Wallpaper Removal Vs New Drywall - Wallpaper - Contractor Talk
Old 08-19-2012, 06:38 PM   #1
QRI's Avatar
Rewards Points: 75
I am currently looking at a 327 room hotel cleanup that entails wallpaper removal. Some rooms have two layers and some rooms have 3 layers. I know what a major PITA wallpaper removal can be so I am a little nervous about properly bidding the work.
Would it be a better to just hang 1/4" sheetrock over the existing walls? Seems like it would be cheaper and would offer a much better surface for whatever wall covering they want to use.
Thoughts?
QRI is offline
Old 08-19-2012, 06:42 PM   #2
Shellbuilder's Avatar
Trade: Shell building contractor
Rewards Points: 1,236
Re: Wallpaper Removal Vs New Drywall
I don't know how anyone could bid that job. You need to bid it with an hourly rate.
www.shelladditions.com
Shellbuilder is offline
Old 08-19-2012, 07:29 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
$65/sheet sounds right to me. I always opt to cover with new board unless the test area just peals straights off with no issues. I use fabric softener and water. Works good and smells nice. Its also cheaper than chomp.
ohiohomedoctor is offline
Old 08-19-2012, 07:30 PM   #4
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 748
1/4 " do they still make it?, 3/8 yes, steamer by the hr leave paper face on sheet rock skim coat, the problem with going over whats there is base board, door casing etc.
sunkist is online now
Old 08-19-2012, 08:55 PM   #5
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Thats a lot of wall paper. I stopped straight pricing it a long time ago, its strictly T&M now. I explain that I have had large rooms done in 2 hours and tiny guest bathrooms take all day.
SuperiorHIP is offline
Old 08-19-2012, 09:47 PM   #6
QRI's Avatar
Rewards Points: 75
I would love to do T&M, but the client isn't going to accept that. All of the doors and trim are being removed so I don't think those will be an issue. i think that the amount of labor need to remove the wallpaper (2 to 3 layers) and then skimming the walls will cost far more than just hanging new drywall.
If it was a smaller job i would just say no thanks, but it has the potential of turning into a lot more work. i either have to figure out a fair price per room for the removal or convince them that new drywall is the way to go.
QRI is offline
Old 08-19-2012, 09:59 PM   #7
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
I would be glad to sub it from you. What finish is going on the walls after removal? Is it just a regular room with a bath ot suites? Everything being demo'd? (carpet, furniture,trim, doors, tile, tub, etc.) or just remove paper and repaint?
I need more tools.
summithomeinc is offline
Old 08-20-2012, 07:43 PM   #8
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
2-3 layers of wallpaper, and wanting to put another layer of sheetrock on top? Better check the local fire codes, you may be in serious violation of one. If that hotel caught fire with all those layers, I'd hate to have my name in the lawsuit loop. Just sayin...
ProWallGuy is offline
The Following User Says Thank You to ProWallGuy For This Useful Post:
QRI (08-22-2012)
Old 08-20-2012, 08:32 PM   #9
PSG's Avatar
Trade: Remodeler & Radon Mitigator
Rewards Points: 75
A few things come to mind. Someone will have to extend all of the door & window jambs unless they stay and you use 200 trim around them. If the ceiling finish is any type of texture you will have to deal with that. All of the electrical devices will have to be taken loose from the boxes and reinstalled after hanging.
PSG is offline
The Following User Says Thank You to PSG For This Useful Post:
QRI (08-22-2012)
Old 08-20-2012, 08:37 PM   #10
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,431
Price it per room.
I would remove what wallpaper I could > Apply Gardz primer > Skim.
If there's an elevator in the hotel, Would a 8' board even fit in it?
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
QRI (08-22-2012)
Old 08-20-2012, 09:11 PM   #11
You need to get the owner there in front of you and a test room. Pull on the paper, bring a steamer, or whatever else you would use and show the guy what its going to take. For that much steady work, it would be worth 2 hours of your time to do exploratory surgery. Owner will appreciate you doing this. Your contract needs to stipulate hours expected on the removal and hours expected on the skimming. Your customer will be much more informed after this. I remodeled a 6000 ft custom last year that had several hundred rolls of paper glued to unprimed drywall. Demonstrated impossible removal in about 30 minutes and signed change order for a big big chunk of change.
The Following User Says Thank You to Shellbuilder For This Useful Post:
QRI (08-22-2012)
Old 08-20-2012, 09:18 PM   #12
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 952
Definitely do a test area. You never know if the guys before sized the walls or not. We just removed about 500 sq ft of paper and it wasnt sized. Skimmed about half the wall. Now we are T&M on this job so its all good. For a hotel I am sure one wall will tell the tale of how it will all go. Maybe you will get lucky...
overanalyze is online now
QRI (08-22-2012)
Old 08-22-2012, 05:32 PM   #13
QRI's Avatar
Rewards Points: 75
Thanks for all of the replies.
We have been discussing doing a test room. I have seen a few rooms that have already had the wall paper removed and the walls look pretty rough. Each room has roughly 700 sq ft of wall area. I think the first two layers will come off easily enough, but it's the 3rd layer that i'm worried about.
I want to pay the guys per room piece price for all of the demolition (carpet, pad, wallpaper, popcorn ceiling, cabinets, etc.), but want to be fair about it.
QRI is offline
Old 08-22-2012, 06:07 PM   #14
I've done several hotel wallpaper removal projects. Schedules are very tight when the hotel is still operating. Start at the top floor and work your way to the first floor and out the door.
Here's one of the guest rooms from a 300 room hotel in Orlando, Florida. We removed 2 layers of wallpaper, repaired any water damaged drywall, skimmed coated and then applied a two step commercial grade knockdown made by Sherwin Williams called Litex. Then we would spray out all ouf the popcorn ceilings.
It has that two tone look and this stuff is hardcore durable.
-Paul
TextureMaster.com
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
ohiohomedoctor (08-22-2012), QRI (08-22-2012)
Old 08-22-2012, 09:44 PM   #15
QRI's Avatar
Rewards Points: 75
Looks good! Luckily this hotel is not operating, but I still expect the schedule to be tight. Still trying to figure out manpower/equipment needs.
QRI is offline
Old 08-22-2012, 10:00 PM   #16
Thanks.
What's the finish going to be once the wallpaper is removed?
-Paul
TextureMaster.com
Old 08-22-2012, 10:45 PM   #17
QRI's Avatar
Rewards Points: 75
Originally Posted by Sir Mixalot View Post
Thanks.
Not sure yet. I have only seen a small portion of the scope of work. Hallways look to be textured with a tile wainscoting. The prototype room has a really busy vertical wallpaper on it. The whole room has a spa/modern feel to it.
QRI is offline
Old 09-06-2012, 06:13 PM   #18
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
strip the paper and then knockdown stucco the walls , that'd be the kind of finish that would be faster than paint finish perhaps would be quicker and cover a ton of sins. I helped one time on a hotel, the stucco was colorized.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Drywall GettingBy General Discussion 3 06-16-2011 12:58 PM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 11:16 AM
Wallpaper removal and Gardz. gideond Painting & Finish Work 18 12-11-2007 10:34 PM
Sheet rock down to brown paper backing, botched wallpaper removal? atv71 Drywall 33 09-07-2007 11:38 AM
Wallpaper Removal Red Canary Painting & Finish Work 33 03-21-2007 02:24 PM
