There Has Got To Be A Better Way To Split Logs - Off Topic (Non Trade) - Contractor Talk
Old 03-16-2019, 01:12 PM   #1
rrk's Avatar
Rewards Points: 48
I wonder of the guy in the 2nd one is still alive
https://www.youtube.com/watch?v=3ks_lbtgJSw
rrk is online now
The Following 3 Users Say Thank You to rrk For This Useful Post:
Rio (03-16-2019), sunkist (03-16-2019), Xtrememtnbiker (03-16-2019)
Old 03-16-2019, 01:28 PM   #2
Lettusbee's Avatar
Rewards Points: 1,906
Re: There Has Got To Be A Better Way To Split Logs
He's gonna make everybody that wears Crocs look like a moron!
Lettusbee is online now
Old 03-16-2019, 01:37 PM   #3
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Rewards Points: 1,038
WTF!! Crazy
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
Old 03-16-2019, 02:40 PM   #4
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,890
I'd use the first one.
TheConstruct is online now
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
deckman22 (03-17-2019), rrk (03-16-2019)
Old 03-16-2019, 03:42 PM   #5
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
So: no change then...
SmallTownGuy is offline
The Following 5 Users Say Thank You to SmallTownGuy For This Useful Post:
B.Johnson (03-17-2019), griz (03-16-2019), Lettusbee (03-16-2019), TheConstruct (03-17-2019), TxElectrician (03-16-2019)
Old 03-16-2019, 03:48 PM   #6
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,410
Wow ! Those look like death traps.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Rio (03-17-2019)
Old 03-16-2019, 06:07 PM   #7
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 58
Lol, some of the comments are pretty good
mrcat is online now
Old 03-16-2019, 06:59 PM   #8
rrk's Avatar
Rewards Points: 48
that 2nd one is a death wish, he even just pushed the log in and cringes when it splits and thrown back at him
rrk is online now
Old 03-16-2019, 07:58 PM   #9
Radical Basement Dweller
Robie's Avatar
Rewards Points: 554
Git r done.
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
Old 03-16-2019, 09:44 PM   #10
hdavis's Avatar
Rewards Points: 288
I'd consider using some if them
I designed a woodsplitter. The mechanism was kind if a cross between the gas mechanism if an AK 47 and a spud gun.
It would wind up jumping around some, and there had to be guards to stop the flying pieces if wood.
GF didn't like the idea of hearing explosions every time I split wood.
hdavis is offline
Jay hole (03-16-2019)
Old 03-16-2019, 11:28 PM   #11
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 155
https://i.imgur.com/tUTK8bQ.mp4
rescraft is offline
Old 03-17-2019, 12:06 AM   #12
VinylHanger's Avatar
Rewards Points: 308
The first one is awesome. Except for the grab your arm and smash it to bits part. But the physics of it is good.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 03-17-2019, 09:43 AM   #13
I bought my first two pairs of crocs at the same time recently. I used one to go outside and cut trim and the other to install the trim inside without having to put anything down as I can through the door. It actually worked pretty great. Almost cost me my relationship when my girlfriend saw I bought them though.
Old 03-17-2019, 11:42 AM   #14
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 532
Definitely no loose fitting clothes for sure.
Deckman
deckman22 is offline
Old 03-17-2019, 05:15 PM   #15
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 396
I'd use the first one and probably the 3rd one. 2nd one is a big hell no. And the 4th one isn't making firewood, he's just making mince meat out of what could be good burning logs.
Jim P.
jproffer is offline
Old 03-17-2019, 06:54 PM   #16
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
There is an easier way.
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
Rio (03-17-2019), SouthonBeach (03-18-2019)
Old 03-17-2019, 06:56 PM   #17
B.Johnson's Avatar
Trade: Builder
Double post.
Old 03-17-2019, 10:26 PM   #18
rescraft's Avatar
Rewards Points: 155
https://i.imgur.com/MCqj39q.mp4
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
hdavis (03-17-2019)
Old 03-17-2019, 10:56 PM   #19
hdavis's Avatar
Rewards Points: 288
That's still slow. You have to stand all the stuff up first. Much faster is to just leave it in a pile and split it where it lays. I'll do that with just one axe, but some will do it with 2 axes.
hdavis is offline
Old 03-18-2019, 08:37 AM   #20
Railman's Avatar
Trade: Railing
Rewards Points: 1,227
Rack & pinion kinetic splitter...
I built one of these almost 40 years ago, utilizing a 3.75/1 van diff, with std engine flywheel on the input yoke. Cycle time was about 2.5 seconds. I still have it but haven't fired up in 35 years.
WoodMaxx claims 3 second cycle time, but it's clearly about 2 seconds in video.
Railman is offline
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Mini split leaking water JackP23 HVAC 1 04-19-2013 06:53 PM
Split Rail Fencing Tylerwalker32 Decks & Fencing 6 04-15-2013 03:33 PM
Side by side doors....One angled? Split jamb? wfg97079 Carpentry 30 07-13-2012 11:03 PM
1/2" Depth Split Escutcheon Cover for 1/2" Pex Tubing wwsmith Plumbing 0 07-20-2010 04:37 PM
