Helpful Tricks And Tips YOU Came Up With. - Off Topic (Non Trade) - Contractor Talk
Old 06-11-2014, 07:16 PM   #1
Unger.const's Avatar
Rewards Points: 3,054
So I really enjoy the thread "tricks you learned from an old schooler" and I noticed a lot of comments that they didn't learn it from someone else but either figured out or stumbled upon a new way to do something. If you think you learned it from someone else please post it over on that thread. I wanted to start a new thread to share ideas and tricks to work smarter (and harder if needed) to get the job done right. Or to be better prepared and organized. Or even an unusual tool that has improved production or stressful issues. Pictures will be a big help in most cases
Unger.const is offline
Old 06-11-2014, 07:26 PM   #2
Re: Helpful Tricks And Tips YOU Came Up With.
I go through a lot of 3 inch screws so I buy in bulk but get tired of dragging a heavy bucket to and from a project that I might only use five pounds. I did some work with rustolum restore 10x paint and it came in these one gallon plastic paint cans. Pretty tough little containers. So I drilled a finger hole to open it and cut back the locking lip around the lid to prevent needing a screw driver to open it. Now I don't get wore down by dragging too much materials around.
The Following User Says Thank You to Unger.const For This Useful Post:
Tom Struble (06-11-2014)
Old 06-11-2014, 08:17 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
the small buckets that pool chemicals come in have a locking twist off lid,easy on/off
Tom Struble is offline
SC sawdaddy (06-11-2014)
Old 06-11-2014, 08:56 PM   #4
SC sawdaddy's Avatar
Rewards Points: 1,018
And the buckets make good toys for the dog.
No, you cant hold my hammer. Where is yours?
SC sawdaddy is offline
The Following 2 Users Say Thank You to SC sawdaddy For This Useful Post:
Tom Struble (06-12-2014), Tylerwalker32 (08-11-2014)
Old 06-11-2014, 09:00 PM   #5
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 458
When setting a large window, tack a block on top of the top flange after you set it into the hole. Leave about 1/4" gap between the block and the window for adjustment. This way, the guy who helped pop it into the hole can be freed up to do other tasks.
Warren is offline
The Following 2 Users Say Thank You to Warren For This Useful Post:
Tom Struble (06-12-2014), Unger.const (06-12-2014)
Old 06-11-2014, 09:11 PM   #6
I just have to stick a finger in to get going while you're still screwing off.........oh wait this isn't a family channel is it......chuckle chuckle snort (couldn't help myself)
I don't have any access to pool chemicals. But good to know if anyone else may.
Old 06-11-2014, 09:21 PM   #7
The Dewalt tstak units have been helping me get more organized. They are kinda limited for configuration. But here is a simple trick. Swap the lids on the long handle top with the deep well box and you can get some bigger tools in them
By swapping the tops of the two left boxes you will get the hybrid box on the right.
Inside the deep well box I have an M18 Sawzall (battery off though) M18 circ saw (batt can be on) and TWO M18 impact drivers (batteries can be on also)
pinwheel (07-11-2014)
Old 06-13-2014, 07:40 PM   #8
Have you done this trick by yourself assuming you can lift a larger window by yourself?
Old 06-13-2014, 07:45 PM   #9
Geometrist
Warren's Avatar
Rewards Points: 458
We do it all the time now, often solo. For a small window, it reduces the time that you need to spend making sure the window doesn't topple out of the opening.
Warren is offline
mikeswoods (07-11-2014), Unger.const (07-12-2014)
Old 06-13-2014, 07:54 PM   #10
MarkJames's Avatar
Rewards Points: 19,505
Maybe this isn't a big deal, or that it's unique, but anyway. For easy-sand repairs I like to use a pocket flashlight for putting on the final coat, and sometimes even the 2nd coat. Usually I find a little something that makes it worth it.
MarkJames is offline
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Metro M & L (07-31-2014), Unger.const (07-12-2014)
Old 06-13-2014, 08:42 PM   #11
PoleBarnsNY's Avatar
Trade: Pole Barn Builder
Rewards Points: 1,419
Two truck tool boxes. One deep one for tools and the other for fasteners.
Mounted a lockable cross brace to my ladder rack that I hang all of my cords, hoses chains, come-alongs, ropes on. Both sides attach with a padlock
Trailer with a flop down gate. I welded up a front rack as high as the back gate and I seconds as a ladder, lumber rack with lots of room underneath for equipment and large tools like compressors, wheel barrows, generators, etc
Dollar store see thru containers - buy every closeable see thru container they have for a buck that fits about ten pounds of fasteners in them that we put in the second truck tool box. We break about one a week but who cares. 50 bucks a year for large see thru organization. Fast, cheap, easy.
