Wholy Shmokes - Off Topic (Non Trade) - Contractor Talk
Wholy Shmokes
Old 07-24-2014, 01:20 AM   #1
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
Wholy Shmokes
sprinkler fitters get done adding a new head they leave , 30 minutes later drops of water start dripping from joint , moments later pipe joint completely fails , no one in building knows how to shut off water , water runs full blast for 30 minutes , 4-5 inches of water on floor . 15th floor of a 22 story building . I was standing 6 ft infront of pipe when it blew full blast right to the mouth . trying to put bucket under drops of water before it blew apart, that was the 2nd grossest water I ever drank. millions of dollars worth of damage .
every hallway and stairway gutted from 15 floor and down a couple complete condo gut outs .
oldrivers is offline
Old 07-24-2014, 01:38 AM   #2
jb4211's Avatar
Rewards Points: 2,306
Re: Wholy Shmokes
Holy smokes is right!!!
Jon
jb4211 is offline
Old 07-24-2014, 05:09 AM   #3
Big Shoe's Avatar
Rewards Points: 2,056
Re: Wholy Shmokes
Hope they have insurance.
Expect the Unexpected
Big Shoe is offline
Old 07-24-2014, 05:34 AM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Wholy Shmokes
i didn't do it
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Jaws (07-28-2014), j_sims (07-24-2014)
Old 07-24-2014, 07:11 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,786
Re: Wholy Shmokes
Can you imagine the mess it will be if they get it in the code book to do sprinklers in new homes like they would like.
Randy Bush is online now
Old 07-24-2014, 07:15 AM   #6
jb4211's Avatar
Re: Wholy Shmokes
Time to go into the sprinkler business. lol
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
Randy Bush (07-24-2014)
Old 07-24-2014, 08:37 AM   #7
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,180
Re: Wholy Shmokes
I've heard of the glass bulk sprinkler heads coming defective. A job a was working on had one that was leaking pretty bad, but didn't blow.
On the same job, a guy stuffed a box full of linseed oil soaked rags that combusted the same night. That water is NASTY stuff.
Was this an actual joint in the pipes or the head?
dielectricunion is offline
Old 07-24-2014, 05:23 PM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 176
Re: Wholy Shmokes
It is in the current IRC (International Residential Code) which most of the U.S. is using now and it also applies to additions over a certain size or if so much of the existing walls and ceilings are opened up (depends on the local's rules).
It's a giant rip off, unneeded (because of the ubiquity of smoke alarms), lots of times the meter has to be upped which means the street has to be torn up to bring in a larger water line and the systems have to be tested periodically adding another expense to the homeowner.............
Rio is online now
Old 07-24-2014, 06:58 PM   #9
Randy Bush's Avatar
Re: Wholy Shmokes
It is not adopted into the local code here yet, still being fought against.
Old 07-24-2014, 07:40 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 86
Re: Wholy Shmokes
And in rural America, there are no streets or waterlines. Good luck with that.
Tinstaafl is offline
Old 07-24-2014, 08:35 PM   #11
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,658
Re: Wholy Shmokes
Pressure tank dry system.
Inner10 is offline
Old 07-24-2014, 08:39 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 86
Re: Wholy Shmokes
Sure, or just require that every new house be equipped with a 20,000 gallon water tower. Give me a break.
Old 07-24-2014, 08:45 PM   #13
Inner10's Avatar
Re: Wholy Shmokes
Consider yourself lucky that you will probably be dead from old age before it's mandated....but sadly for all of us that may not be all that long.
Inner10 is offline
The Following User Says Thank You to Inner10 For This Useful Post:
Tinstaafl (07-24-2014)
Old 07-24-2014, 10:36 PM   #14
Designer/Contractor
Rio's Avatar
Rewards Points: 176
Re: Wholy Shmokes
From what I've heard that is what is basically being required where the jurisdictions are forcing compliance. The fire sprinkler lobby paid off the code council and this is the result.
All of these organizations and bureaucracies have one goal, to grow like giant tumors on the world we work in, to be ever more intrusive and ever more demanding with the cost be damned.
Rio is online now
Old 07-24-2014, 10:41 PM   #15
Balding quickly
BattleRidge's Avatar
Trade: The big stuff!
Rewards Points: 588
Re: Wholy Shmokes
Yeah in the last bastion of AMERICA! We don't need no sprinklers.
www.battleridgebuilders.com
BattleRidge is offline
The Following User Says Thank You to BattleRidge For This Useful Post:
Old 07-27-2014, 10:51 PM   #16
oldrivers's Avatar
Rewards Points: 522
Re: Wholy Shmokes
the building im guessing was built in the mid 70s using the iron pipe , but this remodel they used that orange plastic pipe not sure why they didn't just use iron , the joint itself failed not sure why but they are examining it at some laboratory last I heard . feel bad for them one of the units that needs gutting was just remodeled a few years ago .
Old 07-27-2014, 11:51 PM   #17
GC/carpenter
Calidecks's Avatar
Rewards Points: 1,390
Re: Wholy Shmokes
I just did a 2000 sq. ft. Whole house remodel that include adding a master bed, bath and hallway. It had to be sprinklered. They only had to run from the Meter, 1-1/4". The whole enchilada was 4800 bucks. That included everything but the supply, which my plumber did.
Calidecks is online now
Rio (07-28-2014)
Old 07-28-2014, 08:01 AM   #18
Designer/Contractor
Rio's Avatar
Rewards Points: 176
Re: Wholy Shmokes
From what I've been told if the meter is 3/4" which is very common on older houses then it won't be big enough and they'll have to go up to at least a 1" meter. When they do that they have to bring in a 1" line from the main to the meter.
Rio is online now
Old 07-28-2014, 10:51 AM   #19
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 1,828
Re: Wholy Shmokes
I don't have a meter or a main like Tin. Actually I'm about 15 miles away from a main.
I got buckets and a hose, this whole code thing is more than a little out of line. Going to kill the industry in the language of "safety".
Deckhead is online now
The Following User Says Thank You to Deckhead For This Useful Post:
Rio (07-28-2014)
Old 07-28-2014, 01:38 PM   #20
jb4211's Avatar
Re: Wholy Shmokes
You were misinformed.
Water meters for fire suppression are a totally different animal.
Fire suppression meters cannot restrict water flow by more than 50%, despite being clogged with miscellaneous debris common in water lines: rocks, sediment, etc. Due to this fact, they require a basket strainer. Also, fire suppression meters START at 3" and go up from there.
If the meter is going to do double duty, fire suppression and drinking water, it will need to be two meters in one, such as a Neptune Protectus Water Meter.
Jon
jb4211 is offline
