Things I Hate (2) - Page 69 - Off Topic (Non Trade) - Contractor Talk
Things I Hate (2)
Old 03-12-2019, 01:45 PM   #1361
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,230
Re: Things I Hate (2)
At least the police are taking it for prints, around here they tell you deal with it and go through your insurance. They file a report and move on
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
The Following User Says Thank You to Stryker1-1 For This Useful Post:
cedarboarder (03-15-2019)
Old 03-12-2019, 03:13 PM   #1362
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,952
No they take prints and do **** all with them.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
cedarboarder (03-13-2019), Stryker1-1 (03-12-2019)
Old 03-12-2019, 03:28 PM   #1363
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 496
Originally Posted by Tom M View Post
Upper and lower ball joints, lower tie rod, wheel alignment, front brakes, oil change, fuel and air filter the same time. Oof
How about I have a coolant leak I think it's a freeze plug, the leak is under my feet (e350 van), tech "o no it's the rad" me "you sure that one is not that old, have you put it up in the air", Tech "no need I can see it's the rad".
5 hours later "hey man you got a freeze plug leaking" "let me guess left hand side of the motor".
Next morning "hey man your water pump is leaking" "are you sure that one is not that old"
Next day "hey man a bolt that holds the water pump on broke", "wow after I told/warned you that is what happened the last time with a water pump and I had to replace the timing cover"
$1150 dollars later get the van back drive 10 miles truck stops charging drop off truck Monday morning get home look at where the truck was parked fresh coolant on the ground, me "hey man when you c/k out my alt that not working c/k out the coolant leak.
Next day "hey man your thermostat housing is leaking and your alternator is junk" me "well we are running out of stuffo that can leak on my coolant system"
A week later "hey man your van is ready', I pick up the van after $400 dollars drive 12 miles the truck overheats I have to leave the truck in a parking lot to cool off for 2 hours, drop off the truck Monday am get it back Thursday so far so good ?.
All this in the last month.
Still "Shakin" the tree boss
sunkist is offline
The Following 2 Users Say Thank You to sunkist For This Useful Post:
cedarboarder (03-12-2019), Tom M (03-12-2019)
Old 03-12-2019, 06:34 PM   #1364
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 700
At 4:00 this afternoon it was 70 degrees… My wife calls me a little after 4 and says they just canceled school for tomorrow.
We supposedly have a blizzard headed our way. 8 – 10 inches with 50 MPH winds. Supposed to hit about 10 tomorrow morning and be done by 6pm.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
Lettusbee (03-12-2019)
Old 03-12-2019, 07:41 PM   #1365
hdavis's Avatar
Rewards Points: 2,024
So, you hate being stuck at home with the wife and kids....
hdavis is online now
Old 03-12-2019, 07:54 PM   #1366
Rewards Points: 700
We’re empty nesters so we can do that any time!
I hate the sudden change…
And that I have to go to work tomorrow… unless it hits before 7.
hdavis (03-13-2019)
Old 03-12-2019, 08:10 PM   #1367
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,512
Trying to move my shop and getting slammed with more work than I can handle.
Sent from my SM-N960U using Tapatalk
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 03-12-2019, 08:25 PM   #1368
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,947
What a terrible problem.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 03-12-2019, 08:49 PM   #1369
I like Green things
It sucks.
Warner Mill Works
Facebook
YouTube
hdavis (03-13-2019)
Old 03-12-2019, 08:49 PM   #1370
Stryker1-1's Avatar
When my mechanic tells me I've got a misfire on my number 3 cylinder.
Looks like I won't waste money on new tires
Now to find a new truck
Old 03-12-2019, 09:01 PM   #1371
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,804
Did your mechanic discover what was causing the misfire?
Idothat is offline
Old 03-12-2019, 09:05 PM   #1372
LRG WoodCrafting
Leo G's Avatar
Misfires are usually simple fixes. Bad plug, shoddy coil.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-12-2019, 09:08 PM   #1373
I like Green things
Unless it's a 6.4 PSD, then its completely justified to find something different.
Warner Mill Works
Facebook
YouTube
Old 03-12-2019, 09:11 PM   #1374
hdavis's Avatar
Low compression, faulty injector, clogged injector, bad injector signal, ...
Old 03-12-2019, 09:12 PM   #1375
hdavis's Avatar
$5K to do anything....
Old 03-12-2019, 09:12 PM   #1376
LRG WoodCrafting
Leo G's Avatar
Ya, I think in terms of gas engines, not diesel. Injectors are an expensive fix.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-12-2019, 09:16 PM   #1377
I like Green things
Its 5k to pop the hood and go, yup that's your problem, it's a 6.4. Lol
Warner Mill Works
Facebook
YouTube
hdavis (03-12-2019)
Old 03-12-2019, 10:42 PM   #1378
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,625
I hate taking the Iid off a bucket in the cold without gloves.......because I hate gloves.
Jay hole is offline
Old 03-12-2019, 11:45 PM   #1379
Idothat's Avatar
You had me scared, talking about taking the lid off a bucket in the thing I hate thread
Idothat is offline
The Following 3 Users Say Thank You to Idothat For This Useful Post:
cedarboarder (03-13-2019), hdavis (03-13-2019), Tinstaafl (03-13-2019)
Old 03-13-2019, 10:56 AM   #1380
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,932
I hear ya. im looking at sprinters, ram promasters, and the ford transits.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
The Following User Says Thank You to cedarboarder For This Useful Post:
Stryker1-1 (03-13-2019)
Things I Don't Understand txgencon Off Topic (Non Trade) 563 06-05-2015 05:09 PM
49 Things People From Upstate New York Love Dustincoc Off Topic (Non Trade) 2 04-28-2014 10:54 PM
What you call things Okiecontractor Off Topic (Non Trade) 116 03-11-2014 07:52 PM
Things you like for a business website. flashheatingand Marketing & Sales 20 06-04-2011 10:57 PM
