Helpful Tricks And Tips YOU Came Up With. - Page 3 - Off Topic (Non Trade) - Contractor Talk
Old 08-17-2014, 07:40 AM   #41
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Re: Helpful Tricks And Tips YOU Came Up With.
Originally Posted by olzo55 View Post
Add a horizontal wood piece at each end to connect the legs and it's extra strong
I've been using the design for 30 years and they are strong enough as is. I've had them last 20. My primarly reason for not connecting the legs is so I can stack them. I have 4 stacked now (tall for a work table and short for sawing, etc).
RangoWA is offline
Old 08-17-2014, 08:15 AM   #42
rrk's Avatar
Rewards Points: 3,106
Originally Posted by PrecisionFloors View Post
1/4x1/4 with Best is a phuckin mess... Better you than me.
I used Best on one job recently, that stuff likes to jump everywhere. But it works real well
rrk is online now
Old 11-14-2014, 11:34 PM   #43
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
When using Silicone, first apply masking tape to give a nice sharp border. Remove the tape immediately after tooling, the edge will lay down flat by itself.
skyhook is offline
Old 11-15-2014, 09:50 PM   #44
Superior Firepower
skyhook's Avatar
Originally Posted by skyhook View Post
When using Silicone, first apply masking tape to give a nice sharp border. Remove the tape immediately after tooling (still wet) , the edge will lay down flat by itself.
skyhook is offline
Old 11-27-2014, 12:46 AM   #45
Unger.const's Avatar
Rewards Points: 3,012
Roofing by myself I need to run a chalk line and needed a way to keep the hook end at the top of the shingle. So by pinch clamping it with the claw of my hammer I could snap a line.
Unger.const is offline
The Following 7 Users Say Thank You to Unger.const For This Useful Post:
asevereid (11-27-2014), Calidecks (12-05-2015), hdavis (12-06-2014), mikecarsy (12-05-2015), overanalyze (11-29-2014), Texas Wax (08-05-2015), totes (12-04-2015)
Old 11-29-2014, 09:24 PM   #46
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Originally Posted by Warren View Post
When setting a large window, tack a block on top of the top flange after you set it into the hole. Leave about 1/4" gap between the block and the window for adjustment. This way, the guy who helped pop it into the hole can be freed up to do other tasks.
local codes require all new windows to have hurricane clips on them.. we set the window in the opening then the inside man nails the straps to the framing, the window can still be adjusted for level and plumb.. at this point the spare hand can go start prepping the next opening
woodworkbykirk is offline
Old 08-01-2015, 06:02 PM   #47
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 502
When building shop shelving, make the bottom shelves strong enough and progressively deeper so that they double as a ladder to get to the top shelves.
Golden view is online now
Old 08-05-2015, 12:24 AM   #48
Mordekyle's Avatar
Rewards Points: 5,440
Gecko Gauge lift kit for an 11" reveal.
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
Unger.const (08-05-2015)
Old 11-15-2015, 10:56 AM   #49
Had to dig a french drain under a house. Was hard pack clay. And wet clay in some areas. So I bought a cheap sawsall. Fitted it with a 6in scraper blade and chiseled a 6inch wide ditch near the foundation footing. Belly crawling the whole way. Took about 4 hours. One guy chisel the other cleaning out the ditch. Would have been a day and a half otherwise.
Old 11-15-2015, 11:47 AM   #50
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,446
And a 2x4 diagonal from your piece to the under belly of the I beam, then use coil strap about 4" pieces bent to a 90* and some 1.5" roofing screws to hold it all together at the connection points underneath so when the nails start to give way the legs and stuff don't become wobbly. Same principle as clipping a house. Put the strap and screws from underneath so the screw heads don't damage material when you throw it on top of the load on the utility trailer. I've put a whole pallet of 3/4" plywood on mine that way. Strong as hell. Just make sure you use poplar, pine will throw your back out! #heavy
I'll post pics Monday.
