Making Wood Car W/ Son, Suggestions?? - Off Topic (Non Trade) - Contractor Talk
Thread Tools
Old 01-03-2010, 07:17 PM
mattsk8's Avatar
Trade: Building and remodeling
Rewards Points: 2,738
I'm making a grand prix car out of a block of wood that we are going to race against the other kids at my sons awana group from church. Given the very competitive nature of mine I was just searching for suggestions to make it go VERY fast.
Car basicly can't be more than 7" long, 2 3/4" high, or weigh more than 5 oz. The wheels have to be free rolling (no starting devices or drives).
mattsk8 is offline
Old 01-03-2010, 07:22 PM
Thom
thom's Avatar
Rewards Points: 4,748
Re: Making Wood Car W/ Son, Suggestions??
It's all about the wheels/bearings. Just compare a matchbox car to a hot wheels car.
thom is offline
Old 01-03-2010, 07:29 PM
ARealplumber's Avatar
Trade: plumbing
Rewards Points: 75
This is like the Boy Scouts do or use to do. They called it The Pinewood Derby race. Use graphite to lubricate the wheels on the spindles. We would experiment with adding different weights and removing wood to get the fastest shape and weight placement.
ARealplumber is offline
Old 01-03-2010, 07:32 PM
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 874
I have never made one, but......
I would think a dense wood like ipe might be a good choice.
I would also think that a taller wheel would be less rolling resistance.
And like Thom suggested bearings will make it faster than no bearings.
www.gebcon.com
tgeb is offline
Old 01-03-2010, 07:50 PM
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Tall slim solid wheels are the best option for wheels. Bearings with the grease flused out could work but you may be better of with a straight forward axle and sleeve setup with some good lubrication. A model or hobby shop should stock the axle parts you need. Maybe even the wheels. Also aero dynamics play a major part.
This site looks like it may be helpful to you.
http://www.pinewoodpro.com/
www.bcconstructionllc.com
BCConstruction is offline
Old 01-03-2010, 08:09 PM
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 343
Back in the day at our pinewood derby, my old man took my car into work and crafted it there. He bored out the front end and inserted lead. Then it was painted over and you couldn't tell unless u weighed it, which they didn't. Won first place fair and square! Well............. I won anywany thats whats important. See if they plan to actually weigh the cars or not.
Easy Gibson
Warren is offline
Old 01-03-2010, 08:13 PM
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
You're going to need a good pit crew and some major corporate endorsements. Knock up a local pediatrician's office and some baby food companies for the endorsements. Or call everyone that drops Tiger Woods. They'll have to park that money somewhere else now. One door closes, another opens...
cleveman is offline
Old 01-03-2010, 09:19 PM
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
Ok are you ready for this.
If this is like the pinewood derby they will supply the block of wood and wheels.
They will also weigh the car on race day.
You will need to shape the wood in a wedge shape
what I did is flatten off a rear deck then from the bottom i drilled a couple of through bolts and added washers with cap nuts they looked like exhaust stacks
use as many washers as it takes to dial in the weight this will get you competitive.
But if you really wont to win like I did then make sure that one wheel is slightly off the level plane because 3 wheels have less friction than 4
jeffatsquan is offline
Old 01-03-2010, 10:13 PM
galla35's Avatar
Rewards Points: 250
ill sell ya a car that won districts 15 years ago
galla35 is offline
Old 01-04-2010, 12:04 AM
mattsk8's Avatar
No bearings, I forgot to put that in the og post. Thanks for all the info. I like the Ipe idea. I just read the bottom of the rules and I can only use the wood block, wheels and axles furnished in the kit. I could prolly cheat on the wood though and no one would be the wiser . Might not be cool though since it is for church . I'll have to restle w/ that one a bit...
mattsk8 is offline
Old 01-04-2010, 01:44 AM
Teetorbilt's Avatar
Rewards Points: 2,000
You might want to look at a dry Teflon lube for the axle brgs. Gunshops carry this and don't use much, less can be best.
Albert Einstein
Teetorbilt is offline
Old 01-04-2010, 09:29 AM
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Get some emery cloth and fix the axles (nails) in a dremel tool or similar tool and deburr and polish the sides of the nail. Place all the weight above the axles. I'd also polish the wheels with a 20,000 grit cloth to smooth them up. Other then that, it'll all depend on the track used. I've raced cars on different lanes, different tracks and they've never been the same.
