Things I Hate (2) - Page 104 - Off Topic (Non Trade) - Contractor Talk
Things I Hate (2)
Old 05-16-2019, 09:03 PM   #2061
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 3,020
Re: Things I Hate (2)
Originally Posted by Calidecks View Post
One of the biggest things I was taught coming up through the years is ALWAYS be kind to the people that come after you. Especially as a framer. Nail placement was a biggie as well. Try not to put any blind nails in triplers. Also no nails in the middle of bays on the top top plate unless the nailing schedule dictates otherwise. Think like an electrician with an auger.
Mike.
_______________
Man I wish I could afford to hire you to come train some of the wood butchers I follow.
Sent from my LG-LS993 using Tapatalk
TxElectrician is online now
The Following User Says Thank You to TxElectrician For This Useful Post:
Calidecks (05-16-2019)
Old 05-16-2019, 09:04 PM   #2062
META's Avatar
Trade: General and Trades
Rewards Points: 3,074
Originally Posted by Robie View Post
If I'm going to be out in the woods or a field, I use these:
Permetherin for the clothes and 98% Deet for the skin.
Attachment 476055
Attachment 476057
I buy concentrated permethrin and then dilute it and treat my gear.
META is offline
Old 05-16-2019, 09:20 PM   #2063
Bull Trout's Avatar
Rewards Points: 492
Originally Posted by Easy Gibson View Post
Another day in the Pacific Northeast.
70 and sunny there too?
Bull Trout is online now
Old 05-16-2019, 09:24 PM   #2064
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,100
Finally, yes.
Today was perfect.
Easy Gibson is online now
Old 05-16-2019, 09:48 PM   #2065
rblakes1's Avatar
Rewards Points: 3,016
Originally Posted by hdavis View Post
Something with that many holes I would have trenched with a circ saw and save the pieces. Much faster to patch.
Seriously! Snap 2 lines 6-8" apart and cut, would've been done with that before he got to hole 10
-Rich
rblakes1 is online now
The Following User Says Thank You to rblakes1 For This Useful Post:
Robie (05-16-2019)
Old 05-16-2019, 09:52 PM   #2066
rblakes1's Avatar
Vinyl cove base. Seemingly so simple, but those damn outside corners. I had 5 pieces to install with 7 outside and 2 inside corners.
I should've just gone with wood. Wood and I have an understanding, vinyl cove I just have disdain
-Rich
Old 05-16-2019, 09:55 PM   #2067
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,625
Never seen one mitered. They just bend them around the corner.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 05-16-2019, 10:20 PM   #2068
rblakes1's Avatar
I did bend them around, but realized after a while I needed to lower my standards on it and accept the fact that there is no way to get the lip to bend properly and keep its shape.
-Rich
Old 05-17-2019, 02:08 AM   #2069
VinylHanger's Avatar
Rewards Points: 9,918
There's a corner cutter that 45s the bend. It gouges out the vinyl so it goes around the corner.
https://www.tools4flooring.com/crain...ase-gouge.html
VinylHanger is offline
The Following 3 Users Say Thank You to VinylHanger For This Useful Post:
hdavis (05-17-2019), rblakes1 (05-17-2019), SmallTownGuy (05-17-2019)
Old 05-17-2019, 04:12 AM   #2070
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,734
-Rich
Why anyone uses that stuff for anything is beyond me.
Big Johnson is offline
Seven-Delta-FortyOne (05-18-2019)
Old 05-17-2019, 07:59 AM   #2071
KAP's Avatar
Trade: Custom
Rewards Points: 33,402
-Rich
You can use the corner cutter above or alternately, Heat gun, dry fit to mold, then glue...
KAP is online now
The Following User Says Thank You to KAP For This Useful Post:
Frank Castle (05-17-2019)
Old 05-17-2019, 09:09 AM   #2072
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,234
Standard stuff on commercial.
SmallTownGuy is offline
Old 05-17-2019, 09:24 AM   #2073
hdavis's Avatar
Rewards Points: 1,660
That's the fast way. You can do it by hand with a utility knife, but it's a pain.
hdavis is online now
rrk (05-23-2019)
Old 05-17-2019, 10:41 AM   #2074
John the Builder
That last store front I did for our retail experiment, jeez, had I don't know how many running feet of vinyl cove.
Outside corners, scored the inside with utility, then heat-gunned them to conform. Turned out OK.
Almost bought the skivving tool, but the skinflint in me prevailed.
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
Frank Castle (05-17-2019), hdavis (05-17-2019)
Old 05-17-2019, 02:34 PM   #2075
Tom M's Avatar
Rewards Points: 3,000
I had VCT done and vinyl cove this week I'm on municipal job finally. sure enough they opened the door and never did the pieces behind the doors he had to go back.
To contour they carved out the back a little bit and use the heat on it doesn't really look that great.
Tom M is offline
Old 05-17-2019, 02:38 PM   #2076
Tom M's Avatar
I hate ripping out a nasty eave to access framing and getting peppered with paint chips, dirt, blown in insulation and birds nests.
Fortunately it's warm out today so it's stuck behind my neck and back before down my pants.
Tom M is offline
Old 05-17-2019, 03:37 PM   #2077
Fricken mice. I'm still continuing the battle. Spent a day a couple weeks ago completely sanitizing and carpet extracting.
Three days ago, more mice. Set 4 traps, got 2. Got none last night. Spent this morning resanitizing.
Hopefully I got them.
Suburban, same thing. 6 traps last night, got one. Got one night before last.
Trying some Tomcat mouse spray. Hopefully it helps. Reviews are a mixed bag.
On the positive, the truck smells like cinnamon, jasmine, eucalyptus and peppermint instead of the normal sweaty shirt smell.
dayexco (05-17-2019), SmallTownGuy (05-17-2019), Tom M (05-17-2019)
Old 05-17-2019, 06:24 PM   #2078
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,970
Do you use bait stations to poison them?
I had a huge mouse problem as well and those worked great. I still have a couple in my garage that I keep an ion it to see if there’s any activity but it pretty much solved my mouse problem
Windycity is online now
Old 05-17-2019, 06:56 PM   #2079
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,300
When the new neighbor comes over with his kids to ask if they can use my concrete driveways to skateboard on.
Nope, sorry...not trying to be a jerk but pretty soon it escalates.
No matter the reason...you still come across as a jerk.
Get off my lawn.
Immigration is not supposed to change the character of the nation.
Immigration is supposed to change the character of the immigrant.
Robie is online now
Old 05-17-2019, 07:58 PM   #2080
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,882
yeah.. next thing you know... come home to a skate park on your drive way with 20 kids. slippery slope.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
The Following User Says Thank You to cedarboarder For This Useful Post:
Robie (05-17-2019)
Things I Don't Understand txgencon Off Topic (Non Trade) 563 06-05-2015 05:09 PM
49 Things People From Upstate New York Love Dustincoc Off Topic (Non Trade) 2 04-28-2014 10:54 PM
What you call things Okiecontractor Off Topic (Non Trade) 116 03-11-2014 07:52 PM
Things you like for a business website. flashheatingand Marketing & Sales 20 06-04-2011 10:57 PM
