Do You Use WD-40? - Off Topic (Non Trade) - Contractor Talk
Do You Use WD-40?
Old 09-15-2008, 01:12 PM   #1
recruitwd40's Avatar
Trade: Construction
Do You Use WD-40?
Please read our rules for posting here.
TIA
recruitwd40 is offline
Old 09-15-2008, 01:38 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Rewards Points: 2,000
Re: Do You Use WD-40?
I do, potato cannon and as starting fluid.
mickeyco is offline
Old 09-15-2008, 01:42 PM   #3
Handle It!
MALCO.New.York's Avatar
Works well as a Diesel Primer!
The best application is grease removal.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-15-2008, 01:55 PM   #4
mickeyco's Avatar
It's good for the inside of range hoods, but I use that simple green now, works fantastic, no stink.
mickeyco is offline
Old 09-15-2008, 02:09 PM   #5
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Only for omelets!
silvertree is offline
Old 09-15-2008, 10:15 PM   #6
CaliDesigns's Avatar
Rewards Points: 75
It takes off duct tape residue and is a great form release for steigmeir forms.
CaliDesigns is offline
Old 09-15-2008, 10:52 PM   #7
Teetorbilt's Avatar
Good for rifles if you get rained on. Follow up with oil. Corrosion Block or Boeshield T-9 is better.
Albert Einstein
Teetorbilt is offline
Old 09-16-2008, 03:21 AM   #8
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Back in the old days. I'd soak my .50 cal M-2 HB Machinegun in it and freak the shat out of new Lt's when I fired it at night. Flames would be shooting out in every direction five feet.
Cdat is offline
Old 09-16-2008, 07:49 AM   #9
bob_cntrctr's Avatar
Trade: property manager & renovator
"Double-D-40", the lubricant for big-chested women.
bob_cntrctr is offline
Old 09-16-2008, 10:27 AM   #10
Kent Whitten's Avatar
Rewards Points: 2,040
believe it or not, we used to spray wd-40 into the female end of our electric cords as a last resort when we kept tripping our GFI. This was Seattle, so we had a lot of moisture to deal with and GFI's tripped alot on the jobsite. A plumber told us about this and we tried it and it seemed to work good.
Obviously we sprayed it in there, then took the air nozzle and cleaned it out. Not like we had puddles of wd-40 in our electric cords.
I was told the "wd" stands for water displacement. Not sure how true that is.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 09-16-2008, 10:42 AM   #11
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
When fishing in Texas, I'd spray a little on a lure and dangle it near bridge pilings and get all kinds of hits.
Cdat is offline
Old 09-16-2008, 10:43 AM   #12
Meetre's Avatar
also, it'll take paint off hardwood floors
Meetre is offline
Old 09-16-2008, 10:48 AM   #13
mickeyco's Avatar
Does anyone know where I can get a good deal on some WD-40?
mickeyco is offline
Old 09-16-2008, 10:55 AM   #14
Willybeen's Avatar
Trade: Septic and Plumbing Services
Rewards Points: 75
It also works wonders in cleaning the chain lube and gunk off of my motorcycles wheels.
Willybeen is offline
Old 09-16-2008, 11:44 AM   #15
Handle It!
That is correct. The 40 is formula or attempt #40. Finally got it right on the 40th try.
One thing that WD is NOT is a lubricant.
Until about 5 years ago, the word Lubricant was not to be found on the can. Why it is now is beyond me.
WD is also wonderful for dressing brushed steel! Apply to a rag LIBERALLY. Wipe in the direction of the brushing. Let sit fir 5 minutes. Remove excess with dry cloth! Looks great! Like Sheila-Shine.
Old 09-18-2008, 09:56 PM   #16
Houston's's Avatar
Trade: Remodeling, Replacement windows,
Rewards Points: 150
wd40 is poo... it just strips the good lube off what ever your lubing..tri-flo is good.
Houston's is offline
Old 09-18-2008, 10:11 PM   #17
Handle It!
Tri-Flow is probably one of the BEST lubricants.
WD-40, as stated in the previous post, is NOT a lubricant. It is for surfacting Water and Other petroleum distillates such as you have stated.
WD-40 is the BEST at what it is designed to do.
Old 09-18-2008, 10:12 PM   #18
Handle It!
Commit a crime, and can not help but leave fingerprints???? WD will save your sorry assssss.
Old 09-18-2008, 11:03 PM   #19
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
Rewards Points: 1,000
I hope your not speaking from experience....
I have leather that I cut into 11"x11" squares, I saturate them with WD40 and layer them with my blades....leather, blade, leather, blade...
Keeps'em nice and rust free!
ChainsawCharlie is offline
Old 09-18-2008, 11:04 PM   #20
Handle It!
Could be!!!
Maybe...Maybe not!!!