We use a tow behind man lift a lot. We take a four wheeler with us to the job to move it instead of the truck because it is Waaaay faster.
We removed the foot handle on our tamper and replaced it with an eight foot with a t handle at the four foot, six foot and 8 foot mark so we can tamp comfortably in 1 foot lifts. It is made out of threaded pipe so we could put tees in for the t handles.
I have separate tools boxes or buckets for every phase of projects we do. For example, we have a box that has all the tools needed to install four garage doors at the same time. On that day we install garage doors them, we grab that box and slam them up without having to go get anything else. It's all in that one box.
PoleBarnsNY is offline
Old 07-10-2014, 10:35 PM   #12
totes's Avatar
Rewards Points: 910
Is there anything beer can't do? Really?
I found my self in a bind today on a job it the country, and I got through it without adhesive on my hammer! This works surprisingly well.
Thank you beer.
"faster horses, younger women, older whiskey, and more money"
totes is offline
The Following 4 Users Say Thank You to totes For This Useful Post:
BlueRidgeGreen (08-11-2014), Builders Inc. (11-15-2015), mikeswoods (07-11-2014), woodworkbykirk (11-29-2014)
Old 07-10-2014, 10:56 PM   #13
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
For most of my corded tools I coil up the cords in a loop and then shove the loop through the handle (most people seem to just wrap the cords around the tool). When it comes to getting the tool ready for action, one pull on the cord out of the handle & it's free & unwound.
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
asevereid (07-10-2014)
Old 07-10-2014, 11:33 PM   #14
Hack
asevereid's Avatar
Rewards Points: 412
Do that all the time.
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
Old 07-11-2014, 12:50 AM   #15
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Bungee ball cords to hold the dustbag on the drum sander. Much better than tying the string.
Water based floor finish applicators go in a 1 x 3 tote with four inches of water along with a paint tray. The last set of pad and tbar lasted a year. Never had a problem with metallic reactions either.
When cutting short pieces of shoe grab a piece long enough for two cuts. Miter each side then hold each end in position and mark with razor knife. Voila two perfect pieces in one trip.
Metro M & L is offline
Old 07-13-2014, 01:48 AM   #16
Thank you beer.
My 40oz beer bottle doesn't seem to fit! Haha
Clever thinking though!
Old 07-13-2014, 07:02 AM   #17
Trees are Cool
pdmig's Avatar
Trade: Carpenter Builder
Rewards Points: 215
I had to move some 20' 2x12's from the delivery drop to the house site. They were almost too heavy to lift. So I put (the also delivered) 20' 2x4's down like a rail. It was easy to slide the 2x12's along. Only lifting half and they would steer easy by just tipping them.
I still had to lift them in to position but it saved some time and my back.
pdmig is offline
The Following User Says Thank You to pdmig For This Useful Post:
Gary H (07-13-2014)
Old 07-31-2014, 12:04 AM   #18
Have a lot of power tool batteries. Some have a power level on them some don't. So in order to save time of poking the fuel gauge button or plugging it into a tool and hit the trigger to find out its a dead battery. We lay the batteries on their side which helps indicate to someone else to not to waste time seeing if that battery is fresh or not.
The Following 2 Users Say Thank You to Unger.const For This Useful Post:
Metro M & L (07-31-2014), mikecarsy (12-05-2015)
Old 07-31-2014, 12:35 AM   #19
diplomat
Golden view's Avatar
Rewards Points: 1,550
Dead batteries to the left of the charger, charged to the right. Then the hot ones wait in line to cool.
Golden view is offline
Old 08-09-2014, 03:38 PM   #20
totes's Avatar
Rewards Points: 910
About to paint and can't find your duster attachment?
totes is offline
MarkJames (11-27-2014), Metro M & L (08-11-2014), Roofcheck (11-16-2014), Tom Struble (08-09-2014)
Onyx tips and tricks TheOnyxGuy Kitchens & Baths 5 09-15-2015 04:40 PM
Frameless shower tips and tricks wanted divineinc Kitchens & Baths 7 02-24-2014 04:06 PM
PVC trim tips and tricks BCConstruction Finish Carpentry 52 05-13-2013 08:11 PM
Any tips, tricks or advice on the Aventos HL? DaVinciRemodel Finish Carpentry 5 10-11-2011 10:20 AM
website development, tips and tricks Bleed Technology 6 02-08-2009 11:41 PM
