Things I Hate (2) - Page 172 - Off Topic (Non Trade) - Contractor Talk
Things I Hate (2)
Old 09-14-2019, 03:31 PM   #3421
Dirtywhiteboy's Avatar
Rewards Points: 11,720
Re: Things I Hate (2)
Originally Posted by Leo G View Post
Throw it into the waste burner and produce heat for the cooler seasons. 100% for your advantage.
I don'i even know what a waste burner is or why I'd ever want to produce heat it's in a contractor bag with shredded paper in a 5gl. bucket and will be garbage.
Dirtywhiteboy is online now
Old 09-14-2019, 03:34 PM   #3422
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 15,295
A waste burner is essentially an oil fired furnace with a lot of filtration on the input end. And here it gets cold in the winter and if you collect the oil you can heat for less or free.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 09-14-2019, 03:35 PM   #3423
Radical Basement Dweller
Robie's Avatar
Rewards Points: 284
Lots of garages use them around here.
When the debate is lost, slander becomes the tool of the losers.
Robie is offline
Old 09-14-2019, 03:38 PM   #3424
LRG WoodCrafting
Leo G's Avatar
Exactly. If you are pulling in 100s gallons a month, why wouldn't you use it to heat your place? Otherwise you need to have a company pick it up and pay them to do it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 09-14-2019, 07:35 PM   #3425
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 322
I don't think they do "heat" in Hawai'i.
Tougher Than The Rest.
SmallTownGuy (09-14-2019)
Old 09-15-2019, 07:25 AM   #3426
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,664
Originally Posted by A&E Exteriors View Post
Time for some new framing guns
Check and see if the end of the driver is rounded. I'm betting a new driver will fix it.
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
A&E Exteriors (09-15-2019), mrcat (09-15-2019)
Old 09-15-2019, 07:32 AM   #3427
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,254
Shhhh, hes just looking for an excuse to buy new tools.
Big Johnson is offline
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
A&E Exteriors (09-15-2019), Bull Trout (09-19-2019), SmallTownGuy (09-15-2019)
Old 09-15-2019, 09:15 AM   #3428
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,576
Hell, last time I used my framing hammer - same thing happened.
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
Bull Trout (09-19-2019), Morning Wood (09-18-2019)
Old 09-15-2019, 09:27 AM   #3429
LRG WoodCrafting
Leo G's Avatar
Check to see if the face is rounded over
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
hdavis (09-16-2019)
Old 09-15-2019, 09:31 AM   #3430
John the Builder
Old 09-16-2019, 09:47 AM   #3431
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,576
Miss I have to try and clean up today so can get done with this job.
Sent from my KYOCERA-E6790 using Tapatalk
Randy Bush is offline
Old 09-16-2019, 10:07 AM   #3432
John the Builder
So last week, I've got a hack repair to an underground, homegrown hack water supply line to a hack, home grown apartment, They punched it thru cinder block foundation, then fed that black plastic for a supply. Appears they managed to damage the line EXACTLY where it clamps onto the inside galvy. So it leaks. Typical hack repair attempts, silicone caulk, some sort of epoxy, tape, etc.
So there I am, breaking out some bits of block around this junction - which they made EXACTLY where it passes thru the block - no room to access/repair it.
The only tool/weapon of choice at hand is two claw hammers - place the claws of one against the block, smack the face with the other one.
This took about an hour all told, in very confined space, and all the while I'm doing this I'm thinking "God, I am so glad no one is around to watch me do this hack bull ****.
The claws were pretty well junk by the time I got done.
Oh well, HD has more.
The Following User Says Thank You to SmallTownGuy For This Useful Post:
overanalyze (09-18-2019)
Old 09-16-2019, 10:07 AM   #3433
hdavis's Avatar
Rewards Points: 1,342
That's some messed up...
hdavis is online now
Old 09-16-2019, 10:08 AM   #3434
John the Builder
Sir,
That is gnarly looking.
Randy Bush (09-16-2019)
Old 09-16-2019, 10:17 AM   #3435
hdavis's Avatar
It's like there us some time space distortion bubble that makes it impossible to do anything but hackery. And they put the pipe right there.
Old 09-16-2019, 04:48 PM   #3436
rblakes1's Avatar
Rewards Points: 3,348
That I ran out of paint with about 20 sf left to go.
At least there was a SW less than 10 minutes away
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
hdavis (09-16-2019)
Old 09-17-2019, 05:04 PM   #3437
META's Avatar
Trade: General and Trades
Rewards Points: 4,538
That looks like potentially an improperly racked nail, as in not fully parralel or in the chamber when the firing pin hit it. Is it doing that consistently or the nails bunching up from weakened nail collation?
META is offline
The Following User Says Thank You to META For This Useful Post:
A&E Exteriors (09-17-2019)
Old 09-17-2019, 05:13 PM   #3438
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,884
Frequently. All my framers are well used
A&E Exteriors is offline
Old 09-17-2019, 05:20 PM   #3439
META's Avatar
Bummer. I know when the chamber gets wore out and expanded, the nails will get messed from improper alignment to firing pin.
Super Max are nice...
META is offline
A&E Exteriors (09-18-2019)
Old 09-17-2019, 08:08 PM   #3440
A good framing gun will go almost forever,, I have 2 that are about 30 years old. I know what breaks and keep parts for them.
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
A&E Exteriors (09-18-2019), Calidecks (09-17-2019)
Things I Don't Understand txgencon Off Topic (Non Trade) 678 07-26-2019 02:02 PM
49 Things People From Upstate New York Love Dustincoc Off Topic (Non Trade) 2 04-28-2014 10:54 PM
What you call things Okiecontractor Off Topic (Non Trade) 116 03-11-2014 07:52 PM
Things you like for a business website. flashheatingand Marketing & Sales 20 06-04-2011 10:57 PM
