More Firewood.... - Page 4 - Off Topic (Non Trade) - Contractor Talk
More Firewood....
Old 01-10-2019, 11:47 PM   #61
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,328
Re: More Firewood....
Edit:
36" 30" outside bark to outside bark.
Probably 1.5"-2" of sapwood.
Immigration is not supposed to change the character of the nation.
Immigration is supposed to change the character of the immigrant.
Robie is offline
Old 01-10-2019, 11:53 PM   #62
Robie's Avatar
Robie is offline
Old 01-10-2019, 11:57 PM   #63
Robie's Avatar
Oooops...maybe it's 30" in diameter.
Robie is offline
hdavis (01-11-2019)
Old 01-11-2019, 12:14 AM   #64
hdavis's Avatar
Rewards Points: 1,752
Originally Posted by Deckhead View Post
ARE YOU KIDDING!?
That 3 way crotch is amazing (insert jokes). All almost at a perfect 45-60 angle. Can't get better. It's like that tree was placed in the perfect spot to grow.
That's what it seemed to me, but I left some wiggle room because I never saw the canopy. Major branch size and distribution was great, but maybe some unbalance toward the very top.
Either way, I'd be happy with, growth rings look great from here.
hdavis is online now
Deckhead (01-11-2019)
Old 01-11-2019, 01:42 AM   #65
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,658
Wonder if walnut makes good flooring?
Television is fake...The internet is real
Irishslave is offline
Old 01-11-2019, 03:12 AM   #66
hdavis's Avatar
It does.
Old 01-11-2019, 11:12 AM   #67
fjn's Avatar
Trade: mason
Rewards Points: 10,498
It was said of William T. Sherman. He never admitted a mistake and he never repeated a mistake !
fjn is offline
Old 01-11-2019, 01:47 PM   #68
rblakes1's Avatar
Rewards Points: 3,026
Unloading it was pretty easy. James pulled his jeep around and pulled the smaller 2 off the trailer just enough to get to the edge of the pallets, then I pulled the trailer out from under them. He got a little too ambitious with the big one and yanked it almost clear of the pallets lol. I got that one on video, I should be able to post it up this weekend
We'll pick up some anchor seal and get them covered soon
rblakes1 is offline
The Following 3 Users Say Thank You to rblakes1 For This Useful Post:
hdavis (01-11-2019), Robie (01-11-2019), TimNJ (01-13-2019)
Old 01-11-2019, 02:12 PM   #69
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 13,054
Anchor seal won't do a whole lot of good. Use thick paint or glue if you're looking to keep the end checking to a minimum.
Unless it's really dry, you probably don't have to use anything because it's still green. Sealing the ends is usually done after it's dried to keep moisture transfer to a minimum. Since it's green, moisture isn't going to go up and with as thick as it is, it ain't drying out too quick.
[signature removed by admin]
Deckhead is online now
The Following 2 Users Say Thank You to Deckhead For This Useful Post:
hdavis (01-11-2019), rblakes1 (01-11-2019)
Old 01-11-2019, 02:21 PM   #70
hdavis's Avatar
This is up North. It can freeze solid, and water sublimate from the end or if it warms up for a little while, just evaporate. RH is about nothing during the winter.
I see logs end check during the winter all the time.
I'd definitely seal it. JMO.
Old 01-11-2019, 03:30 PM   #71
Deckhead's Avatar
Trade: Carpentry,
Totally wasn't thinking about freezing. Wouldn't know what it does even if I was thinking about it
I'm really not a fan of wax for end checks though, any reason it would be okay in winter up north? Wax has it's place here, mainly for keeping a high MC for bending stock or turning blanks indoors. Biggest problem is if it melts and gets into the end grain (depending how deep it goes) that part is worthless because no chemicals take it off and almost no finish will stick to it (conversion varnish might).
Paint some titebond 3 on the ends or some good paint.
Old 01-11-2019, 06:26 PM   #72
Robie's Avatar
https://extension.msstate.edu/sites/.../chapter10.pdf
Robie is offline
rblakes1 (01-12-2019)
Old 01-11-2019, 06:52 PM   #73
Deckhead's Avatar
Trade: Carpentry,
Solid info.
Here's the FPL website with vast information. It's by far the most useful site I've ever used for wood. Takes a while to get used to and how to search it but you can find anything you wish to know about wood.
https://www.fpl.fs.fed.us/products/p...criteria=title
The Following User Says Thank You to Deckhead For This Useful Post:
Old 01-12-2019, 12:05 AM   #74
Irishslave's Avatar
Originally Posted by tgeb View Post
20 million BTU/cord...
I've burned them all. Even the uncommon, Willow, Birch, Sycamore, etc
Cut for cut I'd have to say Red or White Oak is the best, but Walnut ain't bad. Birch will burn even somewhat green but it burns almost too hot to use consistently....good for getting it going though
The Following User Says Thank You to Irishslave For This Useful Post:
tgeb (01-12-2019)
Identifying different types of firewood Irishslave Off Topic (Non Trade) 47 02-08-2018 11:36 AM
Big Box in firewood biz griz Off Topic (Non Trade) 12 01-07-2014 07:45 AM
Firewood rack. App-ironworks Specialty Trades Picture Post 4 09-14-2011 10:59 AM
The Firewood Business LNG24 Landscaping 17 04-04-2011 09:16 AM
Firewood Storage Shed CookeCarpentry Carpentry 10 11-09-2009 08:59 PM
