Things I Hate - Page 917 - Off Topic (Non Trade) - Contractor Talk
Things I Hate
Old 08-02-2016, 09:32 AM   #18321
VinylHanger's Avatar
Rewards Points: 10,306
Re: Things I Hate
Originally Posted by hdavis View Post
Or seal the leak from the outside and keep driving it.... Maybe $20 and half an hour.
The way it is designed, It won't seal. So you need to take the flange nut off, the not drop the flange into the pan, try and seal the threads, then goop crap on the flange, then try and get the nut back on and hope it seals. All while not dropping the flange.
If you drop the flange, you then need to pull the turbo and lift the engine to get the pan out to get the flange out. Even if you then ordered the external fix part I just got, you have already dropped the flange accidentally and left the internal O-ring in the pan which will get sucked up the oil intake tube and starve the system.
I am a decent mechanic. The main problem is we have one rig, live in the country and don't have anyone close by for a ride if I forget something. So something small becomes a big problem if I am missing anything. Or the starter lug breaks...
VinylHanger is offline
Old 08-02-2016, 09:38 AM   #18322
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Re: Things I Hate
I'm too paranoid for that. I have to have two autos, and I live alone. I like to be able to run get parts or take my time on some repair work. I have two motorcycles two if I need them.
RangoWA is offline
Old 08-02-2016, 09:47 AM   #18323
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,273
Re: Things I Hate
Can't afford that. All the stuff is easy fixes, just a lot in a row. The factory oil leak fix is a crapshoot. The part I got is a sure fix. Never had a starter lug snap off before.
Your story proves otherwise...
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 08-02-2016, 10:24 AM   #18324
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,348
Re: Things I Hate
Ugh cars.
I hate when, despite using the same beans, pot, water, and filters, I sometimes end up making a crappy cup of coffee. What the hell is that? Is it me? The cup?
Easy Gibson is online now
Old 08-02-2016, 10:36 AM   #18325
RangoWA's Avatar
Trade: General
Re: Things I Hate
Originally Posted by HardGibson View Post
Ugh cars.
Try roasting your own, grinding and running through the machine. No two cups seem to be the same. Only a few have been intolerable though.
RangoWA is offline
Old 08-02-2016, 10:42 AM   #18326
Re: Things I Hate
I can't argue that.
Old 08-02-2016, 10:49 AM   #18327
aaron_a's Avatar
Trade: Remodeling and fine carpentry
Rewards Points: 2,238
Re: Things I Hate
Ugh cars.
Maybe its the brewer? Some get too hot sometimes, or they get dirty.
I usually do french press or pour over and its always good.
aaron_a is offline
Old 08-02-2016, 11:56 AM   #18328
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 3,094
Re: Things I Hate
Coffee snobs. Folgers in a drip maker works every time.
TxElectrician is offline
The Following User Says Thank You to TxElectrician For This Useful Post:
peteo (08-02-2016)
Old 08-02-2016, 12:03 PM   #18329
Re: Things I Hate
Coffee is for girls.
Old 08-02-2016, 01:28 PM   #18330
RangoWA's Avatar
Trade: General
Re: Things I Hate
That's not coffee, it's flavored water.
RangoWA is offline
Old 08-02-2016, 01:31 PM   #18331
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,324
Re: Things I Hate
Just for a daily pot of java, I went back to an electric percolator 2-3 years ago and it suits me and my tastes. I use Maxwell House.
If I want to get fancy, I use the French Press and custom ground beans.
Haven't tried roasting my own and probably never will.
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Old 08-02-2016, 04:12 PM   #18332
Trade: Electrical
Re: Things I Hate
Be that as it may, it's worked for over 40 years
The Following 2 Users Say Thank You to TxElectrician For This Useful Post:
A&E Exteriors (08-07-2016), Robie (08-02-2016)
Old 08-02-2016, 04:21 PM   #18333
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
Re: Things I Hate
Cowboy coffee is COFFEE !!!
You pour some grounds in a pot of boiling water. Then let the grounds settle. It'll wake you up ! And put hair in all sorts of places !
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
aaron_a (08-02-2016)
Old 08-02-2016, 04:28 PM   #18334
aaron_a's Avatar
Re: Things I Hate
Good stuff.
I used to make Turkish coffee when I worked in a coffee shop.
Like cowboy coffee, but you use finer grounds and add some cardamom and sugar
aaron_a is offline
Old 08-02-2016, 04:41 PM   #18335
RangoWA's Avatar
Trade: General
Re: Things I Hate
Might as well snort it.
RangoWA is offline
Old 08-02-2016, 04:43 PM   #18336
Re: Things I Hate
Turkish coffee is wild.
The first time I had it I refused milk and sugar, thinking I knew what I was doing.
After a couple sips I was left wondering why my company didn't alert me to my mistake.
Old 08-02-2016, 04:50 PM   #18337
Drywall Slave
blacktop's Avatar
Rewards Points: 214
Re: Things I Hate
I waited for that...Till after I drank the Coffee !
blacktop is offline
Old 08-02-2016, 04:52 PM   #18338
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,084
Re: Things I Hate
That's how we made it when camping, the second it breaks out in a boil you throw in a cold cup of water and all the grounds sink to the bottom.
It's kinda like French Press coffee.
Inner10 is offline
Old 08-02-2016, 04:53 PM   #18339
Inner10's Avatar
Re: Things I Hate
Originally Posted by aaron_a View Post
Good stuff.
That stuff is intense, I'd take an espresso first...Turkish is a little sandy in texture.
Inner10 is offline
Old 08-02-2016, 04:57 PM   #18340
Re: Things I Hate
I am now rethinking my skills as a mechanic. Go to tighten the new starter cable nut and it snaps just like the old one. Now I am waiting for. ride to get a new one, at 30 bucks more. At least they are swapping it out.
The Following User Says Thank You to VinylHanger For This Useful Post:
Morning Wood (08-05-2016)
Electricians-Thanks for keeping things safe!! Kevin M. Electrical 17 11-30-2014 09:41 PM
Things you like for a business website. flashheatingand Marketing & Sales 20 06-04-2011 10:57 PM
What do you do different, let's here the little things that you do that set you apart Mike Finley General Discussion 63 06-14-2010 01:43 PM
A Sign That Things Are Improving? rstarre General Discussion 1 06-12-2010 01:52 PM
Boy...things are getting REALLY bad!!! finehomes Vehicles 12 10-27-2009 01:46 PM
