Ask Inner Corner - Page 4 - Off Topic (Non Trade) - Contractor Talk
Ask Inner Corner
Old 12-28-2018, 12:21 PM   #61
Frank Castle's Avatar
Rewards Points: 626
Re: Ask Inner Corner
Originally Posted by TxElectrician View Post
That's the question for inner- what's the secret for solving the rubics cube
Originally Posted by Inner10 View Post
Peel off the coloured stickers and put them back on so all sides have the same colour.
Inner, I got this one for ya.
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following 3 Users Say Thank You to Frank Castle For This Useful Post:
donerightwyo (12-28-2018), Robie (12-28-2018), TxElectrician (12-28-2018)
Old 12-28-2018, 12:42 PM   #62
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,488
Very cool.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is offline
Frank Castle (12-28-2018)
Old 12-28-2018, 12:53 PM   #63
MarkJames's Avatar
Rewards Points: 18,981
A reset rubik cheat....fwiw...
You can pop out the blocks and replace them to original position. Turn a face to the 45, then pry up one (any) of the 4 "middle edge" blocks.,,.the rest will come out carefully. The center block on each face remains..use as guide.
Put 'em all back in reverse order...snapping the last "center-edge" block back in place while the face is on the 45
MarkJames is offline
Old 12-28-2018, 03:01 PM   #64
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
I heard Inner knows how to get any girl to say "yes"
He simply asks her...........................................
"Am I bothering you?"
Irishslave is offline
Old 12-28-2018, 03:37 PM   #65
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 6,866
Alright I got one I know he'll be able to answer. Already asked John but figure I should ask Inner too.
If I'm going to smoke a whole ribeye should I smoke it to rare temp or reverse sear it once it's like 110? Or just hit really hot heat first to crust it and then smoke it to rare?
And then I said, supposing you brought the light inside of the body, which you can do either through the skin or in some other way.
Deckhead is offline
Old 12-28-2018, 04:37 PM   #66
Lettusbee's Avatar
Rewards Points: 1,498
How come,
If it's transported by ship it's called cargo,
But if it's transported by truck, it's called a shipment?
Lettusbee is offline
The Following 2 Users Say Thank You to Lettusbee For This Useful Post:
KAP (12-29-2018), MarkJames (12-28-2018)
Old 12-28-2018, 04:41 PM   #67
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Reverse sear is the only way to go, I'd probably take your option of ramping up the temp once it is around 110, then pull it around 120-125, should carry over to 130-135.
Inner10 is offline
Old 12-28-2018, 04:46 PM   #68
Robie's Avatar
I would assume, just as searing helps keep the juices in...would help keep the smoke out, therefore, sear at the end.
Robie is offline
Old 12-28-2018, 05:11 PM   #69
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,270
Next time I will use a sharper knife.
Not sure if this will work or not
https://www.facebook.com/10000992689...4079448932946/
NYgutterguy is offline
The Following 3 Users Say Thank You to NYgutterguy For This Useful Post:
Inner10 (12-28-2018), Robie (12-28-2018), tgeb (12-29-2018)
Old 12-28-2018, 05:20 PM   #70
Inner10's Avatar
Originally Posted by Lettusbee View Post
How come,
Same reason why you park on a driveway and drive on a parkway.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
hdavis (12-29-2018), KAP (12-29-2018)
Old 12-28-2018, 05:23 PM   #71
Inner10's Avatar
It doesn't seal in the juices... The reverse sear just gives you a fresher sear so when it's server it's crispier.... But both methods work.
Inner10 is offline
Robie (12-28-2018)
Old 12-28-2018, 06:13 PM   #72
Inner10's Avatar
Not bad for a two-bit gutter jockey.
Inner10 is offline
NYgutterguy (12-28-2018)
Old 12-28-2018, 06:19 PM   #73
water re-locater
Was a year ago too. Can serrated knives be sharpened ?
Old 12-28-2018, 06:20 PM   #74
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,162
Looks like you threw half that pepper away.
Big Johnson is offline
Old 12-28-2018, 06:21 PM   #75
water re-locater
Yea definitely had another section I could have sliced. That was back in the day when I was doing 30 of them
Old 12-28-2018, 06:43 PM   #76
Inner10's Avatar
Some can. Why are ya using a serrated knife?
Inner10 is offline
Old 12-28-2018, 06:50 PM   #77
water re-locater
Found it cut the best out of the bunch I had. All were new too.
Old 12-28-2018, 07:42 PM   #78
Inner10's Avatar
Sounds like ya need a decent knife.
...the one I used in my video was dull as all hell lol.
Inner10 is offline
Old 12-28-2018, 07:55 PM   #79
https://www.radacutlery.com
Old 12-28-2018, 07:58 PM   #80
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 974
I like a serrated knife for cutting bread, that's about it. Next thing to a hacksaw.
A truly sharp knife is a pleasure to use; practically effortless. Unfortunately, my wife can dull a sharp blade just by glancing at it, so I've pretty much given up on that level of sharpening.
Tinstaafl is offline
Crown around an odd outside corner Expensive Hobby Finish Carpentry 24 12-03-2017 09:04 PM
taping a painted corner A. Finelli Drywall 27 10-09-2014 12:56 PM
Question about building corner cabinet deeper for Staggered Heights Ridicules Finish Carpentry 6 11-14-2013 06:51 PM
Water table, drip cap, corner boards UpNorth Windows, Siding and Doors 4 10-16-2010 04:11 PM
Corner to Corner slump Blockade Demolition 2 12-02-2008 02:41 PM
