IMO. I know LP is quite safe to work with and rarely do problems occur but i still will not risk it. Call a certified tech who is properly insured is what i tell them.
If something were to happen where a loss of life happened due to my negligence i do not know what i would do.
woodchuck2 is offline
Old 12-01-2013, 06:53 PM   #5
tyb525's Avatar
Trade: Remodeling and Carpentry
Spray it down with soapy water to ensure no leaks. Is it that hard to do?
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 12-01-2013, 07:05 PM   #6
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Duh, they should have known better than to build a house with the ridge beam sticking out of the ground like that.
cleveman is offline
The Following User Says Thank You to cleveman For This Useful Post:
MTN REMODEL LLC (12-02-2013)
Old 12-01-2013, 07:20 PM   #7
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Pretty slow leak to take 8 years to build up
Just because the original builder did his own plumbing, don't assume he caused this.
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
flashheatingand (12-02-2013)
Old 12-01-2013, 07:46 PM   #8
Trade: General
Originally Posted by TimelessQuality
Pretty slow leak to take 8 years to build up Just because the original builder did his own plumbing, don't assume he caused this.
That's a good point. Might be totally unrelated to anything he did. I'll reserve judgement.
Old 12-01-2013, 07:57 PM   #9
Boondockian
Dustincoc's Avatar
Trade: Getting the job done
Rewards Points: 1,018
From the pics, I'd say it was more than gas leak. I don't see anything that appears burned in the pics, which I would expect from a gas leak. Looks more like some sort of pressure wave hit it.
In the words of General James Mattis: "Be polite, be professional, but have a plan to kill everybody you meet."
Captain Howdy: We must all go through a rite of passage, and it must be physical, it must be painful, and it must leave a mark.
Dustincoc is offline
Old 12-01-2013, 08:03 PM   #10
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Gas explosions can put the self out I have seen a couple of the insides of flats where it blew the external wall out yet no sign of burns anywhere.
www.bcconstructionllc.com
BCConstruction is offline
Old 12-01-2013, 08:10 PM   #11
90%-er
onmywayup's Avatar
Rewards Points: 2,462
I'm the same way. I get asked all the time about gas line jobs and I know I can handle it conceptually, but it's just flat out above my pay grade. I always politely refer them to a plumber Licensed to work with gas lines. Just not worth the money for the risk man
onmywayup is online now
Old 12-01-2013, 11:19 PM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
LP is down right dangerous compared to natural gas.
Inner10 is offline
Old 12-01-2013, 11:23 PM   #13
tyb525's Avatar
How? Natural gas has more btu's per unit doesn't it? Just curious.
tyb525 is offline
Old 12-01-2013, 11:26 PM   #14
Inner10's Avatar
Less...but that's not the problem. Propane is less buoyant than air and it settles, methane is lighter and rises up and finds it's way out of your home.
Inner10 is offline
The Following 4 Users Say Thank You to Inner10 For This Useful Post:
flashheatingand (12-02-2013), MTN REMODEL LLC (12-02-2013), onthelevel (12-07-2013), rselectric1 (12-02-2013)
Old 12-01-2013, 11:42 PM   #15
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
That doesn't work as well as you think it does.
jlsconstruction is offline
Old 12-01-2013, 11:54 PM   #16
tyb525's Avatar
Thanks for letting me know, both of you. Apparently I was taught wrong (no surprise).
tyb525 is offline
Old 12-01-2013, 11:56 PM   #17
Oconomowoc's Avatar
Trade: construction
Rewards Points: 2,000
If you know what you are doing LP isn't any different than natural gas.
According to statistics the biggest threat are non-licensed plumbers cross contaminating potable water with sewage etc.
Oconomowoc is offline
Old 12-02-2013, 10:37 AM   #18
Diggity's Avatar
Trade: General
I bet a bunch of these are caused by CSST. If you dont know what that is it is Corregrated Stainless Steel Tubing it is thin stainless tune with a plastic covering. I am not a HVAC contractor but did work for one so I felt comfortable doing my own gas line for a new stove. I did the research on this product because it would have made it really easy to do. But what I learned was scary! The problem with this stuff is that it is pretty thin so you can bend it around corners. When installing this stuff you can not let it touch any metal because if there is lightning and the house is not bonded correctly the lighting travels up the pipe finds the metal its touching and arcs to it making a small whole in the pipe. At this point two very bad things will happen eather you have a blow torch if the gas comming out has been lit or you have a whole in your gas pipe and it fills your house up until it finds a source of ignition. They sell this stuff to Joe the home owner at Home Depot and is much easier to install then black pipe and cheaper. Also to the guy who said to bubble check it that is not a very safe way of checking your work. I have done reading on the subject and I have been told stories about guys bubble checking lines then going back and presure checking them and finding a leak. When I put the gas line in my house I found a couple reducers untill I got the pipe to fit a air fitting and put a shut off valve on too. I used my air compressor to fill the line with 125lbs of air and I did this with the new stove in place because I also read about guys finding leaks in new apliences. That side held the presure. Then I checked the other side of the line (from the shut off on the meter to where it comes into the house and found a leak in the pipe I didnt touch and is underground. Went outside and I could hear the air comming out of the gas meter. Went to look and there was a 2 inch crack in the body of the meter! Called the gas company and they came and replaced it. I wonder how much gas went into the air that we paid for? Any way my point is if I just bubble checked it I never would have found that leak by the road. And it gives me piece of mind that if my gas line will hold 125 lbs it will hold the 1 or 2 lbs pressure your gas line is.
Diggity is offline
Old 12-02-2013, 10:44 AM   #19
Inner10's Avatar
Cheaper than black iron? Not in material.
Inner10 is offline
Old 12-02-2013, 10:47 AM   #20
Box Builder
Morning Wood's Avatar
Rewards Points: 10,386
I've got the stainless corrugated going in my home remodel right now. We tip toe around it.
Did you see the woman's husband was out of town at the time. Uh oh.
Morning Wood is offline
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Seeking C-36 Plumbing RMO designbymind New Member Introductions 0 01-29-2013 12:47 AM
Looking for Plumbing or Landscaping work in Central Arkansas. Joshd123 Help Wanted or Looking For Work 0 03-03-2010 09:13 AM
DIYers in the Plumbing Forum 22rifle Plumbing 49 06-22-2008 11:42 PM
