Fire Near Me! - Page 8 - Off Topic (Non Trade) - Contractor Talk
Fire Near Me!
Old 10-22-2017, 10:16 AM   #141
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,614
Re: Fire Near Me!
What am I supposed to be looking at?
Robie is offline
Old 10-22-2017, 11:15 AM   #142
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,565
Re: Fire Near Me!
Grape vinyard not burning at all. Straight line on where the fire stops.
When does it do that?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 10-22-2017, 11:26 AM   #143
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Re: Fire Near Me!
Originally Posted by Leo G View Post
Really odd way for a fire to burn.
Looks perfectly normal to me. The dry grasslands burned, like around the pond, and the vineyard that would probably have been watered from that pond, and would have been tilled, turning the dirt over with a disk type system, to kill all the weeds, would not be able to burn. Safest place to be in a fire would have been a vineyard. Unfortunately Paradise winery buildings near our house didn't make it, but their vineyards did.
So many of these homes could have been saved had folks stayed and fought the fire. I understand it takes balls to get in there and fight, but many of these homes were in open fields that were cut, and it was embers that landed from miles away that then started a tiny little fire that eventually caught the house on fire. A garden hose could have saved them.
The rules are any rural home, on a well, built today must have a 5,000 gallon water tank onsite. Many homes have swimming pools that hold upwards of 30,000 gallons. Granted my neighbor emptied his 40,000+ gallon pool, but he saved his mothers house next door. If it had gone all of our houses would have gone. We are a very small pocket of homes set inside the forest that made it, because the fight was fought. Had any one of our homes burned the entire neighborhood would have gone. Thank goodness a lie to the police got a family member in with the Water Buffalow tank or another at least 15 homes would have burned. For most of the fight the fire department was no where to be found. The Los Gatos Strike Team showed up at our house hours after they cut the water off with a water truck at the 11:59th hour (Not literally), and did help save us. from a low burning fire less than a 100ft behind our house. Once the main event was over strike teams were available to help knock down flare ups as they happened. Two days after the Torrance Strike team came in and mopped up. The rains helped even more.
"Scuba gear and a swimming pool are a good thing to have!" Owning fire proof clothing and a helmet are part of staying behind to fight the fight. Having everything set in place and ready to go in a moments notice are important too. Knowing what precious items you want to send out of the fire zone, like a ditch bag, need to be thought of ahead of time.
There are many places in the woods there is no way I would have stayed and fought the fire in though. Our own house 7 years ago would have been a run for your life situation. I cleared acres of land with some hard manual labor, cleaning dead wood 21ft into the trees, with a pole saw. Climbing many with a rope, and chainsaw, to clear dead wood higher than my pole saw would reach. Also dropped over 48 trees, and cleared acres of brush. Now I realize I didn't do enough. Our neighbors and I talked about doing some serious clearing, which is what I had been pushing to do for years. I always figured it would be a fire from the damn homeless, as they tend to lite up Fountain Grove every year with a "small" grass fire.
Our family friends house burned and it sits in the middle of two acres of mowed weeds, surrounded by more acreage of mowed weeds. Plus a dozer had dang near circled the house. Most likely a bush next to the house caught fire and burned it to the ground. With a swimming pool and a 5,000 gallon water tank, plus a generator hooked into the main panel this house should have been easily defended...by pre-watering and putting out any embers with a garden hose. Should the house caught fire, there was a swimming pool to jump into, and as you can see in the bottom photo a new structure being built that is bare wood made it. Plenty of places to ride the fire out inside a vehicle. This scenario was played out over many rural houses.
Fire near me!-screen-shot-2017-10-22-10.53.06-am.png   Fire near me!-screen-shot-2017-10-22-10.57.30-am.png
Peter_C is offline
The Following 2 Users Say Thank You to Peter_C For This Useful Post:
SmallTownGuy (10-25-2017), TxElectrician (10-25-2017)
Old 10-25-2017, 11:53 AM   #144
lge77's Avatar
Trade: Home Builder
Rewards Points: 982
Re: Fire Near Me!
That is too close for comfort, stay safe!
lge77 is offline
Old 10-25-2017, 01:01 PM   #145
VinylHanger's Avatar
Rewards Points: 11,252
Re: Fire Near Me!
That's crazy. A grass fire is bad, but also easy to put out. I would have stayed. It would be different if there were trees or large brush around.
That looks like they could easily afford a holding tank and a generator to run the well.
VinylHanger is offline
Old 10-27-2017, 03:16 PM   #146
Tom M's Avatar
Rewards Points: 5,820
Re: Fire Near Me!
Any word on the hundred of missing people? Have they registered in some kind of data base from remote places? Dont tell me they are feared dead.
Tom M is offline
SmallTownGuy (10-27-2017)
Smoke and Fire Damage Remediation Advice Needed NJ Contractor Construction 8 03-02-2017 08:53 AM
Houston fire at construction site Snobnd Off Topic (Non Trade) 18 03-28-2014 08:53 PM
Wood burning fire pit and Fiberon decking edmontondecks Decks & Fencing 4 06-27-2011 05:45 PM
Fire Pits deckman22 Decks & Fencing 2 01-30-2011 10:00 PM
Fire damage demo XanadooLTD Demolition 6 03-27-2009 02:26 AM
