Happy Father's Day - Off Topic (Non Trade) - Contractor Talk
Happy Father's Day
Old 06-15-2019, 08:29 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,695
Happy Father's Day
My brother and sister are going to pay to have someone mulch my Dad's flower gardens. They asked me if I wanted to chip it for that but my Dad asked a while back if I could refinished the exterior of his back door to his house.
I decided this was going to be his gift. After tackling the project the $125 that I'd of had to tossed into the kitty with my brother and sister for the mulch looked like a much easier thing to do
Of course stripping the door means sanding, and lots of it. It's a cross buck door with a diamond pattern window. Lots of nooks and crannies and lots of angles.
Used a sander to strip the flat sections, it went quick, 45 minutes I guess.
Then various methods to strip the details until I got the heat gun out and that was the preferred method for the rest of the stripping. Chemical stripper wasn't going to work to well on this stuff. I tried and it just sat there.
So about 1/2 day later and many, many sanding sheets later.
Then I had to mask off the glass. Nice and slow and laborious.
Then I sprayed the stain on. It's American Walnut.
After that I went home for dinner, it was 6:50. The stain needs to dry for 90 minutes. That's what the sealer said.
Oh... did I say 6:50? I meant 6:20. I'm not waiting that long grrrrr....
So after 70 minutes I put the sealer coat on.
I'm using ML Campbell's Polarion Isolente for the sealer and Polarion 'X' a 2K Polyurethane for the clear. The catalyst is old... Hope it dries.
I have to sand the sealer coat and then apply 2 top coats one after another (wet on tack as they call it), so no sanding between these coats.
Should finish up between 11 and 12 midnite tonight.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 9 Users Say Thank You to Leo G For This Useful Post:
DaVinciRemodel (06-16-2019), greg24k (06-16-2019), hdavis (06-16-2019), Idothat (06-16-2019), KAP (06-15-2019), META (06-16-2019), overanalyze (06-16-2019), Robie (06-16-2019), Tom M (06-16-2019)
Old 06-15-2019, 08:38 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,488
Re: Happy Father's Day
Right up your alley.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 06-15-2019, 08:50 PM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Leo next time I am looking for a striper I am calling you I can see from here you are a great striper
Still "Shakin" the tree boss
sunkist is offline
Old 06-15-2019, 09:32 PM   #4
LRG WoodCrafting
Leo G's Avatar
Tip big!!
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 06-15-2019, 09:34 PM   #5
Robie's Avatar
Uhh...no....
Robie is online now
The Following 2 Users Say Thank You to Robie For This Useful Post:
greg24k (06-16-2019), Tom M (06-16-2019)
Old 06-15-2019, 09:56 PM   #6
LRG WoodCrafting
Leo G's Avatar
I should shave my pits if I expect tips.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 06-15-2019, 11:12 PM   #7
LRG WoodCrafting
Leo G's Avatar
Got the final 2 top coats on. What I had was a dull sheen. And I know Dad likes it shinier. So since the finish has been sitting around for a while all the flattening paste sunk to the bottom of the can. I poured the gloss out and then scooped some of the flattening paste into it to dull it down from gloss. I might have gotten it down to semi. It looked pretty shiny when I went back to do the 2nd coat.
I was worried that there might have been something in the finish that wasn't in the upper section where I poured it off. That maybe it wouldn't dry or something. But after an hour I went back and the first top coat had dried enough that I could sand it. I had a couple of plicks in the finish that I sanded down and then a very light scuff on all the flat surfaces. Then did the 2nd coat.
I'll have to get the door down there tomorrow after I pull the tape off the glass. But it looks like it will come out nice.
2nd coat of final finish.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 5 Users Say Thank You to Leo G For This Useful Post:
hdavis (06-16-2019), Idothat (06-16-2019), overanalyze (06-16-2019), tgeb (06-16-2019), TxElectrician (06-16-2019)
Old 06-16-2019, 01:47 AM   #8
hdavis's Avatar
Rewards Points: 1,184
Glad you found a way to use up your old product.
hdavis is online now
Old 06-16-2019, 07:49 AM   #9
LRG WoodCrafting
Leo G's Avatar
Stuff is $140/gal
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
hdavis (06-16-2019)
Old 06-16-2019, 08:03 AM   #10
Tom M's Avatar
Rewards Points: 11,274
A lot of work. They make paint stripping wheels and pads for the grinder. Ever try that? I thought about buying a Fes Ras for this kind of work.....once. it's not my thing but I worried sanding would just gum up.
I salute your patience and skill Mr. Leo.
Tom M is online now
Old 06-16-2019, 10:02 AM   #11
hdavis's Avatar
The prep part of this is the act of love, even if Leo hates it....
Old 06-16-2019, 10:25 AM   #12
LRG WoodCrafting
Leo G's Avatar
Not sure how that would act around glass. That was the most tedious part.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 06-16-2019, 10:27 AM   #13
LRG WoodCrafting
Leo G's Avatar
11am - 11:45 pm. After 7:50 it was 20 minutes every hour or so. Had dinner about 7pm while letting the stain dry for an hour.
My fingertips hurt.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
hdavis (06-16-2019)
Old 06-16-2019, 10:30 AM   #14
LRG WoodCrafting
Leo G's Avatar
Back on the hinges.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 7 Users Say Thank You to Leo G For This Useful Post:
hdavis (06-16-2019), META (06-16-2019), overanalyze (06-16-2019), Robie (06-16-2019), tgeb (06-16-2019), Tom M (06-16-2019), TxElectrician (06-16-2019)
Old 06-16-2019, 10:37 AM   #15
hdavis's Avatar
I bet Dad loves it!
Old 06-16-2019, 10:41 AM   #16
LRG WoodCrafting
Leo G's Avatar
Just so glad all I had to refinish was the exterior. The interior is still in nice shape. Probably should have done the hinge side, when I pulled the tape off it looked like some finish came with it. But I've got a can of brush on poly that'll work just fine.
He loves the door. My Mom took care of the maintenance on the front and back doors. I suggested painting the door to make it easier. He wanted it stained, he didn't say why, but I knew. So in honor of my Mom's commitment to keeping the door well preserved, Happy Fathers day Dad.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
hdavis (06-16-2019), overanalyze (06-16-2019), TxElectrician (06-16-2019)
Old 06-16-2019, 02:17 PM   #17
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 892
Originally Posted by Leo G View Post
Back on the hinges.
Nice job. Too bad your brother and sister will be talking about how you're too cheap to go in on some mulch.
Sent from my LG-LS993 using Tapatalk
TxElectrician is offline
The Following 2 Users Say Thank You to TxElectrician For This Useful Post:
hdavis (06-16-2019), Robie (06-16-2019)
Old 06-16-2019, 04:01 PM   #18
tjbnwi's Avatar
Rewards Points: 4,058
Nice job Leo.
Doors are why I got a soda blaster.
Happy Father's Day-58050820870__7d3f3cba-a824-4c37-8f3e-3432cdb03038.jpg   Happy Father's Day-58050822031__dd15f324-88e7-4981-91ab-8f1ee315ac37.jpg   Happy Father's Day-img_1330-1-.jpg   Happy Father's Day-img_1339.jpg
tjbnwi is online now
Old 06-16-2019, 04:12 PM   #19
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,002
Mike.
_______________
Calidecks is online now
Old 06-16-2019, 04:38 PM   #20
Robie's Avatar
Robie is online now
Calidecks (06-16-2019), tgeb (06-16-2019)
