Ask Inner Corner - Page 5 - Off Topic (Non Trade) - Contractor Talk
Ask Inner Corner
Old 12-28-2018, 08:03 PM   #81
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,973
Re: Ask Inner Corner
Serrated mostly for breads, but I have a serrated tomato knife that cuts great. I just keep forgetting to use it.
MarkJames is online now
Old 12-28-2018, 08:03 PM   #82
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,310
Originally Posted by Tinstaafl View Post
I like a serrated knife for cutting bread, that's about it. Next thing to a hacksaw.
A truly sharp knife is a pleasure to use; practically effortless. Unfortunately, my wife can dull a sharp blade just by glancing at it, so I've pretty much given up on that level of sharpening.
Those ceramic steels do a better job than the steel ones. It's about all I use to keep all my knives razor sharp unless it's been "womanized"...ouch.
Immigration is not supposed to change the character of the nation.
Immigration is supposed to change the character of the immigrant.
Robie is online now
Old 12-28-2018, 08:10 PM   #83
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 1,272
The Rada are American made and reasonably priced. Pampered chef are China and ridiculously priced.
Big Johnson is online now
Old 12-29-2018, 04:41 PM   #84
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 2,476
I've had a few steels, I now have two on hand, one is a shun the other is a century old one that belonged to my great grandmother. I only use the shun....but I find it only really works on softer steels. Steels have almost no effect on my Japanese knives that are made of a harder steel.
Every blue moon I get the itch and sharpen all my knives on my belt grinder using 3M trizac belts, then finish with a leather belt. But for now when one gets so dull it's annoying I sharpen it on a King 1000 wet stone.
Inner10 is online now
Old 12-29-2018, 04:43 PM   #85
Inner10's Avatar
Never seen a Rada knife.
Old 12-29-2018, 05:34 PM   #86
Robie's Avatar
Give the ceramic a whirl. The research I've done has it doing a little sharpening as it hones.
Robie is online now
Old 12-29-2018, 05:48 PM   #87
hdavis's Avatar
Rewards Points: 2,002
Istor.
hdavis is online now
Old 12-29-2018, 06:26 PM   #88
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 329
Just use a piece of flint. Chip a flake off to sharpen it.
Flippin' epochians.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Deckhead (12-29-2018), hdavis (12-29-2018)
Old 12-29-2018, 06:45 PM   #89
Robie's Avatar
Inner...what is a "beachcomber"?
Robie is online now
Old 12-29-2018, 07:42 PM   #90
Inner10's Avatar
Don't doubt it, similar to a diamond hone.
Old 12-29-2018, 07:43 PM   #91
Inner10's Avatar
Someone who combs the beach. My grandparents spent half their lives doing just that.
Old 12-29-2018, 07:50 PM   #92
Robie's Avatar
I should have been more specific.
What is a British Columbia Beachcomber?
Robie is online now
Old 12-29-2018, 08:48 PM   #93
Inner10's Avatar
Couple who goes around in a boat looking for logs.
Old 12-29-2018, 08:54 PM   #94
Robie's Avatar
Who'd you have to call?
Yeah, I was watching a documentary about booming logs from Vancouver Island down to Vancouver....8-15 day trip.
One of the tug captains also goes out in his aluminum work-boat when he's off to gather logs that have gotten loose from the booms.
Apparently, pretty good money in it but you have to be a hardy soul.
Robie is online now
Old 01-09-2019, 10:08 AM   #95
Why can I only use 10 watt LED bulbs (60 watt equivalent) in 60 watt max light fixtures? A 100 watt equivalent is only about 18 watt.
Iíve always wondered (and ignored) this limit on light fixtures.
Old 01-09-2019, 10:29 AM   #96
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,040
I thought you could use whatever led you wanted...the wattage restriction wes due to the heat standard bulbs put out
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
Robie (01-09-2019)
Old 01-09-2019, 01:37 PM   #97
That’s not what the boxes say for a lot of the light fixtures I’ve bought over the past few years. I’d upload a pic. but my phone makes the file too big and I don’t feel like messing with it right now. I’ll do it tonight.
Some do just say “maximum wattage”
Old 01-09-2019, 01:39 PM   #98
I wonder if the boxes are designed in China and maybe it’s just bad interpretation?
Inner will know.
Old 01-09-2019, 01:46 PM   #99
Inner10's Avatar
Bulb life, the LED drivers want to stay cool, and in the case of drop in LED bulbs the driver is built into the base. Once you put that in a closed fixture it overheats the driver and dramatically reduces the life of the bulb.
Some old fixtures were murder on LED and CLF bulbs due to poor heat dissipation, yet an incandescent bulb doesn't mind the heat....and in the case of a halogen bulb it needs the heat for longevity (see halogen cycle).
Big Johnson (01-09-2019)
Old 01-09-2019, 02:59 PM   #100
Lettusbee's Avatar
Rewards Points: 416
Looking at the 8ft fluorescents in my shop, and started shopping around for led bulbs for existing fixtures.
Seems like a pain in the keister to change existing fixture to led bulbs.
Seems easier and more cost effective to just buy 8ft led fixtures.
What would Inner do?
Lettusbee is online now
Crown around an odd outside corner Expensive Hobby Finish Carpentry 24 12-03-2017 09:04 PM
taping a painted corner A. Finelli Drywall 27 10-09-2014 12:56 PM
Question about building corner cabinet deeper for Staggered Heights Ridicules Finish Carpentry 6 11-14-2013 06:51 PM
Water table, drip cap, corner boards UpNorth Windows, Siding and Doors 4 10-16-2010 04:11 PM
Corner to Corner slump Blockade Demolition 2 12-02-2008 02:41 PM
