Any Locksmiths? - Off Topic (Non Trade) - Contractor Talk
Any Locksmiths?
Old 05-01-2015, 08:11 AM   #1
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,630
Any Locksmiths?
I went to check on a friends house while they were gone and the key got jammed in the lock. It's an ancient Zeiss Icon Cross lock cylinder in a mortised deadbolt. I managed to break the key off in the locked position so I can't open the door.
After some screwing around I managed to extract the broken key but the cylinder is screwed. I'm thinking at this point my only option is drilling it out.
Suggestions?
Inner10 is offline
Old 05-01-2015, 08:18 AM   #2
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 14,330
Re: Any Locksmiths?
I've always thought key making would be a cool thing to do for side work.
One time on craigslist some guy was selling the contents of his van which included the copying machine and a van's worth of blanks for about two grand. Very nearly bought it. Should have.
Anyway, back to Inner's conundrum.
Easy Gibson is online now
Old 05-01-2015, 08:21 AM   #3
Inner10's Avatar
Re: Any Locksmiths?
I have a spare key...just won't work...
Inner10 is offline
Old 05-01-2015, 08:44 AM   #4
kixnbux's Avatar
Rewards Points: 1,440
Re: Any Locksmiths?
My recommendation is call a locksmith. They're as good at their job as we are at ours. I've had several mortised locks worked on with great results. They make it look easy
kixnbux is offline
Old 05-01-2015, 09:13 AM   #5
thezoo's Avatar
Rewards Points: 238
Re: Any Locksmiths?
I am a CRL Aloa locksmith, or i used to be. Yes you can drill the cylinder out. I am sure there are youtube vids, lol. Basically drill where the top pins and bottom pins create a shear line.... At the top of the key way where the key way turns the cylinder cutting through the pins, take care not to drill all the way through the lock cylinder or you will damage either the pawl which activates the mortise lock mechanism or into the mortise lock body. There are only 5 pins, maybe 6.
Here is an article for the fire dept via google
http://www.fireengineering.com/artic...cylinders.html
thezoo is offline
Old 05-01-2015, 09:33 AM   #6
hdavis's Avatar
Rewards Points: 958
Re: Any Locksmiths?
If you can measure the cut heights accurately, you may be able to identify the cut(s) that are off. Quick needle file work if it's too shallow, or grab the spot between pliers, vice grips, etc and whack the pliers with a hammer to peen the cut higher. The worst thing that happens is you ruin a key that doesn't work.
You could always glue a tensioning tool onto the face, and make a quad rake for the lock. That's pretty safe as well.
hdavis is offline
Old 05-01-2015, 09:40 AM   #7
mski's Avatar
Trade: home improvements
Rewards Points: 502
Re: Any Locksmiths?
Well the first thing you due is love tap it with a hammer. If that doesnt work use WD40 and more love taps. Then try the spare key.
Never give up w/o using the hammer first.
mski is offline
Old 05-01-2015, 09:50 AM   #8
Inner10's Avatar
Re: Any Locksmiths?
I've hammered the crap out of it...and I've tried picking it. I used a magnet and got shards of metal out.
Inner10 is offline
Old 05-01-2015, 09:54 AM   #9
Inner10's Avatar
Re: Any Locksmiths?
It's a cross lock, probably has 12 pins.
Inner10 is offline
Old 05-01-2015, 10:14 AM   #10
Re: Any Locksmiths?
Can we have pictures of the lock?
How much time are you willing to spend on this?
This sounds like one of those problems that I would secretly be really grateful for because it would give me a dedicated block of time that I "had to" work on something, but really just didn't want to be bothered doing anything else.
Old 05-01-2015, 10:39 AM   #11
Inner10's Avatar
Re: Any Locksmiths?
I have 2 weeks until they are back from vacation.
Inner10 is offline
Old 05-01-2015, 04:15 PM   #12
hdavis's Avatar
Rewards Points: 958
Re: Any Locksmiths?
Heck, with 2 weeks you can hand make a bump key.
You got all the key pieces out, and the pins aren't damaged?
hdavis is offline
Old 05-01-2015, 04:55 PM   #13
Inner10's Avatar
Re: Any Locksmiths?
Well I tried to drill it so it's really fvcked now.
Here's what they look like new, looks like an 8 pinner. Pin on the slider part of the lock is frozen and won't let me get a key inside.
Here's what they look like new:
Inner10 is offline
Old 05-01-2015, 04:57 PM   #14
Inner10's Avatar
Re: Any Locksmiths?
Any Locksmiths?-uploadfromtaptalk1430517403530.jpgAny Locksmiths?-uploadfromtaptalk1430517414093.jpgAny Locksmiths?-uploadfromtaptalk1430517425583.jpg
Inner10 is offline
hdavis (05-01-2015)
Old 05-01-2015, 04:57 PM   #15
Inner10's Avatar
Re: Any Locksmiths?
I have it drilled out a half inch but there are still pins stuck in the bible.
Inner10 is offline
Old 05-01-2015, 05:06 PM   #16
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Any Locksmiths?
just leave all the pieces on the floor, the door open.
they'll think a burglar did it...
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 05-01-2015, 05:46 PM   #17
Inner10's Avatar
Re: Any Locksmiths?
I would if I could get it open! I can't even pry open the door with the hinges off.
Inner10 is offline
Old 05-01-2015, 07:15 PM   #18
hdavis's Avatar
Rewards Points: 958
Re: Any Locksmiths?
I'm no help...
hdavis is offline
Old 05-01-2015, 07:45 PM   #19
Inner10's Avatar
Re: Any Locksmiths?
I'm no help...
I got drunk instead...let's see how this plays out.
Inner10 is offline
hdavis (05-01-2015)
Old 05-01-2015, 07:48 PM   #20
Re: Any Locksmiths?
How good are you with a sawzall?
Footbridge Media is AMAZING! Heritage Marketing & Sales 101 01-25-2012 11:50 PM
Locksmith realmet Construction 9 07-27-2008 07:52 AM