Builders Inc. is offline
Old 11-15-2015, 12:08 PM   #51
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 4,809
Originally Posted by Robie View Post
When gluing wood together to make a panel too large to run through my planer, I will sometimes use colored chalk to color the joint so when I sand I can see the low spots.
I do this also when I need a face frame to be flush with a plywood side.
I just scribble a pencil line across the whole joint.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 11-15-2015, 06:56 PM   #52
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,258
pencil for trim work: I use a 2-3" long HB, worn behind the ear and sharpened on both ends. That way I never get the wrong end. Also prefer the hexagonal shaft over round as it doesn't fall out as soon.
Anthill is offline
Old 11-16-2015, 05:25 AM   #53
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
When I see the sparkys leaving ground wire cut offs on the ground I pick them up and coil them around a Phillips screwdriver and toss them in the belt. When we set tile backsplashes I cut off whatever length is needed and slide it over the outlet screws to shim out the outlets. Makes a nice tight fit and doesn't squeeze out like plastic shims.
Keeyter is offline
The Following User Says Thank You to Keeyter For This Useful Post:
Old 11-16-2015, 09:27 PM   #54
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,458
Works well for vct demo as well.
Metro M & L is offline
The Following User Says Thank You to Metro M & L For This Useful Post:
Unger.const (11-18-2015)
Old 11-16-2015, 09:47 PM   #55
Here you go. Strongest and cheap horses.
The Following 3 Users Say Thank You to Builders Inc. For This Useful Post:
Calidecks (11-17-2015), Metro M & L (11-17-2015), Unger.const (11-18-2015)
Old 12-04-2015, 03:24 PM   #56
totes's Avatar
Rewards Points: 910
I have always kept a variety drill bits, driver tips, countersinks stair gauges in the hip pocket of my tool belt, which are difficult to get to while wearing the belt. I now keep all those small parts in a altoids tin in the same pocket. It has been proven to be much more efficient.
It's no game changer, but everything counts.
"faster horses, younger women, older whiskey, and more money"
totes is offline
The Following 2 Users Say Thank You to totes For This Useful Post:
Metro M & L (12-04-2015), Unger.const (12-05-2015)
Old 12-05-2015, 02:57 PM   #57
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Originally Posted by CENTERLINE MV View Post
A picture would really help here.
I once decided to build a job site wall panel building station using 2 saw horses. It worked for that specific job pretty well. If I had been a larger outfit, I would consider the mobile panel trailer for some jobs.
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
Framer87 (12-05-2015)
Old 12-05-2015, 04:44 PM   #58
Railman's Avatar
Trade: Railing
Rewards Points: 827
Farm hay wagons 8' x 16' work well for that, & used are plentifull. Can ussually be had for 500 to 800.
Railman is online now
Old 12-05-2015, 06:44 PM   #59
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 276
The stilt stick!
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following 5 Users Say Thank You to blacktop For This Useful Post:
Builders Inc. (12-05-2015), MarkJames (12-05-2015), overanalyze (12-05-2015), Railman (12-05-2015), totes (12-11-2015)
Old 12-05-2015, 08:10 PM   #60
mikecarsy's Avatar
Rewards Points: 190
Drill a small hole through your pencil, stick a small screw threw it and screw it to the top of your tape measure away from mechanism and you have a pencil tape measure.
A simple one of these
mikecarsy is offline
Onyx tips and tricks TheOnyxGuy Kitchens & Baths 5 09-15-2015 04:40 PM
Frameless shower tips and tricks wanted divineinc Kitchens & Baths 7 02-24-2014 04:06 PM
PVC trim tips and tricks BCConstruction Finish Carpentry 52 05-13-2013 08:11 PM
Any tips, tricks or advice on the Aventos HL? DaVinciRemodel Finish Carpentry 5 10-11-2011 10:20 AM
website development, tips and tricks Bleed Technology 6 02-08-2009 11:41 PM