Cdat is offline
Old 01-04-2010, 09:51 AM
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Helping your son to build the car is one thing, doing it for him is another.
This is a good time to hlp your son learn about honesty and inegrity, he may not win the race because there will be other parents that will build the car for their son and cheat, but what is more important, winning a ribbon by cheating, or teaching your son the right way to do thing?
bwalley is offline
The Following User Says Thank You to bwalley For This Useful Post:
SC sawdaddy (01-05-2010)
Old 01-04-2010, 10:15 AM
mattsk8's Avatar
It's a baptist church so I'm thinking just to be a trouble maker I'll try to get PBR to endorse . They keep trying to convince me that drinking beer is a sin. If that's the case then the fridge in my garage is the gateway to hell!
mattsk8 is offline
Old 01-04-2010, 10:23 AM
mattsk8's Avatar
I honestly appreciate this. I won't do it for him, just trying to find suggestions for how to make it fast. I also will use the wood it came w/. I'll just teach him how a rotozip works to shape it and hollow it out. I'll also learn w/ him about the best places to add the weight (lead) to make it even so it's optimumly (is that a word?) placed for speed.
I agree w/ you. My son and I actualy do alot together.
mattsk8 is offline
Old 01-04-2010, 10:30 AM
mtm's Avatar
Trade: framing
Rewards Points: 25
graphite in the axels
Sand the wheels down so they are as thin as a piece of paper
Weigh the car often use a deli scale or postal scale
Add weights over the axles (pennies or small pieces of lead)
dont forget paint adds weight
mtm is offline
Old 01-04-2010, 10:37 AM
Pompass Ass
bwalley's Avatar
I helped run a clinic for the pinewood derby cars, Charlie the scout master who has been doing it for many many years, said the wedge works the best.
Take the axles (Nails) and chuck them in a drill and smooth them with 600 grit sand paper then use graphite on a piece of cloth to get it on the axles.
Check the wheels and make sure they are perfectly round.
I think the weight forward also helps and you want the car to be as heavy as possible.
Good luck, you and your son will have a lot of fun.
bwalley is offline
Old 01-04-2010, 10:51 AM
mattsk8's Avatar
These are the shapes we're concidering
mattsk8 is offline
Old 01-04-2010, 11:03 AM
IHI's Avatar
Rewards Points: 1,040
Find out WHAT rules your bound to first and foremost. All of us local drag racers are contemplating doing a guys night PWD outlaw race...just for betting and beers to pass the winter time since we're freinds with a guy that has a track and sets it up for boy scouts and such in his huge building. When we first talked, i was BLOWN AWAY with all the "tricks" out there to have a fast mofo....but like i said, you have to have some rules so you can "make it appear" within the rules
You can either buy or sand the nails down yourself that hold the wheels on...less contact inside center of wheel, the less the friction. Also sanding down the nail head will reduce friction of nail head that holds wheel onto car.
Graphite lube if allowed on axels ovbiously
IF your allowed aftermarket wheels, just buy the $29.99 set that's as thin as a piece of paper with a special outter coating on the "tread" part that is designed to reduce friction.
Many of the guys will actually "redrill" and raise 1 tire so it "appears" to sit on the ground, by in essence only 3 ever come into contact with the track...less resitance.
One fella who claimed to have won made a "stub nosed semi" design and put all his weight in the front (which just about everybody agree on in front over the axles) and when the gate dropped the "semi" immediately raised the back end off the track and went down on two wheels the majority of the track smoking the herd.
Pretty much all the national champs were in agreement aerodynamics in these cars is null and void, makes no difference....preventing and reducing EVERY place friction can happen is KEY.
Just google pinewood derby and you'll find a pleather of forums dedicated to optimizing the car. For around $100 you can buy all the stuff already done built by "pro's" with the latest/greatest technology for this kids sport....so while it seems caddy, this wood car racing is just like big boy racing...boils down to how badly do you want to win, how much do you want to invest to win, and if you can leave your moral compass at home in order to kick the living sheeot out of all that enter
IHI is offline
Thread Tools
Rate This Thread
Epoxy wood deck products Hosea New Member Introductions 0 12-11-2009 12:54 PM
Drywall Cracks and Wood Burning Furnace mds120 Drywall 10 11-23-2009 10:08 PM
Thanks for the marketing suggestions... onenia Marketing & Sales 11 10-16-2008 06:44 AM
wood deck question ???? davinci Decks & Fencing 30 10-02-2008 06:07 PM
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 08:06 AM
