Making Miniature Concrete Forms - Off Topic (Non Trade) - Contractor Talk
Old 05-03-2018, 06:52 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 10,402
The kindergarten class at my kids school does a mini building project every year. They put together a little model house. Iíve built them a frame and parts for putting it together in the past. My youngest is in kindergarten this year and Iím talking to the teacher about trying to pour a foundation with the kids.
I made up a foundation out of durabond for them that they use every year, but the teacher wanted to try making one, and not using flour like she normally does. Iím aware of skin contact and the dust from the durabond, so I have that covered.
Iím trying to come up with something that mimics concrete forms. So far was thinking of plywood panels (1/4Ē probably) and using #4 threaded rod and nuts to hold the panels together. Only problem is when we strip the forms the threaded rod will be sticking out still. Normally we grind or hammer off the ties, but canít do that in kindergarten and the durabond is too fragile Iím afraid.
Any ideas? This thing is only 12Ēx24Ē footprint. 3Ē tall. I guess is need some anchor bolts for sills too.
Morning Wood is offline
Old 05-03-2018, 06:59 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,142
Re: Making Miniature Concrete Forms
How'bout...
Cut the threaded rods to exact lengths...
Grind the ends of the threaded rod flat....
Use a glue gun to keep the rods in place against the plywood....
Just thinking out loud...
ďA great civilization is not conquered from without until it has destroyed itself withinĒ
― Will Durant
Robie is offline
Old 05-03-2018, 07:06 PM   #3
Bull Trout's Avatar
Rewards Points: 138
make some U shaped cleats that fit outside of the plywood, like used with pouring a curb,
not a complete apples to apples but would work
Bull Trout is offline
Old 05-03-2018, 07:49 PM   #4
Box Builder
What I like about the threaded rod is that we could lay in copper wire or something on the ties like real rebar. I wonder if I could pre pinch the threaded rod with wire strippers so that after we pull the forms it would break off real easily.
Old 05-03-2018, 08:03 PM   #5
Box Builder
Iím also dealing with young kids, so glue or hot glue gun is probably out of the question. Although it has crossed my mind. I also need the form to be rock solid so it doesnít fall apart when we pour in the durabond. Thatís why Iím thinking threaded rod.
Old 05-03-2018, 08:46 PM   #6
Robie's Avatar
Just put "lips" on the plywood forms for the rod to rest on...already made up
― Will Durant
Robie is offline
Old 05-03-2018, 09:36 PM   #7
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,262
Could you do the rod in 3 pieces with a connection nut on the inside of the form and a short stub thru the ply and a nut on the outside? After the pour, just thread the stub out of the connector. Sounds like a fun project. Teach those younguns while they'll still learn!
Anthill is offline
The Following 2 Users Say Thank You to Anthill For This Useful Post:
Morning Wood (05-03-2018), TxElectrician (05-04-2018)
Old 05-03-2018, 10:06 PM   #8
Box Builder
I like that idea, but I was planning on #4 or 6 threaded rod. Really small. Maybe I could cut up some small tubing that I could slide the threaded rod into and then nut it from both sides for the pour. Them just slide it out leaving the tube in the pour. Not totally like the real thing but no sharp edges poking out.
Old 05-03-2018, 10:17 PM   #9
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
When I was a kid, me n' Dad formed hog penning foundations like that. Piece of 1/2 black pipe on the inside of the form and a 3/8 thread rod thru it with nuts on each end. Then we could reuse all the thread rods. There were always those 1/2 pipes through the wall after that. Wpw, that brings back memories. That was 30+ yrs ago. I'm getting old....no wonder I hurt
Anthill is offline
Old 05-03-2018, 10:27 PM   #10
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 19,486
There's still no Low VOC cement? It'd be cool to use the genuine article.
As for the form, are you doing this demo outside? I'm picture a scale model.
Like, make a big tabletop "yard" that's a strong plywood bottom, 1x around the edges, and fill that mother with dirt!
Then, you can rip down to 1/4 scale. Have tiny little 2x12's and teeny tiny little stakes that you'll hold the forms in place with. Kids can handle stakes and little rubber mallots.
Copper wire as rebar is a great idea because the kids can really manipulate it easily and effectively, then if you need to nip it off it's super easy to do with a non-threatening pair of needle nose pliers.
This sounds like way more fun that working. I think I'll do this tomorrow instead.
Easy Gibson is offline
Plywood Concrete Forms BattleRidge Construction 33 07-18-2014 03:54 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
concrete forms reno dude New Member Introductions 1 06-03-2009 09:42 AM
